PDA
View Full Version : General Discussion
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. Cam Thrust Plate
  2. Correct hood release handle clip?
  3. Sleeper or sinister?
  4. 2026 Alternative to Dimondale Friday before Homecoming
  5. 403 short block
  6. head selection
  7. 7037130 throttle body
  8. Northern California brake/machine shop for disc brake conversion?
  9. Does anyone know where to get proper sway bar bushings and core support 1966 Toronado
  10. North Coast Rockets
  11. Opinion poll
  12. 8 years and counting...
  13. 1958 Olsmobile
  14. W30 Broadcast card orphan
  15. Looking for past owner
  16. Any GM 2.2 engine experts in readerland??
  17. 1967 c/s convertible
  18. Annoying ad feed
  19. What are these numbers on my 71 cutlass convertible frame?
  20. Olds 455 marine engine teardown
  21. correct nut and bolt finishes for a correct restoration
  22. 1969 Oldsmobile Hurst/Olds at Mecum
  23. SSiii wheels on my 72
  24. A better solution?
  25. Air cleaner value?
  26. Right Outside Mirror - 1964-66 A-Body
  27. Belt misalignment
  28. A/C compressor and components rebuild service
  29. 1972 Window Sticker
  30. 442 numbers
  31. 1966 Toronado Front bumper filler panel to radiator support IS it reproduced?
  32. 1970 442 fender brace usage?
  33. Breaking a rocker arm?
  34. '71 442 w30 IgnCoil
  35. Rallye 350 pictures... Original paint, interior and serialized parts
  36. What to do with the Old Original Pistons?
  37. See any Oldsmobiles?
  38. 72 cutlass emblems placement
  39. Correct oil drain plug gasket?
  40. 1967 442
  41. 70-72 rear bumper rubber fillers; 'cement to install'??
  42. What is this
  43. Energy Suspension Body Mount Kit.
  44. Resto Lamps-Vacuum-System 1966 Toronado
  45. 1966 Toronado front Hub Bearing assembly removal HELP needed!!
  46. 68-72 A-Body windshield upper stainless molding: Hardtop vs. Convertible differences
  47. 6000 mile road trip in my 67 Vista Cruiser.
  48. Paperwork/sheet under cowl tag?
  49. What is going on with mechanical fuel pumps?
  50. Muncie info
  51. 8 track belts, where to get them?
  52. Need 69 Cutlass/442 tach Assembly Manual photo
  53. 97 88 LS Brake lights
  54. Fram is gone?
  55. Felt lined seams or not?
  56. GM or Reproduction? Trunk mat
  57. Need 70-72 power window wire boot holes sizes
  58. Pace car returns back to Indy for the 500
  59. Weaver Brothers Strike Again!
  60. OAI in a driving rain?
  61. Delta 88 -1968 How to change dash lamps
  62. Avs2 carburetor
  63. Added some detail to my oil catch can...
  64. 1969 Oldsmobile Hurst/Olds - Mecum Indianapolis
  65. Carburetor and vcuumsystem 1966 Toronado
  66. Where is the Chart to decode 455s “Date Codes”?
  67. Need some Oldsmobiles for MCACN
  68. Help ID power window set up
  69. Water Pumps recommendation 1971 Cutlass 455 with AC
  70. Ramrod
  71. For sale not mine, 1936 Oldsmoibile
  72. 1966 Toronado Radiator Core support question / help
  73. disk or drum
  74. Fuel sender is reading 114 and should be 90
  75. 442 Rad Top Plate
  76. Great customer service from Covercraft
  77. Sunvisor parts illust.: Assembly or Body manual, or?
  78. Rallye 350 tail light lens
  79. Paint swabs on disc brake spindles.
  80. A/C acutators
  81. ‘70 W3 4 Speed Carb
  82. 69 442 fender molding clips
  83. Back to my roots! Found a Rallye 350, my forever car
  84. Tire date code question
  85. Interesting find on ebay....
  86. Help needed with value for insurance
  87. Windshield washer bottle
  88. Trying to reach the guy who reproduced the 66-7s Corner lights "dead@mchsi.com
  89. Pics from the AACA Old Dominion event yesterday....(group #1)
  90. Car's spotted on Rt66 cruise
  91. Christmas came EARLY 2026
  92. Moderator permission to post?
  93. Number of restorations
  94. Massachusetts May 9th car show
  95. To go or not to go 🤔 ?
  96. Broadcast card question
  97. Rec'd new artwork for my garage walls
  98. ID these rear quarter inner wheel well.
  99. 1963 Olds Engine Build
  100. Lookit my new toy!
  101. If this has been asked before, I couldn't find it
  102. scammer
  103. W-25 Hood Scoop Black Paint
  104. Illinois Valley Olds Club 2026 Spring Dust Off
  105. Really Cool Dyno Video (new LS6)
  106. Aurora, Any Good? 1k mile on BAT
  107. Carlisle Finds?
  108. Paint color 68 Hurst olds
  109. Cutlass in the wild
  110. Golf carts at Carlisle
  111. Reproduction manuals
  112. An auction in VA has a 62 F-85 2door
  113. Car almost ready for spring
  114. WJ Tees
  115. 1971-2 OAI hood difference
  116. Let's talk about Pot-metal, Zamak?
  117. Cool video about the '69 H/O 'vert
  118. Suggestions on brake booster
  119. New Convertible Top Prep - '70 A-Body
  120. Shipping
  121. Obscure seat belt color
  122. Car Shipping
  123. Better Water Barrier Replacement - 1/4 aluminum backed foam
  124. Vent Window Frame Lock Screw - what Is this thing for?
  125. Remove bolts on Head and Intake Manifold procedure?
  126. Anyone ever get this on without ripping?
  127. 1972 olds cutlass s 442
  128. Two different brake differential pressure valve connectors?
  129. Rear Bumper Bar
  130. W30 Aluminum manifold plug correctness
  131. Fan Depth. Worth it to move a fan back 3/8"s to 1/2" for cooling?
  132. Found a set of wheels for my cutlass .
  133. Fan ID
  134. Clean (Restore?) Your 60's-70's GM power window motors
  135. It was fun but time to move on
  136. 1960 service poster
  137. OCA April Issue
  138. 12 Step program
  139. Where will the Olds parts be at Carlisle?
  140. 19th DVOC Spring BOPC show, Wilmington, DE, May 16, 2026
  141. Rocker moldings & Stripes on 1972 442
  142. Were all hoods not created equal?
  143. Cooling System Stop Leak verses Head Gasket/Block Sealer
  144. 1st car show of the season.
  145. That's it! I'm doing it!
  146. Vacuum Spec 442 w/455
  147. Woodgrain dash for 1970-1972
  148. Black or silver?
  149. Rider Oldsmobile State College Pa.
  150. Any Opinions & insight, Steele trunk weatherstrip 68 442
  151. 100 Years of Route 66 Celebration
  152. 64-65 Cutlass Header brand fitment.
  153. Windshield 1955 88 Frozen cons gluing or gasket
  154. My 70 Olds featured in May Good Guys Gazette
  155. Dual Snorkel Air Cleaner
  156. Color choices on this 1968 442
  157. My plans changed. Now looking for my forever car
  158. Conversion to PCV?
  159. Charlotte Autofair April 9-11
  160. 70-72 shades of Gold & Names
  161. Parts cars or projects?
  162. 1980 Cutlass for sale on BAT
  163. My Red '71 442 Convertible used in local TV commercial
  164. Is all this really necessary?
  165. E15 Coming Soon
  166. Original decal removal on Rallye 350...
  167. Ok, now I'm confused 😕
  168. 65 Cutlass door glass
  169. 1971 W30 Vert
  170. Air cleaner decal
  171. Vapor Blasting
  172. Urgent need to know
  173. They just don't build them like this anymore
  174. 1973 cutlass dealer training video
  175. UTG and Exhaust manifold gaskets
  176. Over $200 worth of new parts
  177. This poor '68 Cutlass Convertible
  178. Walmart Everstart Maxx size 34 battery - junk
  179. 1970 A/C question
  180. Interesting VIN Tag
  181. Snow #442
  182. Rear Axle Cover With Magnet 10BOLT anyone seen this style cover made by GM???????
  183. Tulsa swap meet Apr. 18-19
  184. Is this for real and can somebody explain?
  185. Concrete epoxy coating
  186. Reproduction Outside Door handles, any good?
  187. New car buyers watch this
  188. New toy, 50 Olds 88 4dr stick
  189. 1968olds
  190. Nice Story on Olds
  191. 1960-1968 Trico Power Door Lock Switch Restoration
  192. Water valve
  193. 78 Trans AM SHAKER BASE with OAI BREATHER TOP
  194. Q4 Cutaway
  195. What window sweeps do I need
  196. What was the first day of production for the year 1970?
  197. Clutch squeak
  198. Plastic washer Oldsmobile Delta 88
  199. Batch codes 70 W-30.
  200. 400882 Front Spring Free height?
  201. Enclosed trailer length
  202. Cool barn find...
  203. Trans Modulator Valve w30
  204. DECAL Oil Filler Tube '71 w30
  205. OReilly 48 Hr Loan a Tool
  206. Bought a car without a title
  207. Column shift vs Floor shift
  208. Vert Top Frame Alignment
  209. Speaking of Curbside Classic...
  210. The death of Oldsmobile
  211. Should I re-do?
  212. Window Gasket Question
  213. 1970 442 Convertible Top Rail Seals
  214. 68-69 NOS 442 fenders
  215. Power brake Vacuum hose
  216. 71-72 4-speed console and lights
  217. Ready to order, help with bumper bolts
  218. The cruiser
  219. Interiors
  220. Pomona Swap Meet March 1
  221. Poor headlights on my Daughter's 2013 Ford Edge
  222. The most successful Oldsmobile ever produced.
  223. 64-65 lower quarter patch panel
  224. 1972 Hurst Olds/Antique Auto Magazine
  225. Reproduction window stickers
  226. 1966 442 Brake booster Tag
  227. Engine rebuild costs
  228. Pypes down pies uncorked
  229. grille and headlamp refurbishment 1964 Dynamic 88
  230. Engine installed
  231. Name this part
  232. W-30 experts here's a good one for you.
  233. Junk in the Trunk!
  234. Dynamic 88 Speedo Cable
  235. New GM engine rebuild
  236. See the Oldsmobiles being built!
  237. Exhaust Manifold Deterioration
  238. Cooling system decal???
  239. 1972 Arlington plant
  240. Recent family acquisition...
  241. 1984 Hurst/Pete
  242. electric antenna
  243. NOS Firestone Wide Oval G70x14 DOT Decode
  244. 1960's style wire ties
  245. Reuse cork valve cover gaskets?
  246. Ed Iskenderian takes life's checkered flag at age 104.
  247. Playing with ChatGPT today
  248. AI isn't so intelligent...
  249. Build sheet?
  250. Cruise control picture or parts on a 1971 Olds Cutlass Supreme with a Rocket 350
