View Full Version : General Discussion
- I bought another olds
- fuel gage issue
- sputtering after turning key off
- Got a nice surprise today
- Houston Texans!!! WooHoo!!!
- 71 Cutlass Seats
- '67 Turnpike Cruiser
- Fisher Body StageCoach
- Hello All,
- intake valleypan gasket ?
- thank you to "GMAN"
- Hurricane Irene Thread
- Did my starter just die?
- 71 Assembly manual
- Nifty Oldsmobile radio commercial from 1967
- 670 street avenger
- Berlin, CT New England Olds Club Show - Sept 11, 2011
- Mid-Ohio Chapter Oldsmoible Show September 18, 2011
- UPS driver finds me another one
- shipping a manual transmission.
- fiberglass insulation under hood?
- Compression ratio question.
- 84 olds rusting out bad and electrical problem driving me nuts
- Riddle me this batman
- Daughters first ride in the 442 convertible.
- 1975 Delta 88
- Final member of my family showed up today
- 47 olds wheel lug nuts
- Door handle gaskets
- Muscle Cars For Kids... Kent WA Top Foods
- Tampa
- To Swap or Not To Swap....That is the ?
- Would like to see some 68's Olds pics
- Anyone ever just replace the rear window on their convertible top?
- D-day tomorrow
- New Cars
- Great Road Trip..ducking corn
- New location for a build sheet to be found
- Car Show Display Card
- My project for the weekend......and a little tire smoke too lol
- Detailed My Delta!
- Anyone else with a 5 speed Cutlass?
- 59 Caddy Stolen at Dream Cruise
- Alabama OCA club chapter
- Fan Shroud Info Needed
- Back to the Bricks (Flint, Mi.)
- New model showroom covers
- What do you guys think of this T shirt?
- dog dish caps--help
- Paint Match
- Live feed from Detroit
- Help!
- Reason number 2,434,368 why it will be a long time before I buy a new GM car
- Mom seen & rode in the Delta today
- Delta got made fun of today
- Jet-Hot questions
- Wiring harness for 1966 4 speed and fuse box. Electrical ?`
- Just my luck....
- Parking & dash lights went out...
- Looks like Ken (442much) has a cloned little brother
- A backfire lit up my Delta 88!
- 72 W29 package
- Attention
- DVOC Fall Show Oct 9 2011
- hose routing
- I got harassed by a prius owner today
- Continental Kit
- Vacuum advance
- 1969 looking for parts
- Can We Have Some Fun With This!!?
- Quarter panel extentions
- My scoop
- u joint and rear end identification please.
- Bristol RI Car Show
- Rear end codes upside down. Is it possible
- Oldsmobile "take rates"
- Rookies needs help with engine stand
- Results of Hot August Nights in Reno
- Help decode my 66 rear end. 10 bolt f85
- 25th Annual West Coast Nationals
- Charlotte NC AutoFair
- Anyone use rotella 10w30 instead of 15w40
- Stolen 69 H\O Convertible
- the big one route 66
- Magnaflow Exhaust Review
- JEGS or Summit?
- Convertible Top Cylinder Mounting
- olds 442?
- Fuel Filller Bracket or Brace
- wheel cylinders
- My second car show.
- Fusick 1968 Headlight Surrounds
- The Fulton Burger Classic Car Show - Sherwood Park
- BOP car show in Richmond va
- Any help decipher the protecto plate 1966 olds f85
- Rockers still clicking on my 350
- Mpg on 66 f85 330 lc 2 barrel-fuel economy
- Harper olds brooklyn, anyone know about this place
- Any Ford Techs here?
- Picture of a great American with my car
- Toughest engine?.
- 1967 "Stock" in-dash tach?
- Cruisin the Coast 2011
- Upcoming car show
- rear wheel bearing questions
- any quick and dirty tips for carb adjustment
- Dealer installed buckets/console is it possible
- Trick shift fluid in jetaway. Does it help
- timing set
- The mystery of a ghost BMW dealership
- olds 330 fuel difference in octane
- Birmingham/atlanta area to nj/ny area
- 1/4 Mile and 0-60 Peformance Data 1966
- what thermostat???
- Anyone know about using "Diesel" oil?
- Transmission and Idle Speed
- Harmonic Balancer ?
- Column or Floor Shift?
- any one know this car
- Whoops! Anyone into Biker Forums?
- 57 Olds door rubber trouble
- 15" Rallye SS2 Are they worth $50.00
- just when things are looking good...
- Low voltage to coil while starting
- Which side is the alternator supposed to be on?
- quarter panels
- Oldsmobile 455 hemi
- Somethnig I have wondered about drivers stopped at lights...
- # matching car vs non # matching.
- NTOC 2011 ZONE SHOW Update
- finally drove it! now what are these noises?
- Safest way to jack up a car on 4 jackstands
- Here she is. My 1966 f85 holiday coupe deluxe
- Made it into the Members Garage in JWO mag!
- valvetrain
- 70 Cutlass added to the barn lot.
- 1957 Olds Production Dates and Generator
- 1975 Delta 88 Convevrtible HELP!!!!!!!
- Someone Here Should Buy This (57 Olds 98)
- Vacuum diagram?
- Speedometer broken, how do i fix Help please
- 350 valve cover gastkets what type?
- Fuel choice..
- Manuals?
- 66 starfire
- Fouled Spark Plug
- 1969 N34 Sport Steering Wheel
- Olds owner frm Tx
- production dates
- 330 LC Octane and Lead Requirements
- Sticky wheel
- 91 Olds Cutlass Calais Intl.
- Covertible top - leaking
- Oil Pressure?
- tune up for 72 cutlass
- Does 70 Supreme Molding work on 72 Supreme?
- Production numbers?
- front end 1969
- Quadrajet power piston
- Why Is This Chain Here?
- bumper jack
- Toronado oil pan?
- Pix of my junk
- OLDS C/S - Wierd or What?
- What would you do???????
- Flowmasteror Dynamax
- Buyer did not pick up car, HELP!
- Potential Transmission filter distributor
- 70 Cutlass- Brake light switch..no brake lights
- Covertible Top Question
- rear cargo coil springs
- How do i remove my steeting wheel to mount and NRG Hub
- 91-2 Custom Cruiser in Collectible Automobile
- Idle solenoid
- Seam sealer
- Survivor status
- Pontiac, BMW and Oldsmobile(?!)
- Color matched rocket emblem...check it out!!
- What's it worth? Choptop 2 door delivery Olds Cutlass Cruiser wagon
- Installing Cowl Tag Rivets
- Car Show Pics. Amherstburg, Ontario
- 56 Olds Door Button Not Working
- can anyone figure out what this master cylinder is for?
- '67 4-4-2 Post Interior Color Codes
- I got back from Reno late last night, my impressions
- Gasoline in the oil
- Spark plugs
- 68 442 Cowl Tag Decode
- How do i tell the missus
- Can I use Diesel Oil in my V registered Astra 1600cc petrol engine , 125,000mls
- Hamm36 (Carl) gets some A/C parts installed
- power windows stopped workin today
- Production Volumes
- Cowl tag purchase
- Did Hot Rod Power Tour in a 67 442 convert!
- Ron Roth dash restorations
- Do-it-yourself suicide machine. Needs work...
- Steering Wheel Play
- Question about Disk Brakes in general
- Hugo MN Oldsmobile car show. Is anyone going to it
- Clean 78 GMC Motorhome aka super big Toro
- Reno Report and Update Please!
- stalls when braking
- Looking for historical info on a 66 Trac Pac from Michigan
- push rod/ rocker arms help
- SuperRun Saskatoon
- oldsmobile 1963 dynamic 88 convertible
- price on 455, good deal?
- Vintage road test
- Carbs & cams - AT vs. stick version ???
- Apoligy,to all...
- Info Please
- 1979 2 door landau top question
- fingers crossed exhaust leak
- One one on RealOldsPower?
- '54 Olds corvette killer?
- What Makes this a Clone
- My 66 3 x 2 convertible
- too much coolant
- Motor & trans. "swap" costs
- Rocket horn button for 3 spoke "comfort grip" steering wheel
- how do i fix my power booster SEE PICS
- landau top question
- What's up with"none olds powered?
- Couple of fresh pics, after car show
- trailering question
- Front coil springs
- Telegraph Car Cruse
- Stock stamped steel valve cover gasket???
- 8 track housing unit...has anyone purchased one?
- Pal/Speed nuts or Barrel nuts for emblems on 68 442
- how to tell the difference between 3 and 4 core radiator
- Whats wrong with this picture?
- 73 Delta 88 fuel tank
- 72'OAI latches,brackets.Where?
- BOP 1/8th mile near Mt.St. Helens
- 425 Olds powered 1973 Kelmark
- Cooling system upgrade
- Need some carb cleaning help...
- Need help with codes for pullys
- Need help with interchange of 1970-72 Wheelwell Stainless
- Not even car shows are safe
- 1967 442 instrument panel restored by Ron Roth rroth01
- Computer/tech question-Music w/email
- '67 Skylark & '67 GP complete in a yard!
- 1947 Olds Vin decoding
- Strange problem after putting in premium gas
- A Horrible Way To End A Weekend Car Show Vacation
- Vent window weatherstrip install on 68 442?
- So this is how my Friday night ends
