PDA
View Full Version : General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 [93] 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. Automatic Shift Knob Thread
  2. Wild About Cars Has a Newsletter
  3. Car Museum
  4. What Olds Tail Light?
  5. To the boneyard or save?
  6. 442 LED tail light upgrade
  7. Quadajet 4 barrel odd idle
  8. Cleaning Engine sludge--Seafoam good? Bad?
  9. Bad Vibration, Part 2
  10. Pictures Request
  11. I need some info on a speedo cable
  12. Save a Suburban or part it
  13. looking for Bob Brannon OKC
  14. Question about value of the Olds Tri-Power
  15. Annoying craigslist trend
  16. My repro SS1 wheels & tires on EBay
  17. 1966 Cutlass on autocross (video)
  18. Looking for 455 Valve Covers, and a question
  19. In need of advice on aftermarket Ram Air Hood!!
  20. th400 oil pan?
  21. need some help
  22. RobertShaw Stat
  23. Original-yes or no
  24. Mystery cable
  25. Willie Nelson 1964
  26. 7th Annual BOPC Car Show, Media, PA, May 19
  27. 72 Cutlass Exhaust
  28. Free Posi Decal
  29. SS1 Wheel codes
  30. 455 Valve Covers
  31. Buyers beware!!!!!!!!
  32. carfax reports
  33. Took A Little Drive...
  34. What year Cutlass?
  35. Instrument Repair Service
  36. OK all.....I have been on here for a bit...
  37. C2c
  38. Seeking information on former Oldsmobile Dealership in Hollister, California
  39. Not an Olds, but still cool.
  40. Pate swap meet!!
  41. Argggg!
  42. Is this worth $200,000
  43. fender skirts
  44. Starting engine for the first time in 3 years.
  45. Floorboard undercoating
  46. Wanted to introduce my 69 Cutlass
  47. New Olds!
  48. Portland Swap Meet
  49. A/C For My 1972 442
  50. Vacation Time Vancouver & Pacific NW
  51. 76 olds cutlass 260 v8
  52. Doors
  53. Tranny filter 67 supreme
  54. Olds in the "Great Race"
  55. So anyone else going on Hot Rod Power Tour?
  56. hood alignment
  57. Replacement / Stall torque converters
  58. Could use your help! TH350 from Ohio to California
  59. What makes my car worth more?
  60. Electric Fan?
  61. The Firewall Stampings Thread
  62. oil pressure guage and engine temp guage
  63. Brake Proportioning Valve
  64. Old Air Products
  65. Houston Motorsports Park - April 13, 2012
  66. The planets aligned in the Pacific Northwest
  67. Non-Olds
  68. NOS 70 hood tongue troubles
  69. '92 Custom Cruiser 350tbi idle surging question
  70. Bad hydraulic lifter?
  71. '69 vacuum trunk release
  72. 70 F85 Post car - worth saving?
  73. Replacing valve cover 67 supreme questions
  74. Radio Speaker
  75. '70 442 air conditioning
  76. 71 Cutlass Will Not Start
  77. Look what i found....build sheet????
  78. POA Valve Inspection
  79. Cars & Coffee Event - Plano Texas, Tomorrow Way Too Early
  80. 65 Cutlass cowl tag
  81. Pictures
  82. Nothing is ever easy!
  83. Vintage Air - '70-'72 A/C Car is now available
  84. 455 gaskets
  85. Ethanol free gas
  86. Tim McGraw on a 442?
  87. N. Cal / S. Cal Salvage Yards
  88. FYI On Link To Ethanol Free Gas Locations
  89. Fisher Body Production Codes
  90. Question on a windsheild seal
  91. Anyone a Admin on R.O.P.
  92. Ok, I'm torn on a decision concerning my 442
  93. Brake Dillema HELP!!!
  94. Going to look at a "barned" 66 Tornado, what should I be looking for?
  95. How to sell a car?
  96. Cool 1960's aftermarket valve covers. Any ideas to make a PCV system work?
  97. 5 speed richmond or tko 600
  98. 67 f85 cowl tag decode
  99. should i sleeve 1 cylinder or bore 8 cylinders?
  100. deceleration chirping noise
  101. Does anyone else have a washer pump like this?
  102. who sells tcs bracket?
  103. The "NEW" Assembly Manual
  104. Need Help, floor shift column missing what linkage?
  105. Blueprinting charts
  106. '62 black / yellow wire
  107. 71 delta 88 rad cap????
  108. Check your spare tires.
  109. nice 1936 video on you tube
  110. Complete front end replacement progress...PICS
  111. original groovy green!
  112. Need some Help mounting O-L-D-S-M-O-B-I-L-E on Rear Deck Lid
  113. security system
  114. Locking Gas Cap Trouble
  115. Check The Oil Ma'am
  116. 1969 Rear Wing Diagram
  117. 68 400 oem paint color
  118. 70 F-85 W-31 With 10K Original Miles
  119. 39 pontiac plexiglass ghost car
  120. Bumpers
  121. Oldsmobile Feature Night at Rideau Carleton Raceway
  122. Restoring my convertible
  123. Need some help
  124. Olds/Caddy dealership pics from Hemmings
  125. rim blow steering wheel
  126. Is this how scams work?
  127. InLineTube..again!
  128. gonna change my fuel line from the gas tank, any tips?
  129. Journey with Oldsmobile
  130. My New 71' Cutlass Convertible
  131. Diesel cleaner?
  132. New Floors in a 70 Cutlass
  133. Warning to Indy residents
  134. So how long do think a clutch in a modern car can last after starting to slip?
  135. 1965 442 Grille Treatment Flat Black
  136. Did it again.............
  137. Idle Speed (IN PARK)
  138. Buying an Olds-Surprise!
  139. What will happen to your car if you don't drive it enough!
  140. Front strut replacement
  141. Olds Jetfire Rocket V8 in Airplane?
  142. Concept Olds 442 rendering (New)
  143. Cross Border Shopping
  144. Opinions Please- not about an Olds
  145. quick wiring question
  146. olds delta 88 royale brougham
  147. Header interference 73 Cutlass S
  148. Any value bump from Vaughn's "bumps"?...
  149. losing fuel pressure
  150. Lakehurst NJ 1943
  151. 1949 tucker photos
  152. Dual Gate questions
  153. 67 F85 hood
  154. my 33rd oldsmobile
  155. The green highway, our Governments answer to Petrolium
  156. 394 - compression ratio
  157. how do u drain the tank on a 72 cutlass
  158. Build date question
  159. Relocating to Baltimore - resources?
  160. 74 delta 88 royale 75 delta 88
  161. 1948 Oldsmobile of Tomorrow
  162. Holiday Inn Continued
  163. 1970 442 convertible new wheels/tires help needed
  164. 1970 Front Bumper Guards - A-body, 442, Cutlass, F-85
  165. Ebay W30 Something I Did Not Know?
  166. Shipping - WTH??
  167. Waldron Exhaust?
  168. Is there a diff-Clone vs. Tribute?
  169. Oldsmobile Solutions for trailers
  170. 85 olds delta 88 307 vacuum diagram
  171. Some Oldsmobile SPECS - the little known pieces
  172. Kids Today
  173. Not that I need another project, but...
  174. The Line Up - Part 1
  175. Fill up AC
  176. Old color photos of WWII stuff
  177. 1965 442 Clone Boxed Trailing Arms
  178. Orphan Car Show at Bothell, WA in July
  179. Help me pick my wheels SS1 vs Torq Thrusts
  180. Convertible cutlass
  181. Round Oil Dipstick?
  182. 71 supreme
  183. Mini-projects
  184. Car warriors cutlass
  185. 425 versus 455
  186. Mecum auto auction
  187. Carburetor percolation
  188. 1969 Cutlass Convert. door glass
  189. Oldsmobile script bricks wanted
  190. 1971 Cutlass Convertible to 1970 Fastback Body Conversion
  191. Hotel Motel Holiday Inn
  192. 394 puking oil
  193. replacement speaker
  194. '66 442
  195. 1965 Radiator replacement
  196. how to clean a dirty gas tank
  197. Question: "Propeller Shaft"
  198. poverty cap removal tool
  199. Well it will never happen to me Pictures at 11
  200. bumper refinish
  201. Help with 70-72 console value $
  202. Estimate of value?
  203. Key Stuck....
  204. WTB Olds Toy Car for Kid w/ Autism
  205. The Parts Place Customer Service
  206. 1966 442 convertible frame
  207. Scanned an old photo
  208. 71 delta 88 cruse control
  209. '68 Cutlass front speaker replacement. Is it as bad as it looks?
  210. sitting here wondering....
  211. How do the front shocks come out? 62 F-85
  212. A/C Vacuum lines
  213. bleeding brakes procedure 67 Cutlas Supreme
  214. Inside Window Felts - HELP!
  215. VERY Cool CHP Olds Pic
  216. Junkyard parts source near me
  217. Early AM Cruise in Central New Jersey 2012 03-18
  218. Will Someone Please Help With Canada Body Tag Decode
  219. adding rightside mirror
  220. Window seals!!!!
  221. No motor or trans but could be a very profitable numbers matching car.....
  222. Has anybody eliminated the ccc on a toronado
  223. New Idea for a build, "The Olds dealership garage"
  224. Correct me on this, but...
  225. Convertible Top - Plastic or Glass rear window
  226. Cut out bumper worth?
  227. Cutlass supreme for $32,000 on ebay
  228. part number help
  229. Go Olds!
  230. Gauges
  231. tricky fuse problem in 72 cutlass
  232. Ones that got away
  233. Oldsmobile Reference Book
  234. #1 '70 442 pace car
  235. 67 Delmont 425 and 400 trans
  236. Cruise Control?
  237. Finally Replaced Motor Mount - Broken Bolts
  238. 1984 Caliente..CCC removed now having idling issue
  239. Holley Pro Series Secondary Linkage
  240. Won't fire...
  241. Please Help
  242. Check out these pictures!
  243. jUST PICKED UP A 85 DELTA 88 ROYALE BOURGHAM A COUPLE OF PROBLEMS
  244. Doggone It!
  245. Showboard for a 69 H/O
  246. Brace Behind Seat on 1971 Cutlass Convertible?
  247. The 66 is off to the body shop
  248. 69 442 dashpad
  249. Pee Dee's in Myrtle Beach
  250. Blend Door Motor
