74 delta 88 royale 75 delta 88
Old Mar 24, 2012 | 04:11 AM
Bigball's Avatar
Are the tail lights interchangeable from a 74 delta 88 royale with an 75 delta 88
Old Mar 24, 2012 | 04:32 AM
jaunty75's Avatar
I would think not, assuming you wanted to maintain an original look. Just compare the two:
1975:
1974:
The '74's are divided through the middle horizontally while the '75's are not. The two might interchange as far as fitting in each other's slots, although in looking at the two just now, the '74's look slightly larger. I don't know for sure. But in any event, the appearance would certainly not be correct.
Old Mar 24, 2012 | 04:35 AM
jaunty75's Avatar
By the way, which one do you actually need parts for? Here's a guy selling taillights for a '74:
https://classicoldsmobile.com/forums...ear-parts.html
Old Mar 24, 2012 | 05:09 AM
rocketraider's Avatar
Oldsdruid
They will work by changing out the entire bucket, but as you see the taillight styling is very different between 74-75. 75-76 88s use the same taillight assemblies.
TNGAREB
Mar 9, 2006 08:09 AM
Terrifying Toronado
Oct 18, 2005 12:15 AM
<Delta 88>
Jun 7, 2005 04:53 AM
Oldsmobile Jo
May 20, 2004 05:55 PM
<Dennis Oliver>
Mar 14, 2004 08:58 AM
