Inside Window Felts - HELP!
Old Mar 18, 2012 | 11:23 AM
guy.graziano's Avatar
Guys - I was working on the door panels of my 66 Cutlass today and took the inner window felts off. They were stapled in. The kit that I got from Legendary has the same clips on the inside "Sweeps" as the outsides.
Do I need to remove these clips and find staples or drill holes and use the screws they provided ?
Of course there are no instructions.
I searched CO here and and couldnt find any threads that helped.
Thanks!
GUY
Old Mar 18, 2012 | 02:30 PM
Tedd Thompson's Avatar
The problem that arises is no one has that big of a staple gun in there tool box that they would probably use only twice a lifetime. I believe originally they were all stapled but I have often wondered if a pop rivet would work if you could get it flat enough, never seen screws used, might work as well as pop rivet though. ...Tedd
Old Mar 18, 2012 | 03:01 PM
aristellier's Avatar
I've just done mine on my '63 Starfire and I glued them on adding small screws to totally secure. The small screw heads laid below the felt level when tightened down.
Old Mar 18, 2012 | 03:06 PM
Chumley's Avatar
I just got my new felts from Legendary(after only 6 months) and they gave me new staples for the inners. I have a '72, but the principles are probably the same. They are made by Repops, and did come with brief instructions. The inner sweeps have staple holes pre-drilled, and they say to clamp the sweep in place on the panel and use it as a template to drill new holes in the panel, since the old holes don't line up. They did say to avoid pop-riveting, as this could be visible when the windows are down. I'm surprised that the new sweeps you got don't have the same attachment setup as the originals. I personally would take it up with Legendary to make sure you got the right sweeps. The first ones they sent me were incorrect, and it took me nearly 2 months to get the correct replacements. Best of success. Chumley
Old Mar 18, 2012 | 06:19 PM
cargo442's Avatar
staples would be best, but i used pop rivets on mine and painted the heads black to blend in. hardly noticable.
Old Mar 18, 2012 | 06:43 PM
Lady72nRob71's Avatar
Use the existing holes in the metal rail, drill through the felt strip, and crimp the new staples with pliers and a backing piece (I used a brass nut).
These posts may help...
Rear:
https://classicoldsmobile.com/forums...html#post66668
front:
https://classicoldsmobile.com/forums...tml#post162232
Old Mar 19, 2012 | 06:37 AM
I think that Legendary sent me all outters!
MLK-442
Feb 17, 2016 01:47 PM
4424me
Feb 1, 2012 05:35 PM
sixty9olds
Sep 29, 2010 08:00 AM
dsolomon
Jun 3, 2010 03:53 PM
Hark442
Vista Cruiser & Wagons
Sep 21, 2009 02:25 AM
