View Full Version : General Discussion
- 1970 Rally pack. How to change face plate on cluster??
- ever heard of an smx cutlass??
- high temp paint for heads
- curious
- 350 + 455 fuel injection
- what?
- 2.2 Ecotec
- Strange resonance or harmonic sound from heater cont valve
- Stripes & Plaid Don't Go Together
- Houston area engine builders
- '68 Cutlass Wagon rear handling "glitch"
- help identify this engine
- By Design or Flaw
- 65 Delta 88 ignition lock
- Removing upper steering column bearing retainer
- W30 and Fan shrouds
- My New Garage !!
- Need to know if anyone knows this guy?
- Serious Truck RACING
- My grandsons 442
- 67 f85 club coupe door panels
- uber rare 93 w-31
- #12
- 455 blocks stamping not casting
- Spark plug confusion
- Don't see stuff like this everyday 1980 Omega SX go kart
- 1968 Two Speed Automatic
- Trans rebuild kits
- 455 "X" heads
- Vin numbers
- the weekend started OK, then gas, gas everywhere
- More of my 55 Olds patina
- who? got wipers from John in medford
- Help with new purchase 1967 cutlass conv.
- Vista Cruiser & Airstream
- Need help with 70 Dual Gate shifter
- Opg
- Wheel bearing inspection/replacement tips
- Possible build sheet?
- Couple pics of my 71 S at World of Wheels Chicago
- Texas engine builders
- promo items
- Interesting Article on the Olds Logo
- Date plate info
- Is There A List Of Trans For A 350
- Damsel in Distress Carburetor Help
- San Antonio TX
- 70 cutlass - front drum brake piston retaing bolt wrench size?
- G head disassembly.
- Any Pics of Convertible Top Cylinders Installed?
- Dual Gate Light Housings
- Driver side sitting 1" lower?
- New and need some help with my Delta
- To rebuild and change out starter motor or not
- us 41 or no limit raceway in morroco indiana.
- Stampings on Service Engine Blocks
- Jetaway Transmission
- Drum To Disc Brake Conversion
- Vista Cruiser Bumper Jack PITA
- anyone deal with oldsmobile cars and parts of oklahoma?
- Are you Green?
- 55 Olds patina clear coat, we love it
- California Olds owners-'member these??
- So what's the difference??
- Rebuild: 425 or 350???
- No Valve Adjustment
- Thank you 80 Rocket & 67 Cutlass Freak!!!
- Type of Exhaust Manifold Gasket (Cheap vs. Expensive)
- What is this?
- To put Thermo-Tec insultating tape on exhaust manifold or heat shroud pipe?
- styrofoam bumper for a 1970 442 convertible
- Oil rated hose vs fuel rated hose
- Found 1955 88 two door hardtop
- Selling a car. Payment etiqutte
- 1984 Delta "Noise Switch"
- Aftermarket audio \ 1972 442
- Any ideas on how to remove a lot of gas from a car? Also, anyone got a spare carb?
- glass interchange
- Cutlass SX fans are not gonna like this article
- Dyna Mat (or equivalent), School Me
- Error Codes!
- Olds article in April Collectible Automobile
- For owners of 1959 Oldsmobiles -- an event for you
- Olds Woodie wagon sells @ auction/Hemmings
- Installing the Accelarator Cable Clip on a 68 442
- Computer down.
- I know I'm crazy, I just don't want to be the only one...
- 1972 oldsmobile cutless question
- Super Stock III Wheel Finish
- 1968 Conv 442 frame- Rear Brake Hose Mount
- Need help identifying a part...Radio Delete Plate?
- Door Panels
- Worried about your kid's interview skills?....
- 67 f85 club coupe
- 12V DC PLC controller on epay
- 1966 Cornering Lights
- Intake Manifold #16
- Sound and Heat Insulation
- The Iron Head Thread.......
- Topping it off
- 66 400 vs 67 400
- Dakota Digital VHX in a Cutlass
- 18 inch wheels for 1971 442
- George Berejik RIP
- 394 cui exhaust manifolds
- Identify this Heat Riser Tube
- Water Wetter ?
- Perfect Ignition Timing for Street Use ?
- Coil Spring Choice Help Needed W-31
- NYT Op Ed Today: End the Ethanol Rip-Off
- 55 Olds Rear Window Reveal Molding
- 71 442
- Another load of good parts. Mostly '70-'72 & some G body
- Eastwood or Name Brand?
- 65 cutlass
- 70 W30 Carb
- What does NOS mean?
- scissor lift?
- Glove Box Diving
- Getting a Cassette tape out.
- Bad toruqe converter??????
- 67 Delta 88 Power Top Help Needed
- 1970 Emission Tag
- Parts For 1972 Delta 88
- Help with 4 core radiator
- 70 Supreme help
- C casting question
- One for the transmission guys.
- Recent Find 1967 F-85
- Power Steering Box Leak. Need Insight.
- REO nationals
- GoodGuys in Scottsdale
- Full Size Center Link joint replacement
- I have finnaly found a nice 68 442 hood
- Air Conditioning from Rock Auto
- Service manuals online?
- thank you all
- Guess whats inside
- 1969 455
- If only oldsmobile had this technology!
- 72 olds dual gate
- I'm either an Olds fanatic or just plain crazy
- Cowl Tag Decode help please
- Soon to have a 455
- Body plate decoding.
- Wings Auto Art
- Manifold value
- '67 Cutlass/4-4-2 Post Coupe Power Window Regulators
- 70 W-30 Non Air
- 70' 442 1 of none!
- wiper motor decals
- 69 cutlass rear window regulator
- Trans jack ?
- 2015 olds homecoming alert!
- Vintage Car Advertisements
- Apple Pie, Americana and some Chicago History
- A nice day for a drive
- 1970 Oldsmobile engine chart
- Removal of the emission equipment
- Still learning and BBO Heads?
- My 55 Olds 324 Dual 4 youtube video
- [69 Cutlass] How to remove a rear Power window Motor??
- OBDI code retrieval Problem 93 OLDS Cutlass Cierra
- is it pinging
- Got my 55 Olds lowered
- w30 shortblock
- 1971 - 1972 W-30 Manifold
- If you are not making mistakes you are not learning
- Chroming question.
- Oldsmobile 350 Build . . . . Newbie?
- Caught in traffic
- Needing help
- bought a 1965 442 today... need help with data & protecto plate codes
- 1953 Oldsmobile dealer book help
- I'm a terrible care taker
- OBD2 Car Scanner
- SBO with AC radiator questions?
- Best aftermarket sbo hei distributor
- Traffic stop gone wrong...
- Tower Clamps
- Wheel color name or code??
- 71-72 Cutlass Cruise Control Switch
- Any 70-72 guys near Chincoteauge Island, VA?
- What seems fair?
- I thought this was funny
- Feb/ 27/56
- Oldsmobile Pace Cars
- Need Some Help On Behalf of my Grandfather.
- 1957 Oldsmobile Fiesta wagon ..
- How can you tell a real 1972 442
- Anyone care to de-code a body tag for me?
- Steering box rebuild
- Got my 324 dual 4 installed
- Travel suggestions?
- 1970 Cutlass Supreme Cowl Hood (3")?
- Another tire size question!
- 70 Cutlass S, SX Convert Numbers
- '66 Skylark GS validation
- Need help, disassembling a column shift tilt.
- Parts Catalog to get part number for any item?
- Vent door behind the pass side wheel well
- 70 W-30 Alternator, non air
- 66 W30 Option
- looking over the w25 hood on my rallye...video youtube
- Recommend a transporter in CA for 2, '68 Oldsmobile 88s?
- Anyone know a eng rebuilder/shop in Charlotte NC
- My First Start up after the Rebuild (72 Cutlass)
- Production questions
- help with trim tag decoding
- Clunk sound after spring install
- What's this part for?
- Quadrajet Fuel Inlet Nut and Gasket
- Anyone planning road trip south?
- 1958 Olds 98 script on deck lid
- a day at museum
- Do you remember 1976?
- swap meets and to do lists.
- balance point
- turn signals won't work on my 1976 cutlass supreme
- 1970 Olds Ninety Eight - Lead Substitute?
- Help Identifying Older Red Fenderwells 70-72
- Tire and wheel dilemma and judging?
- How long can you leave a battery charger on?
- Collins Oldsmobile Fort Wayne Indiana
- 1968/1970 Cutlass fender values
- Texas Roadtrip
- ever hear of this option?
- What color and Fabric are my seats? '72 Vista Cruiser
- Caliper Brackets and Splash Shields
- CL add for 64 f85 convert
- 55 tail lights
- Spring Carlisle!
- rearend i might have scored!!
- 1983 Delta 88 posi rear, fit in a G body? Worth anything?
- trim tag on 70 f-85
- trim tag on 72 supreme
- GM Heritage Center
- Interesting Use of Leftover Olds Parts...
- Coolant Radiator on 68 rocket 350
- '55 Headlight Switch Generic?
- Salvage Yards SE Texas, Houston
- 1968 Oldsmobile Toronado
- 72 442 Fender Emblem placement
- hurst interior
- 65 442 value
- Ignition Lock Cylinder Replacement
- Rocker Arm In Up Position with No Pressure on Pushrod
- 55 olds windshield sedan, hardtop difference
- Anyone near Tigard, Ore ?
- ohh the humanity!!
