is it pinging
Old Mar 2, 2015 | 10:37 AM
billmerbach's Avatar
major noob
is it pinging
Not sure if I tested it correctly but my timing tab comes in tomorrow afternoon but it has to be driven cause dad needs to go to the bank I did it best I could by ear the only noise I hear is what I believe to be my exhaust echoing back since it is right under the cabin which needs to be fixed
Old Mar 2, 2015 | 10:45 AM
Pinging is usually heard under light throttle going up a hill. It will sound like marbles bouncing around in a tin coffee can. Another indication of over advanced timing is the engine cranks erradic and much slower when hot than when cold, feels like its trying to overcome a lot of back pressure.
Old Mar 2, 2015 | 10:51 AM
major noob
So my little video holds no evidence? And I cranking is pretty consistent I say I guess I'll just avoid hills tomorrow lol
Old Mar 2, 2015 | 10:58 AM
If your on a hill and witness pinging, decline your timing a tiny bit when you get home. Then when you get your timing tab installed you can set it correctly at that point. Recommended posted timing settings are a guide not gospel. Some engines run better with more and some with less.
Old Mar 2, 2015 | 01:11 PM
major noob
Went up to my neighbors as he has flat ground for a transmission gasket and filter change and I heard a rattle but it wasn't metalic or high pitched
Old Mar 2, 2015 | 01:15 PM
major noob
I feel it should make it tomorrow till I get the tab and can dial things in
Old Mar 2, 2015 | 01:24 PM
rocketraider's Avatar
Oldsdruid
You generally won't hear pinging unless engine is under load, like going up a hill or you're holding the brakes and accelerating.
Old Mar 2, 2015 | 02:25 PM
m371961's Avatar
One way I used to set timing back in the day was to powerbrake the car. Hold the brake tight, put it in drive and slowly accelerate. If it is going to ping, you will hear it.
Old Mar 2, 2015 | 03:07 PM
Macadoo's Avatar
I have found the work "ping" to be somewhat misleading. It's not that high-pitched. Like Eric said, marbles in a tin can. Or even gravel in a can. You'll hear it if it's there. Makes my skin crawl!
Old Mar 2, 2015 | 05:16 PM
76olds's Avatar
Hookers under Hood
X2 here, that's the way I set my timing.
My marks are way out to what my engine likes after distributor curve. The light is of no use in my case, As Eric and Mac said marbles in a can sound will be noticed.
oldsmobil
Nov 12, 2012 07:19 AM
defiant1
Aug 8, 2011 03:27 PM
69442
Aug 1, 2011 07:04 PM
Wyze
Oct 13, 2010 06:36 PM
woodie582
Oct 25, 2008 10:29 AM
