- Warehouse fire destroyed my 1967 Cutlass
- Has anyone else seen this?
- 330 or 394
- for all Southerners
- Bad th350 kickdown cable ?
- Might need new hood insulation, recomendations?
- Vintage NYS license plates question?
- 1955 Super 88 conv.
- 1971 Oldmobile delta 88 **Original**
- 72 Cutlass S window regulator ques.
- 1970 455 F Block
- Discovered a couple of tricks this weekend.
- Thought it blew up!
- in response to 89 307 Y
- NTX Speed & Machine. Has anyone had dealing with them?
- autotrader.com popups
- 67 production start date
- Exhaust Condensation
- 1958 fiesta station wagon
- 1974 Hurst Olds Body Panels Interchangeable?
- 1970 2 dr wagon
- Engine harness interchangeability
- Best chromed parts storage practice
- 1956 olds 88 seats
- Chrome Intake Manifold Bolts?
- Sport Steering Wheel Question
- fuel pump failure
- Odd looking car in HMN
- 250 motor questions
- Wiper motor 71 cutlass supreme
- Radio replacement
- after a year of searching finally found my 69-72 A-body donor car w/ stock disc
- Ok I have a Mystery Wire i Need Help With
- Reproduction W-30 Red Fender Wells - Fillers - Liners
- 2bbl 2 4bbl swap make a few more horses
- seat belt tags
- Dealer Invoice 1969 Cutlass Holiday $4295
- Harrison Radiator Numbers
- 73 442 olds question
- Here's Why Putting a 70-72 Hood On Other Years Doesn't Work
- I said goodbye to my W-30...
- My Valentines Day :D
- Inside Hood Latch Release for 66 442
- Tire Size Calculator
- engine assembly lube....& pre lube question
- 1965 98 4dr
- 65 442 Post Parts Car
- 1967 442 Convertible crossmember brackets
- Restoration?
- 1967 Toronado Outside Mirror
- How many cu. in. 455 .040
- Dr Oldsmobile decal
- How to ship heads?
- 1968 400 2 barrel (Turnpike?)
- Sid Caesar
- 66 cutlass wiper motor decal
- What Model do i have?
- Anyone in Nashville area able to look at a car?
- Toyota to recall 1.9 million Prius hybrids
- What the earth giveth, the earth taketh back
- 455 over bore
- 400..sell or keep?
- 455 boat engine
- Electric trunk release
- Tachometer Bench Test
- Anyone else have this option? Pulse wiper on shift handle.
- Quick 350 rear seal question
- Body Mount Pads - 67 Toronado
- Question?
- Carb Numbers
- 1967 Toronado Throttle Cable Needed...
- aka Mega-Tron CL ad
- 70 442 DVAP build
- 82 olds 98
- N.A.I.A.S. pics
- Motor Mount Heat Shield? New Format on CO??
- Cowl screen and rubber
- Hubcap ID's Please/
- 70 Aluminum water outlet anomaly? Have you seen this joesw31?
- Heard this today, made me chuckle
- 64-69 manual console application question
- A little too much chrome
- Olds 455 timing
- Type o rear end fit?
- 1988 Cutlass Calais SSC?
- Difference between outer and inner tie rods
- Feedback on wheel choice - Hurst or Wire Spinner
- What's Mine Worth
- w-30 p c v fitting
- Car insurance
- new thermostat on 64 Olds 15 Min. On 2000 silloette 4 hrs
- Cowl Tag decode
- All Girls Garage
- What do you know about these people? Gateway
- Safety Sentinel Speedo
- Trunk torsion rods
- 455 Cam Help!!!!
- CITGO Vintage Oil Recycling Kit NOS Sealed - $10
- Help with Matching numbers
- Glass beading question??
- Robert Powers Motorsports
- elec. problem
- Just another reason to appreciate driving an older car
- Yard cars
- 455 Cam Help!!!!
- What is it worth
- 69 442 wood dash trim ???????
- In search of the cool factor or maybe not
- Is this for real? 1968 Olds 442
- Rear glassl
- Question about parts place bumpers
- What parts need to convert 70 ht to a 72
- Help w/ part number
- Car Transport
- Bandit buyers beware!
- The REAL Miss America
- 1969 442 Cowl Tag Decode
- Mediocre Driving Skills
- Window channel kits (fuzzies)
- Ready to buy - what would you choose?
- 59 olds 98
- Back in Black is complete : )
- 1970-72 Cruise Cutlass Cruise Control Questions?
- 69 holiday coupe front clip
- photobucket
- Name these cars!
- 68-72 Jack Cradles
- how do i adjust my valve?
- My Cutlass replacement - '79 T/A Anniv Ed
- buying tyres onlinefrom australia- best options
- article about oil
- 70-71-72 trunk lid differences
- sluggish driving
- Why did they go 15" tires to 14'' tires?
- Steering column shaft question.
- 64 Cutlass frame swap
- OPINIONS? What would you do?
- How do you place pictures in the body of your post?
- 1971 442 Cowl screen fasteners
- Ugh - turn signal on my 62...
- 1950 rocket 88 engine number
- Voss Olds
- 1967 442
- 68 W30 fan shroud
- 65 Vista Cruiser Info needed
- Rear end gears for a vista cruiser
- Boneyard pix - HMN Flikr shots
- a/c car with 342s
- top inoperative
- trim rings n o s vs repos
- exhaust question
- 1959 olds 98
- What kind of oil do you use????
- Factory bucket seat width ?
- 70 Hood on a 72
- master cyl.
- 1966-67 bbo q-jet divorced choke rod
- Build Date
- Radio Issues
- Why don't people fill out the statistics page?
- what oil is best
- 70 cutlass, 455 headers
- Best quality points
- Air Gap & Holley 1050 CFM (Quick Fuel) fitment for OAI W30 hood
- My DVD's made front page on hot rod online, thanks diego
- help with figuring motor in 78' delta 88
- My New 70 442 is Smaller than my First one
- 2014 Nationals
- 68/69 HO Head ID
- Why I don't always buy NOS
- 62 Parisienne Distraction
- From 442.com (FAQ)
- UK. Buyer for my 1960
- '64 rear spring retainers
- Decode Help
- Can a Bucket seat head rest be painted or dyed?
- Rockauto 5% discount, good through 3-31.
- What are these out of???
- Pro or Con: Replace distributor with HEI?
- 1949 Oldsmobile Pick Up Custom
- Road salts- the bane of my existence..
- Jack Restoration
- 67 Cutlass supreme body moulding clip
- posting pics
- Inner fenders
- Looking for my first Olds, What is best? What to avoid? All advice is appreciated
- Changing Headlights (Then vs now)
- Hot Rod Scotts anyone ?
- Newly acquired 68 442
- Low mount power steering bracket
- leakdown test results, strange?
- One of One
- how to get a piston TDC?
- Larry Camuso/West Coast Classics
- Advice needed on Front Brake Items
- Cool old pickup...
- Need a little help with modern climate control
- summit pcv baffle
- Trunk Divider/Insulation
- 1975 H/O air cleaner color/type
- 1981 Color Code 69 Dark Sandstone Metallic
- '72 center console in a '67?
- 1949-1950 Engine serial numbers???
- water pump ?
- Central Ca. Swapmeet this weekend
- 1968 Delmont 88 4 door. Is the frame the same as a 2 door?
- I would like to install a posi rearend...
- YouTube and Paranoia
- Help Locating Reliable Mechanic
- New Convertible top time for 71 Cutlass
- 1964 Dynamic springs
- W30 hood question
- What's New but Olds looking???
- Correct Hydramatic color
- New Arrival 72 442 Not Mine
- The ClassicOldsmobile Chat Room-Let's Chat Boys
- 14th Annual Groundhog Gala Hot Rod and Custom show
- vinyl roof in 1964???
- speedo not working
- What's mine worth and is anybody interested??
- Interior lights
- Heated seat recommendations
- Olds Hemi
- Hood Doesn't Raise Very High
- Post your "Back in the Day Pic's"
- valve covers and edelbrock heads
- My newly aquired 69 442 3 speed convert
- 455 Countach
- Restoring Hubcaps
- 69 442 back drive parts.
- Steering column
- 70 blue interior paint
- ATTENTION: 67Olds442X2 Kyle's 77 Cutlass Tedd Thompson slantflat crzyjef
- Hidden electric fuel pump and line install....
- 1965 Oldsmobile 98 four door sedan
- Changing transmission fluid on a 56 Super 88
- Spacer for power steering pump bracket?
- 67 W30 "barn find" to be sold.
- Cowl Tag Decode again
- 455 radiator
- Opinions on value
- Best times
- barrett Jackson 270k 79 h/o olds
- OAI Air Breather Question
- Government Opening Free Gas Stations in Poor Neighborhoods
- '70 Azure Blue W-30
- My mistake?? What is your opinion?
- Body Tag Decoding
- Barrett Jackson Scottsdale
- 70 Cutlass radios, What am I missing???
