View Full Version : General Discussion
- 1968 delta 88 custom :missing rear yoke ?
- Larin Engine Test Stand
- 1984 hurst olds sequence number
- Can someone confirm this as a '67 Olds axle?
- Steel Valve Covers - Thoughts?
- How should I handle this?
- water pump pulley
- Locking hub cap problems.
- And the ugliest Chevy award goes to....
- What kind of Olds is this?
- Parts Place Steel Frame Hood 1970
- 1964 ninety eight
- Air Conditioning for 1965
- Big Block Olds In Cheby A Body
- not olds but damm,why can't i find deals like this
- Radio delete on 84 hurst
- W-455 intake production time frame
- SUV price???
- Are there higher quality Motor Mounts available?
- What alternator bracket will fit on an air gap intake?
- New Ride
- '70 Olds 442 Seat Belt Release Tin Plaque
- Inflatable Seat belts?
- Oldsmobile radio ad, late 1963
- Replication of Window Sticker
- My former mechanic needs HELP (not him ME (just kidding)
- one of those tic tach toc gauge watches
- That'll Buff Out
- Alas, things change...
- $245 Dollars??
- 1972 cutlass supreme
- 1968 Cutlass wagon fuel capacity
- olds 213, has anyone installed a modern transmission on a 213?
- Hopefully going to look at 87 442
- The '70s called...
- 70 cutlass headrest
- best cover for outdoor storage
- symtoms of a bad torque convertor
- Going rate for 3:91's
- Post Photographs of Dealership Items
- alternator bracket part missing
- Odd control arm
- ID a 455. Interesting lower pulley?
- 70 Assemby Manual
- 4/22/17 NTOC Zone show pictures, members feel free to ad more.
- Iron Battens before vs after!
- Which car? Choose only 1.
- Ram air cleaner base
- Best Way to Remove Metal Clips from Arm Rest Chrome Base to Door Panel
- Stuck valve caps
- What year mid-80's 442 had an option of white?
- Shot in the Dark
- CAR & TRUCK Guess who won.
- Jetfire vs Cutlass Air Cleaner Pie Pan
- Upper radiator hose
- Which power steering hose is correct?
- Car Transport suggestions
- Bon Voyage
- Dupicolor Gold engine enamel is a good paint remover
- Rocket man
- Bbo heads on 307??
- Cottage Grove Oregon
- What are your thoughts on a place like this?
- Sport mirror rebuild
- Amazing Artist
- Wheel/Tire size, again. Going for a certain look....
- Free stuff at Carlisle Spring swap
- 70 W30 convert at mecum
- Classic Car Insurance Restrictions
- '63 Starfire Dealer promo?
- Roadkill.com - Nicky Flores’ Old-School, Olds-Powered ’31 Ford Cabriolet Hot Rod
- Opportunity to buy a pair of 68 Toronados
- low milage wagon
- Anyone in close distance to Chicago? Any meets in the area?
- Taking Cutlass/442/Hurst Olds Parts Requests
- New Shoes on the Cutlass
- 1978 98 radio removal
- Differential questions
- 1968 442 Production numbers
- Power brakes booster lag
- Vinyl Adhesive Suggestions
- Can someone help me identify an Intake Manifold?
- 70 442 conv rear body panel
- Information on 1970 442 W-30
- Car show pics 4/15/17
- Backup lens polishing advice needed
- My Gear options?
- 5, 3/4 = 5x127.00?
- Barn find?
- If you could get another Olds?
- 65 rear axle question
- 1970 442 going in for paint
- silly question
- Wheels Day. Aldershot, England, 04/14/2017
- Double hump cross member 68-72 ???
- Spring Carlisle Swap Meet
- May be selling my '69 Cutlass for a 4 speed '70 Cutlass W-31
- Any experience with Classic Exhaust Inc?
- 1965-6 Cutlass turn signal switch help
- Tail light restoration
- What were the correct exhaust manifolds for a 1970 Olds 98?
- Vista Cruiser Cowl Codes?
- 840 HP and 770 Ft-Lbs
- Bad Vendor - Shockwarehouse.com
- Tennessee Classic Car Insurance
- 68 442 Window Crank Part Numbers
- 1954 100% correct STUDEBAKER
- Replacing Clock with 3 Sunpro Mini Instruments- 72 Cutlass
- Five-on-the-tree maual trans
- Northstar experts, need advice
- Rear disc brake conversion from LS
- I need a Chevy 302 expert
- How to interpret car ads
- Block casting
- Picture Appreciated
- 'Best Custom Classic'. Our 1st trophy.
- never seen this decal before
- Convertible top purchase
- It's the End of an Era for me, literally
- 1970-1972 Original GM Grilles versus Reproduction Grilles
- I don't like crack
- I purchased this AC fuel pump yrs ago.
- window sticker for 1984 Cutlass
- Cupholder Ideas?
- 66 dynamic starting 3rd time around
- Odd 68cutlass?
- Quad 442 in a wrecking yard
- Dual Exhaust
- Adjustable driveshaft?
- Canfield Ohio Meet
- Any Wa state members going to the car show next weekend 4/15/17
- 77 cutlass rear bumper
- Trumpet Tips for 2.5" Tail Pipes
- Question about Olds Custom Cruiser
- heater box control cables
- SSII & SSIII Wheels
- 68-72 Wiper Blade (Refills)
- I need some help, anyone in the San Francisco area?
- Classic olds cars
- What bit did ya'll use
- FUEL / BRAKE LINES/ a body 72 cutlass
- My restoration
- Does anyone have my old 442?
- What is wrong with people
- Bravada? To be or not to be.
- 2000 Intrigue won't start
- Strange truck
- Olds 350 fuel pump issues
- House For Sale . . . . . . With Cars
- Cutlass supply seems to be drying up
- Trunk lid
- Long chevy
- Anyone live near Plaistow New Hampshire
- Harmonic balancer bolt torque.
- How the heck does this happen (Pt Deux)???
- powemaster starter motor ??
- engine building 1969 olds 350
- Never seen this option before, 1970 Cutlass trailer hitch wiring.
- Oldsmobile Homecoming in Lansing
- New toy. Leave bare or add emblems and wheel well trim?
- !971/3 Quadrajet Question
- 72 Cutlass turns over, won't fire
- fuel line
- Found it!!!
- Not selling the cutlass
- 455 parts weights
- Modern Factory Drag Car?
- Need oil filter adapter expert:
- Cruise Control Issues
- Bridge falls in atlanta
- A C help not olds
- Anyone in the Redding CA area?
- 1985 442 motor swap
- GBody wiper arms
- Question about Correct Vacuum Hoses on 1972 350 Engines
- 86 cutlass supreme no reverse!
- Buick fans
- Broadcast cards
- Ceramic Cast Iron Coating Exh. Manifolds
- 1970 Cutlass, 1971 Supreme - $1.45M Cdn?
- 9 car hauler
- OPGI anyone have trouble with their service?
- 30th annual Coming out Car show
- Is this Carburetor salvageable?
- Swap meet in Portland Oregon, April 7-8-9
- Crank: Trash It or Worth It To Somebody
- 72 Cutlass Supreme Rear Bumper. Who has a source for new one?
- Headers or stock manifold?
- Thermostat housing
- 1955 Olds 98 exhaust inquiry
- Ethical issue?
- 1971 Cutlass Production Numbers
- Rims question/feedback
- Any members from Fort Myers Florida?
- Interior Manufactures
- How the heck does this happen???
- 1970 dash paint color
- No more points!
- 1970 442 body mounts
- Driving a Boat 67 Cutlass
- Dual Gate installed
- Cad plating cost
- 1972 Cutlass
- US buyer protection?
- Mechanic
- delco battery y71
- Maybe There Is Hope Yet
- 46 years old and still mine
- Will Bleach White damage the paint?
- Does anyone sell individual sets of window felts?
- Here are some (mostly) clean ones!!!!!!!
- Deck Lid trim
- Speedometer cable
- Advise on Car Tracking System
- Rag joint
- Anybody know what these are called?
- Values
- ss1 center cap question
- not Made in America
- Wheeler Dealers is losing Edd China
- car hauler winch ???
- And the Service Manager said...
- Has anyone ever seen these wheels
- Converting to 134A? This is the deal you have been looking for
- YOM Plates for Daily Driver Use in Virginia
- How many Oldsmobiles have you owned?
- Whose Oldsmobiles are shown on the site banner?
- Has Spring Sprung in Your Neck 'O Woods?
- Ebay 70 CS vert
- 455 mild rv cam profile
- '57 Olds two-seater custom
- Hot Rod run Australia 2017
- What's it worth, as is (for the brain trust here).
- Buying 'used' Intake
- Plastic bag for owners manual
- Who's going to the Daytona spring turkey run ?
- Looking to determine value of parts
- Recommendation for car lift
- Wanted 70-72 memorabilia
- Recommended Olds Literature?
- Brake shoes '70 Cutlass 4dr
- call engine bay stamps
- Ported or manifold vacuum advance?
- "You can't have too many toys" I just added a 1969 Vista Cruiser to my clutter
- Should i part or sell whole
- Fuzzies
- 70 chrome louver hood
- Anyone going to the Nationals in NM?
- 1964 Cutlass; Recommended Fuel Tank Source?
