delco battery y71
Old Mar 24, 2017 | 04:09 PM
Bob 442 PC's Avatar
delco battery y71
I have been getting some restoration work done to my 1970 442 conv. I was looking at parts gathered for this and came across an NOS never had acid or water added Delco Energizer Y71 battery. Does anyone know what cars this fits and how rare it is. Has it much value? Date code is M21 1
Thanks for any info
Bob
Dimensions for the battery are 12 inches long, 6 5/8 wide 8 inches high.
i think it may be for a full size gm.
NOS Delco Y71 label
NOS Delco Y71. Date code M21 . additional 1 located near eye.
NOS Delco Y71 battery
can someone identify this tatto discovered on the turbo 400 after cleaning.
before.....
after.....
Old Mar 24, 2017 | 04:52 PM
Can't answer your question, Bob, but I just wanted to say welcome to the site!
Old Mar 24, 2017 | 07:31 PM
Can you post a picture of the battery, the box if any, any labels, and the dimensions.
Old Mar 24, 2017 | 10:17 PM
stevengerard's Avatar
I'd recommend this , new battery that looks old
http://www.restorationbattery.com/r71s.html
Old Mar 25, 2017 | 05:44 AM
Bob 442 PC's Avatar
Thanks for the welcome. I should have joined 30 years ago. would have saved time on research.
Bob 442 PC
Old Mar 25, 2017 | 05:51 AM
Bob 442 PC's Avatar
oldcutlass, I have added the info and pics to my blog. Hope this unlocks the mystery.
Old Mar 25, 2017 | 07:11 AM
Happy Trails's Avatar
It was neat to see your battery. It looks similar to the reproduction battery my Dad purchased for his car, but his 1972 car has side posts.
Someone had a few of these and was selling them on eBay Canada last year for $159. Here's a link.
Wild about Cars had some info that popped up related to 1971. Here's a link to that.
The Wild about Cars site might be a good place to poke around and find out some more about that battery. Thanks again for posting the pictures. It was neat to see a NOS battery.
Old Mar 25, 2017 | 07:59 AM
OG is the standard trans in a 442 in 1970 should be on the data plate as well with
70-0G-XXXXX
With the X's the tranmission production number
Old Mar 25, 2017 | 08:18 AM
I thought we were talking about batteries.
Old Mar 25, 2017 | 08:29 AM
In the middle of the pics he posted (added later) he asked about the code OG on the transmission
So he hijacked his own thread - not me
Old Mar 25, 2017 | 08:49 AM
The Wild about cars link above is pretty handy with a lot of info.
http://wildaboutcarsonline.com/membe...e_pg_39-66.pdf
Old Mar 25, 2017 | 09:29 AM
Bob 442 PC's Avatar
Sorry. I'm new to this forum and had initially posted on the general discussion thread. Did not realize that it would cause a problem. I will try and tighten up my skills and do better.
Thanks to all of you for your time and effort on this topic.
The links from Happy were very helpful and the trans question I sneaked in was great info from Steven. I would like to ask Steven, do all the 442 trans have this odd marking on the side? The people I dealt with seemed surprised or just pulling my leg.
Thanks all,
Bob
Old Mar 25, 2017 | 11:00 AM
From what I know most trans had the code painted on the top like that. Though I have only seen it on one of my cars. Though that doesn't mean it wasn't there originally and was removed when cleaned or painted over. Your trans should have a tag on it as mentioned riveted on the passenger side. There is also a VIN derivative stamped on the trans case as well on the passenger side as well
Old Mar 25, 2017 | 11:15 AM
Bob 442 PC's Avatar
Thanks again. This was very helpful. Now I know that it came from GM is great. It just looks odd.
Bob
Old Mar 25, 2017 | 12:01 PM
Hairy Olds's Avatar
Shoveling Snow
The correct replacement battery would be a R-71 group 24 battery. The Y-71 will work in a pinch but not suggested and less valuable. Can you pull back on the trans marking and submit a photo of it. All of the marking's on the transmission I've seen are black for 70.
Old Mar 25, 2017 | 01:43 PM
I've seen orange, eiter way I figured this is either gold paint or another color faded/changed with age
Old Mar 26, 2017 | 11:33 AM
Sorry, missed that.
Old Mar 26, 2017 | 01:02 PM
VC455's Avatar
Barely Registered
That is correct.
The Y (yellow) series of Delco batteries from this era had lower Cold Cranking Amps and lower Reserve Capacity than the R (red) series. Otherwise if the number after the letter were the same, they were the same external size.
i.e. the Y-71 and R-71 would be the same physical size, but the R-71 would have higher electrical capacity ratings.
Oldsmobile factory batteries were R series; the Y series for our cars was available for lower cost in the aftermarket.
Some lower-priced GM models used Y series from the factory, particularly on smaller, non-v8 engines.
Old Mar 27, 2017 | 07:48 AM
Bob 442 PC's Avatar
Thanks all for the info I received. It answered a couple of questions. I don't have a better picture of the tranny . The colors of the marking are gold and black. I am pretty sure they are legit since I have owned the car for 46 years and know the history. I find it odd that it's not on all the 442's.
Old Mar 27, 2017 | 09:45 AM
mrolds69's Avatar
The battery in the first post is Delco aftermarket. It IS NOS, but be aware they never left the factory with that sticker on the top. I'm not too sure about the yellow paint, I'm pretty sure that was an aftermarket thing, too. One interesting thing to note is th"EYE", 2nd from the + pole. That's the exact right place they were originally, although I'm not sure exactly why. The OG tranny was used in other years of 442, also. My 69 442 has an original OG tranny. Finally, I like the repro batteries...not the acid ones, but the gel or AGM type. I've had good luck with them and you never have to worry about the acid getting on your core support again!
1970VistaCruiser
Sep 15, 2013 04:58 PM
Texas442
Mar 28, 2013 07:13 PM
Hairy Olds
Sep 3, 2012 02:11 PM
w-30dreamin
Jan 9, 2010 03:19 PM
68Tom
Mar 20, 2009 08:50 AM
