Rocket man
Old Apr 19, 2017 | 08:11 PM
Rochet man's Avatar
Rocky Mountain Olds
Rocket man
I finally made it in! I have a 69' 442 with AC. The AC doesn't work and I don't plan on restoring it at this time.My question is how do I get cool air vented into the car? I don't have vent windows or kicker vents either. I did slide the **** on my heater AC selector to vent and temp to cool but I'm not getting any air through my dash vents. any ideas?? thanks....
Old Apr 19, 2017 | 10:08 PM
Originally Posted by Rochet man
I've tried selecting vent on my temp controller and setting it to cool but I'm not getting any air through my dash vents.
Is there air blowing from the floor or defroster vents? It may be that the vacuum reservoir on the firewall is disconnected. It's a round ball in about the center of the firewall behind the engine. It should have a vacuum hose connected to the intake manifold and another going through the firewall to the AC blend door under the dash. Many times the hose from the intake manifold to the vacuum reservoir is removed for whatever reason.
Old Apr 20, 2017 | 02:55 AM
I deleted your duplicate post in the newbie section. Post a proper intro in the newbie section with some pics when you get a chance.
Old Apr 20, 2017 | 04:50 PM
Rochet man's Avatar
Rocky Mountain Olds
Thanks, I don't have any floor vents. I do not see a vacuum hose coming off the manifold but I bet that's it. I need fresh air, especially this summer.
Old Apr 20, 2017 | 04:53 PM
Rochet man's Avatar
Rocky Mountain Olds
Hate being the newbie! Thanks for cleaning it up
Old Apr 20, 2017 | 04:57 PM
What I mean by floor vents is there should be vents under the dash for the heater and they blow down towards the floorboards. When vacuum to the HVAC control is lost, the air blows out of those lower vents instead of the upper dash vents.
Old Apr 20, 2017 | 05:06 PM
Rochet man's Avatar
Rocky Mountain Olds
I do have the vacuum hose coming out of the manifold going to the vacuum reservoir and a hose through the firewall. it seems to be hooked up
Old Apr 20, 2017 | 06:33 PM
You may want to make another account, unless you really wanted to be Rochet Man.
Old Apr 20, 2017 | 07:04 PM
Rochet man's Avatar
Rocky Mountain Olds
Haha....lost my glasses, good advise Thanks
Old Apr 14, 2018 | 10:10 AM
Rochet man's Avatar
Rocky Mountain Olds
How do I post pictures?
Old Apr 14, 2018 | 10:54 AM
https://classicoldsmobile.com/forums...-pictures.html
Old Apr 14, 2018 | 11:34 AM
Yellowstatue's Avatar
Although your A/C system refrigeration doesn't work, your vacuum controlled flapper doors must be operational to achieve summertime comfort.
Old Apr 14, 2018 | 03:19 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Agreed with Mr. Yellow'. Best bet is to get the shop(s) manual(s), AIM (assembly information manual or assembly manual) Fisher Body manual and all the other manuals available for this car. You need to see the HVAC schematics showing the vacuum and electrical systems. It will show the location of the vac lines and the blend door actuators under the passenger side kick panel etc...Once you get the vacuum working you can go through the rest to see whats not working. And you will have the info for when you restore the rest of the AC system. At least two vendors have the parts and service support for most of that system. Vintage Auto Air and Classis Auto Air. Log on to Wild About Cars dot com, info there as well.
Upload some pics.
Octania
Apr 21, 2015 05:14 PM
delmontcrusier
May 7, 2012 04:01 PM
Ranmat
Apr 4, 2012 07:18 PM
jaunty75
May 26, 2011 09:03 AM
stinger
Sep 15, 2008 11:41 PM
