Rocket engine/tranny saved from the Junk man
Old Aug 10, 2008 | 07:48 PM
stinger's Avatar
I was at the local metal recycler the other day and saved an Olds Rocket engine with cast iron transmission. We got CFD75 off the bell housing, and 563966 off the intake manifold, back left. To me it looks early 50'ish. Don't know much about car engines.
firing order is 18736542 Left bank is #1 from looking from behind.
My Question is what size is it, when was it made, and what does the car look like it came from.
Thanks!
Tom
Old Aug 10, 2008 | 09:56 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
55 or 56
Old Aug 10, 2008 | 10:08 PM
59-59-59's Avatar
Originally Posted by J-(Chicago)
55 or 56
How did you come to this conclusion since this number isnt listed in my '54 thru '61 parts number book???
Old Aug 11, 2008 | 04:10 AM
88 coupe's Avatar
Junior Member
Originally Posted by stinger
........ CFD75 ........ 563966 ........
Casting numbers. No use to me.
On the right side of the trans, there should be an oval (?) metal tag, with Hydra-Matic, above a stamped letter/number combo.
R54-xxxx would be a '54 Olds trans. It will also tell us where to look for the engine number.
Norm
Old Aug 11, 2008 | 07:58 PM
stinger's Avatar
I'll try a couple pictures. As I said earlier I don't know much about cars. I am into old tractors, gas engines, snowmobiles ect., just thought this looked to neat to get melted down.
Can anyone tell me about what year this is, what car it may be out of, and any other information that might be known about it?
Many thanks!
Tom
Old Aug 11, 2008 | 08:24 PM
redoldsman's Avatar
Proud Viet Nam Veteran
It appears to be 54-56 but I don't have anything to reference the numbers. If the batwing aircleaner is not pitted too bad it will be worth you efforts of hauling this thing home. They are very sought after.
Old Aug 11, 2008 | 08:35 PM
stinger's Avatar
Thanks redolsman! That's called a batwing? Thats a cool name for it. The air cleaner looks to be in pretty good shape with just surface rust.
Old Aug 12, 2008 | 05:02 AM
Oldsguy's Avatar
Past Administrator
I'll give you $50 for it as-is.
edit; the air-cleaner....
Old Aug 12, 2008 | 05:44 AM
It looks like a see a little bit of green paint on the back of the motor. Weren't 324 engines painted green in the 50s?
Old Aug 12, 2008 | 06:46 AM
88 coupe's Avatar
Junior Member
'52-'56 (and up) Air Cleaner. Not very efficient.
'54-'56 rocker covers.
'49-'60 fuel/vacuum pump.
'49-'55 (and most '56) single exhaust.
'52-up Trans dipstick tube.
From what little is shown of the trans, it appears to be a '54-'55 (and '56 Eighty- Eight only) “slant pan” Hydra-Matic. Could also be an optical illusion.
'49-'55 distributor.
All '54-'56 were 324, and the engine number began with a “V”.
Based on my doubt that anyone would replace a '56 distributor, with an earlier version, I am confident that it is not a '56, but, most likely, a '54 or '55.
Norm
Old Aug 12, 2008 | 10:09 AM
Oldsguy's Avatar
Past Administrator
Originally Posted by 88 coupe
'52-'56 (and up) Air Cleaner. Not very efficient. Norm
Yes, but they are beautiful. and I would like to use one on my '46 project.
Old Aug 12, 2008 | 08:33 PM
stinger's Avatar
Thanks for all the inormation fellas! I think I'll put it in the back of the the shed and forget about it for a few years.
If someone really needed it I could probably be talked out of it before I put it away. Also thought about ebaying the air cleaner but I think I'll keep it all together right now.
Thanks again!
Old Aug 12, 2008 | 08:48 PM
redoldsman's Avatar
Glad you saved it. I think you ought to sell the air cleaner to Oldsguy since it would go to very good use. Just think about some part you look for one of those old tractors and how much they mean when you find one. It would be perfect for his 46 project. If you put it in the back of the shed it is going to rust and then it won't do anybody any good. Go ahead, make his day.
Old Aug 13, 2008 | 06:07 AM
Yeah, hoarding doesn't help anyone out.
Old Sep 14, 2008 | 09:06 PM
Not a perfect information source, at all, but a lot of experience is on it nonetheless.
http://www.442.com/oldsfaq/oldsfaq.htm
Old Sep 15, 2008 | 01:31 AM
88 coupe's Avatar
Junior Member
http://www.442.com/oldsfaq/ofblk.htm...949%20-%201964
Where did you find the numbers?
Norm
Old Sep 15, 2008 | 07:17 AM
Oldsguy's Avatar
Past Administrator
Pleeeeeeeeeeeeeez
Old Sep 15, 2008 | 08:27 AM
Norm
Under the intake manifolds section I believe.
Old Sep 15, 2008 | 11:41 PM
88 coupe's Avatar
Junior Member
........ and 563966 off the intake manifold ........
Click here.
Norm
Octania
Apr 21, 2015 05:14 PM
oldspackrat
Mar 15, 2013 09:46 PM
archeryshooter
Feb 25, 2013 08:12 AM
delmontcrusier
May 7, 2012 04:01 PM
kmangsxr
Aug 2, 2007 08:30 AM
