Sport mirror rebuild
Old Apr 18, 2017 | 09:00 PM
csouth's Avatar
I have some sport mirrors for 71-72 Cutlass. The remote movement is very restrictive drivers mirror. Is this something that can be repaired fairly easily pulling them apart?
Old Apr 19, 2017 | 06:32 AM
stevengerard's Avatar
have you tried spraying some white lithium grease on there first before pulling it apart.
Old Apr 19, 2017 | 06:49 AM
dalilama's Avatar
I had a similar issue. I took a chance and purchased a set of sport mirrors with a seized-up drivers side. In my case two of the three control cables were frozen within the mirror housing. I was able to repair it by taking the mirror apart and soaking the collar/cable area where it was frozen in WD40 for a few hours and then grabbing the cable with pliers and slowly working the cable loose. Then silicone spray.
It's been a few years and the mirror still moves freely...
Old Apr 19, 2017 | 08:29 AM
csouth's Avatar
I have not tried that yet. Based in on how the mouting bracket looked, it may be a difficult task for white lith.
I have a penetrant I can try that has worked for me. If I can get it free, I'll lube it with the white lithium.
Old Apr 19, 2017 | 09:24 PM
csouth's Avatar
So this is why the mirror wouldn't move... When asked, the seller claimed "I pulled them from the car, tested and they moved..." Yeah right.... He gave me a partial refund. Soaking them now...
Old Apr 20, 2017 | 06:37 AM
dalilama's Avatar
Threw up in my mouth a little bit looking at that picture
It's still salvageable - good luck!
Old Apr 20, 2017 | 09:47 AM
At least it wasn't filled with living things!
Old Apr 20, 2017 | 10:20 AM
csouth's Avatar
Yeah, I almost sent him the pic to say "Are you sure this mirror worked?..."..
One cable is still stuck. I think I may just use it for now until I find a decent replacement. I tried to tug a little with needle nose, but I don't want to distort the cable too much.
Yeah, like a brown recluse or something...lol
Old Apr 20, 2017 | 10:46 AM
RocketDevo's Avatar
That mirror looks like something from a horror movie. lol
Old Apr 20, 2017 | 10:59 AM
dalilama's Avatar
FYI - mine was pretty frozen so I started with needle nose pliers but wound up using regular pliers in order to break it free after weighing my options (e.g., wallet). Yes, I mashed the cable braid a bit in the process but they are pretty beefy and I was able to compress it back into shape once things were free.
Old Apr 20, 2017 | 12:31 PM
csouth's Avatar
I'm going to try a little more pressure this evening. I'm worried more about putting a kink in the cable more than anything.
Old Apr 20, 2017 | 04:34 PM
csouth's Avatar
Firm tug with bigger pliers did the trick. Thanks for all help...
good to go now....
droptopron
Apr 28, 2017 06:06 PM
jonesolds442
Apr 13, 2016 01:38 PM
Oct 16, 2013 05:35 PM
stlbluesbrother
Dec 24, 2009 05:47 AM
Coltonis
Apr 24, 2009 06:15 AM
