PDA
View Full Version : General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. Toronado temp gauge
  2. Anti-Squeak tape for 1962 body panels
  3. 1966 Cutlass/442 front bumper value.
  4. L69 head stamped numbers- photo
  5. Question On Seat Belt Bolts - Why the Shoulders?
  6. Rally Pack Oil Gauge Erratic
  7. Chrome
  8. Clutch Shutter/Chatter Question
  9. 79 Oldsmobile Regency symbols
  10. 2020 OCA nationals rescheduled
  11. dip stick tube and stick
  12. Looking at a 1970 Buick GS455
  13. Where do you Install your Phone Mount?
  14. 1967 tape player questions
  15. Oai air cleaner
  16. 1964 Olds Cutlass holiday coupe resto
  17. 1970-72 442 and Cutlass AC vent ‘deflectors”
  18. 1971 Cutlass SX Body Tag Decoding
  19. 1971 Cutlass SX Body Tag Decoding
  20. 1975 w-25
  21. Hood storage
  22. 69 Cutlass rear bumper rubber fillers?
  23. Trunk Release Question
  24. 1967 Oldsmobile Cutlass Supreme 4dr
  25. strange Idea oil cooling?
  26. Olds Aerotech | Retro Review | MotorWeek
  27. 67 Power windows question
  28. Oil pressure light
  29. New Shop Build Questions
  30. 68-72 Cowl Section Differences
  31. R-12 to R-134A Refrigerant Retrofit/ Conversion
  32. What is it? 71 4-4-2....
  33. Cowl tag Decode ?
  34. carburetor size?
  35. Buyer beware or at least smarter!
  36. Armrest adjustment ?
  37. Which tool do I need to install my trunk springs?
  38. Fuel pickup
  39. How many Tributes out there?
  40. OAI hood pins - buy new or rechrome?
  41. Mondello
  42. Temp gauge flutters
  43. 10 bolt rear end
  44. Apologies to the members of this site
  45. Auto transmission conection
  46. how much oil
  47. compression ratio 67-400
  48. camshaft LSA
  49. Neutral safety switch or shift linkage?
  50. What Oil/Gas do you run in your Olds?
  51. 68/69 dash work
  52. Old Olds dealership???
  53. Locksmith help???!!!
  54. 442 valve covers
  55. Opgi fyi
  56. Count the Oldsmobiles
  57. Stripe/Stencil kit '70 Cutlass
  58. Need help FAST 65 442 clutch
  59. Kids & Cars
  60. Have you seen one of these and what years and models did they install on
  61. Proper black on 1966 442 trunk moulding
  62. Battery
  63. 69 Cutlass PRNDL ????
  64. 330 Timing chain
  65. MSD 8529 Timing for performance
  66. window rails and window separation.
  67. 1968 body part interchangeability
  68. '73 98 Side Post or Top Post Battery?
  69. rough idle and dark smoke.
  70. Broadcast cards
  71. Does anyone make a correct body mount kit for 65 442
  72. What's your Oldsmobile story?
  73. 1972 H/O Pace car promo film
  74. Speedo Troubles
  75. Can't find this carb????
  76. Coming back to life
  77. 1970 Olds Rallye 350 window seal Bracket?
  78. 1970 Olds Rallye 350 GAS Gage
  79. Power Steering High Pressure Line
  80. How many of you have quarter skins
  81. Homecoming 2020 Cancelled
  82. At least they got the stripe location right...
  83. Electrical Problem EFI Timing Control
  84. 58 olds engine oil leak
  85. Diff leak
  86. Do seats interchange?
  87. Home Coming
  88. Paint colors
  89. My 68 442 restoration
  90. No numbers on the block
  91. Rear speaker wiring
  92. Header Recommendations 68 Cutlass-461
  93. Installing Emblems 1970 pace car
  94. Chris Witt
  95. 1968 Bob Moore Oldsmobile Race Car Pic
  96. Exhaust set up for a 330?
  97. Pre bent rear brake lines 1966 442
  98. Welding practice
  99. 3M Machine Polish - 05996 Versus 06064?
  100. G Heads
  101. Oldsmobile Tornado Jetway 707
  102. Neutral Safety Switch
  103. convertible top hydraulic hose replacement
  104. ‘76 vs ‘77 cutlass supreme
  105. Radio Refurbish
  106. Fuel Tank Vent
  107. Olds steering wheel
  108. I know im Not the only one
  109. Quadra jet ID 1966 442
  110. Power Steering Return Line Hose Clamp
  111. 67 Power Seat
  112. Cup holders standard?
  113. Tri carb accelerator rod length
  114. Project Finished ( pictures )
  115. Suspension Bushes
  116. Would you use NOS heater hose?
  117. Tires and Rims
  118. Tri carb accelerator rod question
  119. door edge guards
  120. Here's my Buick wagon, and there's a reason I posted it
  121. Spark plug gap. 1972 Cutlass Supreme 350 4bbl. Stock
  122. Heater control (water) valve question
  123. 455 big block under hood temperature differences
  124. Leap of faith..66 442 purchase
  125. Best door hinge lubricant?
  126. 1970 442 Power Steering Pulley Alignment
  127. Bucket Seat Mounting Bracket differences
  128. 58 olds
  129. LED Headlights for my 83 H/O
  130. 2020 OCA Meet - Proceeding or Cancelled?
  131. Opgi inner fender wells
  132. The Gallant Men of Olds
  133. OCA National Judging
  134. Quarenteen car projects, what are you doing to occupy yourself?
  135. 1970 cutlass supreme break question
  136. Super 8 Emblem
  137. part number resource - 68 - 72 A body
  138. Interior Details: Vertical Windlace, Rear Quarter Trim, and Door Pillar Seal
  139. 1970-72 Cutlass / 4-4-2 headlight question
  140. ‘70 fender well restoration - how shiny is too shiny?
  141. Interesting License Plate Ideas?
  142. Olds F88 in the wild
  143. Straight 8 blocks
  144. Console gage question
  145. Battery died
  146. Some W Machine Nostalgia
  147. Power steering rebuild
  148. 91 OCC upgrade
  149. Whitewall tires
  150. Oldsmobile in the Wall Street Journal
  151. RockAuto.com Discount Code for Parts & More - Expires July 1, 2020
  152. Vacuum operated exhaust valve?
  153. Parts...
  154. Looking for 68-72 Oldsmobile Police Car Brochures
  155. Close-Quarters 1/2" Impact Wrench
  156. 1 month old granddaughter got her SS# today
  157. Steering box upgraded, rag joint ground missing now no horn
  158. Tri carb ad value to your car
  159. 1970-72 W30 W25 OAI assembly question
  160. 71 442 4 speed speedometer cable length
  161. Quarentine Convertible Top Help
  162. Car day
  163. Gauge v lite
  164. 1966 cutlass 442 d55 console code
  165. 1941 Ignition Switch Removal
  166. Vfn w25 hood ?
  167. How to find previous owned car
  168. To seal or not to seal
  169. Identifying a shifter.
  170. Check this out
  171. harmonic balancer
  172. 66 L79 versus W30 400 engine
  173. Front seats for a 67
  174. 65 clutch z bar bracket
  175. Build Week Question- 03E or 04A?
  176. W31 255s
  177. Oldsmobile Classifieds site?
  178. quadrajet id
  179. 68 442 Ram Rod!!!!!!!!!!
  180. Restoration
  181. M/T Valve Covers
  182. 66 data code, is this correct?
  183. Calgary World of Wheels 2020
  184. Can we just talk??
  185. Squeaky Carb (Bad CCV?)
  186. Asking price way too high ?
  187. Rock Auto users?
  188. Front disc brakes locked up, 1971 442
  189. Question about interchange between 1968 and 1970 post A-body cars
  190. dash pad removel
  191. Still Time to Take Advantage of These Rebates!
  192. Rebuilding 350
  193. 1970 442 In Dash Factory Tachometer Available??
  194. 1951 Speedometer noise and overreading?
  195. Replace 1 Piston
  196. Hurst dual gate part needed 1971 442
  197. 1970 Oldsmobile Rallye automatic exchange
  198. Ultrasonic Carb Cleaning
  199. Hood latch wear?
  200. Back when Fel-Pro cared
  201. Are people happy with Guide T-3s for current needs?
  202. Anybody here cut up a parts car?
  203. Quadra jet air door adjustment
  204. 2020 to do list.
  205. Anybody have a car purchased new at Halladay Olds Cadillac in Cheyenne Wy?
  206. It followed me home.
  207. anybody deal with ecanopy before?
  208. 1951 88 Steering Column Shifter ANCHOR RING
  209. Rescheduled Spring Carlisle
  210. Tool box
  211. 1970 W-30 all over the internet..
  212. Leak from the oil pan drain plug
  213. 70-72 Tachometer BL00570
  214. Cool Olds 72 Wagon Never seen one..
  215. Three deuce setup on a 66 and a 57-58 Old's
  216. Definition of barn find....
  217. Linda
  218. Retro Radio
  219. 65 jetstar
  220. Trunk Divider Installation
  221. Worst Gas Mileage Ever
  222. 68 442 turnpike cruiser info
  223. Static Kling someone smarter than me...
  224. What's Wrong With This Picture ? LOL
  225. While you are stuck at home
  226. transmission temperature gauge install
  227. When the Smothers Brothers raced from Massachusetts
  228. grill for 1983 cutlass brougham 4 door sedan
  229. Battery Question
  230. 1967 442 undercarriage
  231. does anyone know the difference between rad support bushings?
  232. 1970 Quadrajet Tee Fitting Plating and Color Question
  233. Went and looked at a 72 H/O today.
  234. 66 67 Vista Cruiser NOS Quarter Panels Info Needed
  235. Made the Show My Classic Car....Well in the back Ground that is.
  236. Any Left?
  237. Is this a real 442 or clone?
  238. 69 Oldsmobile missing parts
  239. 1969 Cutlass Overflow Tank Cap
  240. 71 W30 Hardtop Johnny lighting Toy car
  241. Drum brakes
  242. Decoding Bad fisher plate
  243. What color should this bracket be?
  244. Not a Show Car, But A Little Show Off
  245. Old faithful battery died
  246. 442 Stood for Many. Things, According to Hemmings
  247. OCA Pacific Southwest Zone Meet May 1, 2 2020
  248. Restoration Shop Reported Customers Cancelling Builds
  249. Where's Winn?
  250. Dome Lamp Base/ Housing w/ Map Light Lenses
