Rebuilding 350
Old Mar 25, 2020 | 06:05 AM
Bigsal510's Avatar
Rebuilding 350
Hello all, I'm rebuilding my 350, trying to get the most HP with out breaking the bank, any suggestions?
Old Mar 25, 2020 | 08:15 AM
Sugar Bear's Avatar
Completely understand not wanting to break the bank...what year/model is it going in, what transmission, what rear axle ratio? Will it be driven often on the highway?
Unless it needs a rebuild, you may get more for your money through a transmission replacement or axle ratio change.
Good luck!!!
Old Mar 25, 2020 | 08:19 AM
Bigsal510's Avatar
Its 1968 convertible all stock
Old Mar 25, 2020 | 08:27 AM
Sugar Bear's Avatar
​​​​​​68 vert, very nice.
Two speed or three speed auto? What are the letters in the bottom of the speedo PRN___? Does it shift once or twice? If it is a two speed auto a lot can be gained with a different transmission. This is all if the 350 doesn't need a rebuild, if it needs it then it needs it.
Good luck!!!
Old Mar 25, 2020 | 08:44 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Do it in steps:
What are your performance expectations?
Step 1. After teardown & inspection, do a stock rebuild with a mild cam, degreed properly, Intake port matched to the heads, head port clean up with a good 3 angle valve job. Refresh the QuadraJet, distributor and fuel pump. Use a machine shop familiar with Oldsmobiles!!!!
Step 2. TH350 trans? If its the stock ST300 Junk Away consider an upgrade to a TH350 or a properly built 4 speed TH2004R. Rebuild the trans with a TransGo shift improver kit and an adjustable modulator. TCI clear synthetic trans fluid.
Step 3. Consider a 308 or lower rear gear. It likely has the 2 series gears. This is where you will see all the modifications come together.
Keep in mind the cooling, fuel and exhaust systems will need upgrading/rebuilding/replacement as well to handle the new mods. Don't forget you need a solid chassis and braking systems as well. Let the MAWs commence!
Old Mar 25, 2020 | 09:50 AM
There were two versions of the 350 engine available in that car, a 10.25:1 4bbl and a 9.0:1 2bbl.
As already asked, does the engine really need a rebuild or is a rebuild something you want to do just because?
Adding a third (or fourth) gear to a vehicle with a 2 speed transmission is a huge performance gain, as is changing the rear gears from the typical 2.56 to something in the 3.xx range.
My first car was a 1970 Supreme 350-4bbl (same engine as 1968) and swapping the 2.56 rear for a 3.08, then later a 3.55, made a world of difference in performance. A cam upgrade, headers, and a bit higher stall torque converter made it a really fun car to drive on a daily basis (school and work).
Old Mar 25, 2020 | 10:12 AM
Bigsal510's Avatar
As far as l know the trans is a TH350, and also l have a warped head, l was thinking of getting some aluminum heads.....
Old Mar 25, 2020 | 01:33 PM
Be aware the aluminum heads are made for big blocks and therefore have larger combustion chambers and intake runners. It will take some modifications to use them on a small block. Do more research before you spend money.
XTREMEGSXR
Dec 28, 2013 06:46 AM
travisbeamon
Sep 3, 2012 11:02 AM
69oldsdude
Dec 1, 2011 12:11 PM
gscott819
Jul 28, 2009 07:02 PM
omega73
Aug 17, 2006 10:11 AM
