View Full Version : General Discussion
- oldsmobile crate engines
- 65 442 brake light problems
- Local show
- Body Mounts for '70 W-31--Polyurethane or Black Rubber
- just to say thanks...
- Is there any protection from ebay or PayPal when buying from Canada?
- Original Paint Markings - 71 Rear Axle Assembly
- Smoky Mountain area, Anyone need or selling parts?
- Higher octane in the future? Opinions?
- looking to decode the stripe color on a 1970 442 with build sheet info
- Meaning of Y68 "color comp ex" option on a 1970 build sheet
- 442 Side Stripe
- 1 week from today , Mecum Indy .
- Vin#s confidential #s on 1968 Cutlass
- Then and Now
- Roadkill customs
- Any guess what this was?
- Spark plug with HEI
- 1964 Cutlass Oakland CA Pick-n-Pull
- '68 Dual Snorkel OAI Kit
- head swap ????
- 1978 Cutlass Supreme
- New Upgrades
- Radiator fitment issues
- Mirror Suggestions?
- Comparison Of Original Firewall Pad Against A Repro - Installation Tip
- What's it worth
- What was the standard speedometer gear ratio for a 200-4R inside a 1985 Delta 88?
- charcoal canister setup
- 1972 Cutlass Supreme Headers Questions
- tilt steering shift lever column
- Crusin' Southern Maryland for the Vets
- Interesting craigslist find.... hopefully someone can save it
- 1957 oldsmobil hood
- Cool Vintage Olds item
- Looking for '68 H/O #482
- Tailpipe tips
- gas tank vent lines
- "Holley" Aluminum Valve Covers
- Fuel line check valve
- Right side only springs heated to be lowered???
- Hot Rod Power Tour 2016
- Location of ac (compressor) fuse
- Q-jet vs Spreadbore Holley
- NHRA Class Question
- Information/help
- Steering column re-installation question
- 455 Chugging/Jerking
- Does Anyone Own A Olds Diesel
- 70 w32 question
- Got any leads on this 72 cutlass s?
- Chrome Rally Wheels
- 1972 Hurst Olds Indy Pace Car convertible
- Friday Night Cruise-Ins/Saturday car Shows
- Tank leaking / Vent line
- P90D Tesla took me to dinner
- 1972 Cutlass Supreme Tach Help
- '70 W30 - RED w/ WHITE stripes.........
- 1970 442 exhaust recommendation
- Steering column help
- My cowl tag has "E" as the prod-month? Huh?
- M22 and reverse lights...
- 68-69 Forced Air Induction 442 W-30
- Contact info for Joe P
- POA vs "Cycling Switch"
- Canadian early 70's rocker cover decal
- Look what I found today
- when did painting become so expensive?
- Help with coolant fitting 64 f85
- Value of good 70 Cutlass S 2 dr post body
- Looking for water pump rebuilding parts
- "HF" vs. "XE" Wheels
- Floor pan drain plugs
- reliable mechanic in the GTA
- Unrestored 1969 Hurst Olds (Cape Cod Craigslist)
- This 65 cutlass is near me. Thinking of buying and parting.
- Best fit headers for 85 442
- Can anyone id this master cylinder
- Cam Info ?
- A/C cars
- 71 cutlass out in the daylight
- rally wheels 14" to 15" trim pieces,centre cap
- REVELL 1983 Hurst Oldsmobile model here
- Olds 307 Belt tension help. 87 Cadillac Brougham
- W25 + Edelbrock 04B + Holley DP
- 72 Cutlass Question
- Advice Requested: New Buyer
- Setting the RED line
- Classic Oldsmobile members are the greatest!
- 72 Cutlass conv.
- Friday Eye Candy
- Radiator Question
- Missed her Birthday....
- service engine soon light reset
- OLDS SHOW in Merrick, L.I., New York
- Could this photo have been more useless?
- Post #1000
- Carpet For 1985 Custom Cruiser?
- 1970 QB Code Engine
- Capri Drive-In, Coldwater MI: '68 442 Conv.
- When did body filler become the new duct tape
- 455 Olds in 1973 GMC 3/4 ton
- can i get 4k for my wagon?
- How do you guys use Paypal?
- elactron convertible tops
- Recommendations for Gauge Repairs?
- Carb Blues
- Rallye Gauge
- Scored Big this Time
- High Altitude driving '70 442 W30
- Sweet Ride, 85? Custom Cruiser
- underbody of 1955 olds
- 70 forsale
- St Louis 442 Inspection Needed
- So what's the actual story on this $21000 "W-30"
- OK Guys is this really a pace car???
- I wonder if this is a real W-31???
- Was B85 = Exterior Belt Moulding available on 70-72 convertible Cutlass/442?
- A choice of two - what would you do?
- Need to Identify wheel center and spinner DELTA 88
- Production numbers on 1970 f-85
- GPS tracker
- Bumper Filler Question
- Year ??
- Need 3.23 posi for 72 455/auto
- clearance between oil pan and steering comma front pulley and sway bar
- Can anyone help with a picture or two?
- Ummm....I think I'd rather have the Oldsmobile back
- How do I know..
- Repro SS1 Wheel Question on a 68, 442
- Detailing products
- 2016 Nationals
- 1967 Delta 88 Holiday Coupe
- Any 77-79 B/C bodies in Northeast US junkyards??
- The Rarest Olds Part?
- vintage ride.. locksmith help
- Beech Bend Dragstrip
- 67 442 4 speed value, non post car
- 8 track belts
- 2016 Holley Hot Rod Reunion
- MCR letter
- Oldsmobile key fob / key chain
- Joe P in print!
- Need help saving her
- Floor Pan Prep - 69 Ctulass
- AC Problems
- 1970 f85 w31
- Front and rear oil galley plugs. How imperative?
- Toss up paint choice
- This Is Why You Use OE Parts Everywhere Possible
- 1963 F-85 arrives in Charlotte
- 8 Trac player
- Has anyone shipped a used gas tank.
- Sway Bar Issue
- local guy is asking $4500 for an original low mileage 67 442 400e motor.. too much?
- Anyone ever seen this?
- 70 sport coupe rear seat attachment???
- Olds mechanic in Minnesota
- Type of gas in a 1979 Regency
- Jetfire, Jetstar I, and a Starfire all at one local show
- Sacramento Swap Meet 70 Hood
- Compression test results way off 67 cutlass 330
- Batten engine build.
- '69 4-4-2 finally home!
- Question on Lifting my 70 Olds
- Non Ethanol Premium fuel in Northern, Ohio/
- 70-72 442 Spoiler Question
- Does this motor look clean?
- Props for 2blu442
- Cleaning up for the first car show of the season added reveal moldings
- Test drive
- Is it true?
- Engine Makeover in Massachusetts
- Non Ethanol Gas Stations to in U.S.
- 1986 z28 parts for 1967 a body or 1983 g body?
- Help with speaker issue
- 1969 W-30 carb questions....
- oldsmobile diesel 5.7l crankshaft
- Anyone know this 69 Hurst Olds?
- HP Exhaust Manifolds
- 1965 and 1966 convertible quarter window tips
- Vinal Top on 70 Cutlass Supreme
- This is one of the reasons we do this
- Coolant coming out of overflow tank
- Defroster Door Return Spring
- '70 pass sport mirror glass housing won't recess all the way into mirror assembly
- Raceway Park Swap Meet?
- 1972 Cutlass, wiper issue. Off in high position, high in off.
- Just checking
- OEM 72 bumper value?
- Carburetor kit and bypass hose review, And... Inline Tube strikes again
- Air Cleaner Hsg Stamps
- Someone got a real good deal
- 405233 intake
- Guilt or Pressure to make every car a 1st class restoration
- Hurst shifter question
- Have a 71 olds cutlass supreme convertible. reinstall front bumper. any tips?
- Real 4 speed ?
- For your entertainment Craigslist ad of the day
- 95 Olds 88 Serpenting Belt Diagram without A/C
- 1971 bumpers
- Nissan payload rating off by 1000 lbs
- Waze speedometer and more ap for our phones
- Tranny leak during storage?
- 2 1975 442 craigslist
- Center console romval
- trip
- Wheel Opening Moldings Set - What Can I Expect?
- Shorty Headers
- CL. Title and Vin for sale
- RALLYE 350 numbers
- My 71 cutlass has a new life
- powersteering 1955 Olds
- New England Olds Club 20th Annual All-Olds Show
- BJ Has ruined the Hobby
- Canadian Car Finds............2 more saved......
- Hello and What Was that BJ 442?
- Salvage titles
- powersteering
- $50 dash cam - how bad?
- Pin in shift gear (floor console)
- tire pressure decal on 1975 oldsmobile cutlass supreme
- Ospho Rust Treatment
- Brand C big block, REALLY BIG block
- Did a 1994 Delta 88 use VATS?
- White cloth bench
- Visitors to Kingsport. ( Great photo Shoot)
- 70 442 W30 Sherwood Green on Barrett Jackson
- Dezer Auto Collection in Miami
- wiring for the rear view mirror
- Umm...m22?
- SWM 403 Found
- Super tuning...w cars
- RIP Merle Haggard
- 66 Dynamic convertible at 66 Orange Bowl
- 1950 Olds Sedan Delivery
- Check Out the Wiring.....
- This site views
- How much for 66 Cutlass hood
- One of 3,100?
- W30 Resto Project
- 1968 OldsMobile Delmont Information
- ARG!! When will the weather change
- Heavy loss of power after misfires
- R.I.P. Honestdave
- Bench/4speed 442
- NO steering wheel needed
- Machine Shop Recommendations
- Anyone here put 1G down on the Tesla 3 ?
- What battery have you had the best luck with ?
