1969 W-30 carb questions....
<a href="http://s77.photobucket.com/user/realdoneHurst/media/DSC00183_zpsgtturcgg.jpg.html" target="_blank"><img src="http://i77.photobucket.com/albums/j73/realdoneHurst/DSC00183_zpsgtturcgg.jpg" border="0" alt=" photo DSC00183_zpsgtturcgg.jpg"/></a>
<a href="http://s77.photobucket.com/user/realdoneHurst/media/DSC00184_zpswxiqzazp.jpg.html" target="_blank"><img src="http://i77.photobucket.com/albums/j73/realdoneHurst/DSC00184_zpswxiqzazp.jpg" border="0" alt=" photo DSC00184_zpswxiqzazp.jpg"/></a>
<a href="http://s77.photobucket.com/user/realdoneHurst/media/DSC00185_zpsumbnbvgg.jpg.html" target="_blank"><img src="http://i77.photobucket.com/albums/j73/realdoneHurst/DSC00185_zpsumbnbvgg.jpg" border="0" alt=" photo DSC00185_zpsumbnbvgg.jpg"/></a>
I have had this carb for years. Can anyone give a good value for it? It is complete and runs quite well. My info says it is an original 1969 W-30 carb.
Looks like a chevy carb to me. 69 W30 carb is 7042954. Sometimes the first 2 numbers (7 0) are omitted. Your carb would then become 7022954. The 3rd digit designates brand. 2 us Chevy and 4 is Olds. Your date, 1119 decodes to 111th day of 69 or about april 21st, 1969.
You have to elongate the holes on the 69 hinge to fit the bolt spacing on the 68 hood. I think daveh did it on on his red car. I started it back when everyone said it was a direct bolt-in, got frustrated because it wasn't, and ended up putting 68 hinges on. I have a set of 69 hinges that are 99% modified but I never quite finished them. Someday I'll put them on. I have dual pattern fenders. Obviously you need that or a 69 fender for the 69 hinge to work.
You need at least the 69 pattern. The two hole 68 pattern doesn't fit the 69 hinge at all.
What happened with the Rochester Q-Jets with the short #'s is,the Rochester plant burned and the carbs with the short #'s were made by Carter. The 70 designation means Rochester and those made by Carter had no such designation.
What's the date code say for this carb? Years ago I purchased one advertised as NOS on ebay. It was a service replacement carb with a date code in the mid 1970's. OP, sorry I don't know how to read the codes well enough. But that would make a difference on value, if its an original 1969 date vs. replacement date. John
What year did the Rochester plant burn?
Tweed answered it above
I heard this carb also has a date on the base too but I don't know if it's the same.
It would probably be during the 69 model year run because I've never seen any other year with the short Carter #'s.
<a href="http://s77.photobucket.com/user/realdoneHurst/media/DSC00188_zpsvmcvepwo.jpg.html" target="_blank"><img src="http://i77.photobucket.com/albums/j73/realdoneHurst/DSC00188_zpsvmcvepwo.jpg" border="0" alt=" photo DSC00188_zpsvmcvepwo.jpg"/></a>
