Best fit headers for 85 442
Old May 1, 2016 | 03:28 PM
85Cutty442's Avatar
Looking to see if anyone has any first hand experience with headers in their G body,
I'm using a moroso 7 qt oil pan, and i also am using a power master mini starter.
If you have a gbody with a 7 qt pan and you have headers, please chime in with your opinion.
Thank you for your time
Old May 1, 2016 | 09:12 PM
oldsmobiledave's Avatar
You did not state which engine, original small block or other replacement?
All SBO fit the same as the 307. ARH are the best for SBO in a G body. Need powermaster mini starter to make it work.
If you went BBO you will need hooker or kooks.
Old May 2, 2016 | 02:29 AM
85Cutty442's Avatar
I apologize for that,
I am using a SBO 350 w/ pro comp heads, if this helps.
Thank you again
Old May 2, 2016 | 07:14 AM
83hurstguy's Avatar
I had a stock pan on my '83, but it had plenty of room with the ARH headers and mini starter. I did have to trim the ears on the transmission case (200-4R) though.
soundhd
Aug 8, 2012 04:24 AM
STR-8_CHARGIN
Aug 13, 2010 04:43 AM
boondocker
Dec 13, 2009 09:00 AM
nonhog
May 15, 2008 03:18 PM
