View Full Version : General Discussion
- What do you think?
- 1949 88 water pump?
- 1970 cutlass Radiator Core - Brace Patch
- 350 question
- 68 Quadrajet on a 67 330?
- 1979 olds/hurst
- Another good deal!
- Oldsmobiles sold in Manchester NH
- value 1969 w30 block
- Engine Casting Number
- Pillar needed, online part sites
- Linkage
- Help with carburetor install
- 442 engine start in 26 years
- 442 question
- Olds 442 hood
- 1974 olds 442 thoughts
- A big thank you to everyone here.
- 1986 Oldsmobile Cutlass Supreme Brougham/ Seat Couple Assistance
- 1974 Oldsmobile exhaust manifold
- 1964 Cutlass 330 to 455 swap
- How much are 70-72 AM FM Radios worth?
- 1111977 0B23 Distributor
- flowkooler 1775 waterpump gasket #
- 1970 W-33 Package Olds Delta 88 Convertible Questions
- Carburetor Rebuild Advise
- What's wrong with this picture?
- First Ebay Motors Purchase
- Two part question...
- bumpers
- Toronado question
- 72 cutlass with no emblems on the front fenders?
- Good machine shops in chicago suburbs.
- Wire harnesses When to Replace
- 70 Cutlass - Radiator Core Support Bushing install
- 62 Olds Door Weather Seal
- What's it worth
- Does anyone know the history of this Ram Rod
- 1970 442 Grille Installation
- Deciding on a Lift, 2 or 4 Post, etc.
- I just got my new book,Thank you Diego.
- Lokar throttle cable - it works!
- Oil Pump Pickup
- B17 buffs
- Swapping Out Instrument Lights to LED--What Color Temp?
- 1967 coil wiring
- Loving this site
- I miss the 1960s
- Quadrajet TV cable geometry
- Climate control et al questions
- Looking to clone the 1970 hurst olds
- Rear end issues
- Washer box location
- More pictures of houston autorama
- Dash Lights out!
- 1962 Starfire Transmission issue
- Getting A Car that's been sitting running again.
- Bad hydraulic lifters
- The Parts Place Thanksgiving Sale
- 65 442 found, What parts to look for?
- Bastrop Texas Veterans Day Show
- Quadrajet question....4 barrel...
- Car Check Out St. Louis Mo.
- 65 JS1 auto to 4 speed changover
- 1979 Hurst Olds Barn Find
- 70 Cutlass Supreme - Center Hoold Molding
- Cruise control
- Thanks givin 2016
- Removal of reveal molding on top of a 1968 to 72 Vista Cruiser tailgate?
- Can I use chevelle lowering coils?
- GM of Canada / Vintage Vehicle Services
- Meeting fellow Forum members
- Bench seat to bucket conversion
- Window felts
- adj carb w vac gauge
- Today is the day
- New Addition - 1970 Cutlass
- 1919 Olds V8 on ebay
- Did anyone else see the first episode of Grand Tour?
- Car Hauler Recommendation
- Houston AutoRama
- 72 supreme
- What Engine in this Barn Find?
- Good buy ???
- Rocker Arm Shaft
- Might have to sell a Cutlass
- Real or not. 0256 carb ???
- Converting bench to buckets -- impact on value
- 68 & 69 442 performance
- 403 heads
- R/A air cleaner ?
- Lock Washers
- Model ID
- 1970 firemist paint ????
- 70 cutlass 14" steel rims 4 - free
- edelbrock 2711 intake 1406 carb 8131 fuel line kit issues
- Fuel Issue - Need Some Real Help
- New oca chapter
- Relay ID
- Awful eBay experience-Saved by this site!
- Steering wheel alignment after gearbox swap
- 1961 oldsmobile starfire on airbags
- cragar mags rims
- Replacement part "quality"
- 2016 MCACN, Who is going?
- Veterans Day
- New Mexico July Temp
- Ram Air Hood wire screen/ who sells them?
- Check out my latest find
- 1982 Oldsmobile Firenza
- ac vs non ac heater boxes
- Head gaskets .030 bigger than cylinder bore?
- W Cars "Twins/Cousins" meet first time!
- EBay open face alternators (kinda repro)
- GPS locator anyone using them???
- Are 295/50r15 tires going away????
- bone stock , slightly modified or restomod, whatcha got?
- 1961 oldsmobile starfire dual master cylinder conversion
- 57 oldsmobile Craigslist
- Installing your own convertible top..
- Why No Love for Olds
- Used flat tappet cam with new lifters?
- 71 cutlass with removable hardtop
- Spring on 1973 olds
- 71 Cutlass SX Conv.
- 66 442 dash
- What type ATF to use?
- First Cutlass
- Fuel line replacement
- FiTech install #3 today
- Taking a break from the make.
- "Hurst/Olds" from SEMA
- 442 Respect
- Phosphoric Acid
- Fantasy pricing
- gauge repair recommendation
- Power Steering Failure
- Possibly the dumbest new product from SEMA
- Car storage...to stand, or not to stand
- 73 olds floor shifter removal question
- ID PLate
- Replacing opera window trim
- Anyone else getting pop up saying you win 1000.00 gift card
- AC Box Fix?
- Engine bolts
- Windsheild wiper spindles
- Big Block vs Small Block
- wheels
- lift loop in action
- Oil useage
- Stupid Flywheel Question
- Oil
- has the world gone mad II
- Is this a good buy, bad buy, or regular buy?
- 4 sp. flywheel
- 70-442 heat is intermittent
- Bucket seat question
- Any winter projects
- 1964 dynamic 88 wagon
- The world has gone mad...
- Help in ID of trim rings
- Correct headers for the 67 Woodland & Anderson drag car??
- Top down weather for the 6 months!!!
- Shakedown Shakeup Drive - 64 F85 in restomod process
- Intake question 72 cutlass 350
- Book
- Assembly line
- need, 70 rear quarter lower section
- 70 olds 442 ???
- Unusual Halloween lawn decoration.
- Sometimes it IS the simple things you overlook
- Best new/repro dual gate shift knob
- Request for help
- Carpet : Cloth or Rubber?
- 1985 442 Oil Pressure Issues
- 1969 cutlass what is widest size wheels/tires will fit
- Hit and miss engine
- steering box finishes
- throtle position sensor 84 cutlass 5.0
- Historic Dash Cam Video 1988 Chevy/Ford/Mopar VS. Olds 98
- need help on a phenolic carb spacer
- 62 88 and 64 starfire trans
- GM forgets its history
- Build Sheet Question
- 69 vs. 70 A Body Core Support
- Screen at top rear of engine on 55 olds
- Are these standard hubcaps for 1972?
- Unrestored all business W30 going to Mecum
- Atco Dragway Show Oct 30 NJ
- AC POA valve
- window wsh connector
- Trunk hood and door rubber stoppers?
- Looking for some motor build advice
- high idle problem
- rear axle vents
- Another eBay Optimist...
- Pully combo codes
- Positive purchase from Olds3442 !!
- Heating my garage
- Z bar
- 442 S ? is this an option?
- Torque spec
- Dyslexia Strikes the 68
- 64 F-85 Deluxe sport custom
- Check out this beauty for sale on C.L.
- The Unicorn
- #48 Sherwood Green
- What year is this part?
- Oh, the humanity.
- 71 442 Convertible
- newbie with some 1970 Rally 350 questions
- Auto Oil Change Intervals
- WTB '70 Matador red 442 1/43 scale
- G Body double hump crossmember
- My hometown car show
- Lowering 1961 oldsmobile starfire
- 67 cutlass back seat not comfortable...
- Browsing history?
- Who has the best repop OAI flapper door, 70-72
- 70 cutlass exhaust head pipe question
- 70-72 Cutlass Supreme painted stripes
- 67 cutlass console pieces lost
- Texas megamansion
- Oldsmobiles for sale at Hershey
- Help!!!! Not getting gas again!!!
- Piston Ring Sets
- I'm trying to understand Oldsmobile and GM paint codes...
- What American Racing Wheel Is This?
- Stereo install
- You can download Oldsmobile info from GM. Heritage Center
- Why I don't buy parts locally
- todays gasoline properties.
- What's with the seams on the tops of new cars?
- Paul's chrome for bumpers
- Down East NC Members: Effects of Hurricane Matthew?
- Need to decode a EB type Generator/Alternator
- RIP Brock Yates
- 1967 Oldmobile radio
- Reference
- 72 olds cutlass parts car
- Provenance stories are getting creative.
- Tic-toc-tach.
- Cruisin' the Coast 2016
- Olds break down !!!
- 69 442/Cutlass aftermarket fenders
- fall car show, Pentwater Mi
- Downingtown PA All Oldsmobile Show
- red inner fender ?
- Carb decode
- My muscle car book is ready for pre-order!
