PDA
View Full Version : General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. Upper control arm seals on 65 Cutlass
  2. CO hacked?
  3. "Pay Forward" with parts?
  4. Ss1 wheels
  5. Output shaft diameter
  6. Three miles
  7. 1970 dealership vehicle price poster
  8. Really? Again?
  9. 77 GMC Jimmy brake problem
  10. Rally Pac Gauge Repair
  11. Brake cylinders
  12. Blower Control 1972 Cutlass
  13. My Buddies New Playroom!
  14. spoiler opinions
  15. WANTED~2018 OldsmobileCalendar.com pictures wanted for the 2018 Calendar
  16. Spark blow out
  17. Looking for correct part?!?!
  18. Convertible Top cleaner
  19. 14" X 7" SS1 wheel trim ring depth
  20. 1968 442 Water Pump Pulley
  21. '62 Starfire side panels
  22. Cold front
  23. Dual Gate Conversion
  24. 1st time for everything!!
  25. 62-63 f-85 transmission question
  26. ATTN MODERATORS! Marketers using the PM's
  27. Parts Place Ram/Repro Air Hoods fit?
  28. Jetfire turbo rebuilder article from Hagerty
  29. The Dualjet carb has the same throttle geometry as the Quadrajet?
  30. 1966 Toro coolant bottle
  31. Exhaust Manifold casting numbers
  32. Has anyone ever had an electrical issue related to the cig lighter?
  33. Need a thorough inspection in northern Minnesota
  34. A-pillar outside weather-seal
  35. Archway Olds Club Fun Show this Sunday
  36. Bullsh!t post Memory Lane
  37. I bet it'll run in the 12's!
  38. Head light switch warm to the touch
  39. Transport Available from Illinois/Wisconsin to Colorado
  40. 69-72 jacking and jack stowage decals
  41. What glue is used for this.
  42. 330/455 swap?
  43. Z-bar bushing
  44. Bad weekend for my cousin's 66 tri carb car!
  45. Pics from Purestock
  46. Olds distributor 1111289
  47. 1968 SSII wheel
  48. Backfiring 1967 cutlass supreme 330
  49. AC parts - worth keeping?
  50. Richards 1966 Cutlass
  51. '57 Olds Dash Question
  52. Anyone know what year this mirrors?
  53. Fall Carlisle
  54. NOS boxed rear control arms
  55. someone explain to me the advantages of a bolt with a 12 point head
  56. Choke setting
  57. 1971 Cutlass S and project 455 with L 69
  58. Old Pic of '69 H/O
  59. Using BB Exhaust Manifolds w/ Cam
  60. How much HP is enough?
  61. aluminum heads for my 67 330 engine?
  62. 72 442 w30 documented
  63. Inside Hood Lock Cutlass/442 '70 - '72
  64. Wheel Question
  65. Help me understand...
  66. Radiator Tag Code Decode
  67. Engine number
  68. sounds crazy but hear me out...
  69. Hagerty Article on the Jetfire model
  70. A lifetime with Oldsmobile
  71. Who knows a quality electric window motor rebuilder
  72. Will this ever end??
  73. Had a little get together last night and this showed up.
  74. Intermittent fire.
  75. Rear Window Reveal Moldings for 1970 F85
  76. When I turn on the heater in my 70-442, it blows warm,
  77. Radiator from '70 Cutlass
  78. How many of these were used on 70-71 abody olds?
  79. 1971 Cutlass hood hinge color?
  80. Brandon Reynolds A+++++++++
  81. Was there such a thing as a Chevy only pattern 2004R?
  82. BRAKE Light Stays On Dash
  83. Charging Issue Question
  84. Pegging the meter...
  85. Keep your GM car GM air cleaner decals
  86. Title sales??
  87. Carburetor primary throttle shaft bushing kits
  88. 66 88 B Body: Are original exhaust hangers available?
  89. 1970 taillight socket
  90. Rear tires on a Starfire
  91. Brake drums for 65 olds
  92. Hurrican Harvey 442 Flooded
  93. Fuse and plug question
  94. Sudden idle problems
  95. Octania was a Great Saver
  96. 66 442 fuel tank vent tube kit
  97. Olds WD-30 last of it's kind...
  98. 70-72 A/C under dash vent runner
  99. Disc brake part??
  100. A big thanks to oldspackrat
  101. Spilling fuel
  102. 1957 Olds 98 exterior chrome molding
  103. dual gate shifter
  104. Speedometer Cable for 1967 CS Holiday Coupe
  105. Wheel Vintiques 15 in SS 1 problem
  106. My car lighter 70-442 will not heat up. The fuse is fine
  107. Happy 40th Anniversary
  108. 1970 442 bumpers
  109. 1970 Cutlass Supreme 350 with 7041251 Quadrajet
  110. A fin instead of a wing on a convertible
  111. This doesn't sound good
  112. Oldsmobile part vendor help - Wisconson parts
  113. Machinists Humor
  114. 1958 Oldsmobile in San Francisco Bay Area
  115. Pertronix & Points
  116. Trunk Lid Lock Question
  117. 2017 Adirondack Nationals anyone? Sept 7-10 Lake George NY
  118. 1972 Cutlass Olds Parts Shop in Annapolis MD
  119. 1970 dual gate shifter value
  120. Starfires
  121. Exhaust Options '70 CS
  122. Labor Day Weekend
  123. Flywheel issues!!
  124. Long Story from my adventure today
  125. Annual Clements Market Car Show
  126. Fuel cooler?
  127. 1970 442 back from paint (pics)
  128. Days Gone By
  129. adirondack nationals car show
  130. I have a addiction with olds, WHY I was a Pontiac guy
  131. Oldsmobiles at Saint Faustina Grove
  132. What does the stamped numbers on the oil fill tube reference?
  133. Fusick kick panels
  134. Bad news for connected vehicles and the future of self driving vehicles
  135. Maybe a dumb question???
  136. Value of '68 power antenna switch??
  137. 1970 442 A/C faceplate
  138. Anyone know a good 65 to 70 Cadillac forum?
  139. Oldsmobile casting numbers?????
  140. 69 cutlass/442 Weather striping supplier ???
  141. revolution per mile
  142. 70 442 back from paint (w/ pics)
  143. ID this part and value
  144. Hot August Nights 2017 Olds
  145. What body mount kit is the closest to OEM
  146. 72 Cutlass Clock Lamp
  147. '62 Jetfire promo film
  148. 69 442 emblem locations
  149. Rarest Oldsmobile part EVER!
  150. 1970 Cutlass S hardtop rear glass
  151. Non Olds transmission problems
  152. Replacing starter on 330
  153. Garage tour 2017
  154. 64-67- hose that go from Intake to heater
  155. 330 # 4 heads on 455 engine...
  156. Hidden hitch
  157. Gas Tank Liner Opinions
  158. For the guys running 403's out there!
  159. 72 442 pinch weld problem
  160. 74 or 73 white omega
  161. Just had my 70--442 Rochester carb rebuilt.
  162. Auto hi-beams
  163. I don't think I've ever seen anybody ask about this before ...
  164. OAI hood with light
  165. 71 Cutlass Conv Questions
  166. Turbo 400 issue
  167. HVAC vent
  168. Lowering springs for 72 cutlass convertible 455 no a/c
  169. Full lock sets for 70-72 cutlass
  170. cam ID
  171. Mannix's toronado
  172. 68 442 Seat belt housing
  173. Factory employee's and special orders
  174. Interior plastic paint
  175. Anyone live near Elizabethton tn.
  176. Not mine, dual gate shifter
  177. Blue/Gray Car Show at the AACA Museum in Hershey
  178. Photobucket 3rd party block bypass for Firefox
  179. positiv valve stem seals
  180. radiator issue
  181. Auto shipper Spokane to Chicago....
  182. Instrument cluster fuse keeps blowning
  183. 1971 Flat Top wagon 4dr 2 row seat,, where is the build sheet located
  184. quadrajet question
  185. We have moved!
  186. 1970 model year LANSING production
  187. a newbie
  188. An oldie but a goodie from BJ
  189. 455 Tear down. Sat ten years. Any thoughts on this one?
  190. Annual Car Show
  191. 1972 Cutlass Supreme Clock
  192. Bone stock 455 ignition timing
  193. One piece or 2 piece
  194. Repo a-frame seals not right
  195. Brake bleeding help
  196. Aftermarket parts question??
  197. James Garners 442
  198. Gauge range for oil and water temp
  199. 2328 motor mounts
  200. Switch pitch questions
  201. 1970 toronado
  202. windshield trim
  203. 1958 Oldsmobile Jetaway problems
  204. Cars that made America
  205. Non computer 307
  206. 70 Cutlass Supreme - Radio question
  207. Sell-A-Thon basketball hoop
  208. 70 Cutlass Supreme Value?
  209. oldsmobile trailer
  210. Enquiring (442 fanatic) minds want to know.
  211. Car video
  212. Frame and Shell transport 1965 442 (looking)
  213. Where to get new rally pack face plates?
  214. Radiator upper and lower rubber seal
  215. engine temp readings
  216. Source Needed to Look Up GM Part Numbers
  217. Total Shock
  218. Trunk Question
  219. 70 442....Wanted to Cry.......
  220. It only took 10 years..
  221. a Lansing buildsheet!!
  222. 1995 h/o?
  223. AC and alrenator brackets
  224. Wanted: black vinyl bra protector for front grill on a '76 Cutlass 442...
  225. Mysterious coolant leak
  226. 1972 Cutlass Supreme Speedometer Lamp
  227. Dave Laurer Oldsmobile drag car
  228. Help with 1972 442 option code on build aheet
  229. another cutlass supreme 1970
  230. Pax side mirror
  231. coolant coming out both exhausts
  232. Bucket seat ID
  233. distributor numbers
  234. Key pullout in ACC & RUN positions, 1965 Cutlass
  235. Power Windows?
  236. Heater hose restrictor and overheating
  237. 1969 442 Horn relay
  238. If Oldsmobile were to return to production today
  239. Garage - hot stuff
  240. DFW area Machine shops
  241. W27 diff cover
  242. Cork vs Rubber Valve Cover Gaskets?
  243. 15th Annual All Oldsmobile Fall Show, Sunday, Oct 8, 2017
  244. Need Some Real Help
  245. 62 starfire gaskets
  246. Wendy's Commercial with Olds
  247. 1970 electrical connectores
  248. 72 442 in Hemmings
  249. How much?
  250. Universal joints
