Garage - hot stuff
Garage - hot stuff
Ok guys my new garage isn't much different than my old one. Limited on space and the garage door faces the same direction on the compass, with some living area above. But this one is HOT inside.
A difference is that this one has an extra panel for height on the door itself with windows. And also there is an electric 50 gallon HW heater vs a 50 gallon natural gas we had at the other place. Not sure that would add to the heat, but just throwing it out there... The new place was built this year and the old place was built in 1998. So it is possible the finished living space above the garage was insulated on the floor differently.
So I'm thinking I need to get some airflow going in there somehow. I've browsed the through the wall exhaust fans, but I wanted to get some feedback first. Do those work well at all if you don't have a cross flow scenario where you can install one on each side of the garage? The one side of the garage is on the sidewalk leading to the front porch and I'd like to avoid placing one there if possible.
In case anyone is wondering, I prefer to work in the garage with the garage door closed.
My 2 car garage is small 20x20. It gets so hot and humid that mold was growing inside my cars even with the windows open. I did a google search and found a solar power exhaust fan from www.ussunlight.com. It really works and no more hot and humid air. Installation took me 15-20 mins. I couldn't get a tax write off with this fan because my garage is not attached to my house.
I have a through the wall exhaust fan in my shop/work/dirty room. I really only use it to suck out exhaust fumes, welding smoke, or paint fumes. But that room seals up so tight that I need to crack the man door to get some flow through so the fan can suck out the nasty stuff. I also made a hinged door to seal it off when it's not running.
When I was at my other place, every once in a while I would take my huge fan, open the garage door the whole way, and then exhaust all of the warmer air out. Then I would seal it up and let the fan blow the A/C out from the house into the garage for about 5 minutes then close the house door. That worked well, however in this case as I mentioned...this current garage is way hotter to begin with.
Used, probably from $5-800. Call some mobile home places and see. They are a single duct type system and you can branch off just like any home unit other than the duct comes from the outside.
How hot is hot? During the summer, my garage is typically 90 or so in the morning and well above 100 in the afternoon.
My neighbor installed a louvered fan in the garage wall similar to the one above, and that worked well. Later he pulled the fan and stuck a window AC unit in the opening.
So the ductwork just comes right into the garage wall and then you have to put a return somewhere too, right? Sounds easy enough.
Walked around W/M (that's where I get my exerciser daily) the other day and a stand alone AC unit was on display for I think around $275. don't know anything about it just passing along.
Good luck.
Johnny
Good luck.
Johnny
jack69cutlass
Oct 23, 2012 09:56 AM
MrLightning
Aug 28, 2011 12:22 PM
