Inside Hood Lock Cutlass/442 '70 - '72
Old September 16th, 2017, 03:37 PM
Toms cutlass's Avatar
Anyone install or have experience with the inside hood lock release offered aftermarket by TPP?
See > http://www.ebay.com/itm/1970-72-Olds...BXUiZk&vxp=mtr
http://www.ebay.com/itm/1970-72-Olds...ZXVflI&vxp=mtr
Toms cutlass is offline
Old September 19th, 2017, 03:01 PM
JLane92's Avatar
Following
JLane92 is offline
Old September 20th, 2017, 10:46 AM
davebw31's Avatar
their lock assembly has two items that are not the correct finish. The one most noticeable after installation is the lever with teeth. I saved an original latch that is very nice and looks NOS.
the cable mounting tabs are wrong (original were plastic and prone to breaking) I used "plastic coat black liquid rubber". I layered several coatings with a drying time of 24 hrs per coat to the thickness of the original tabs. I let dry for a week and using a very fine file using light pressure I took out the imperfections and smoothed any ridges. Use patience, go slow, and make as little heat as you can. I had a cup of ice water and dipped often. People think the cable is NOS
davebw31 is offline
Old September 21st, 2017, 07:44 AM
Thank you, Dave.
I was looking for exactly that level of detail regarding appearance. I wasn't looking at the latch for functionality as much as appearance, especially on a ragtop. (Back in the day, you wouldn't lock the doors of a ragtop since the top would be cut if someone really wanted to get in.)
goldie442
August 21st, 2015 11:01 AM
benjamin247
October 1st, 2014 07:23 PM
RandyS
February 14th, 2014 06:44 PM
tcarroll
January 3rd, 2013 10:15 AM
randomarrival
December 22nd, 2012 12:28 PM
Quick Reply: Inside Hood Lock Cutlass/442 '70 - '72
