2328 motor mounts
Old Aug 19, 2017 | 08:53 PM
edzolz's Avatar
2328 motor mounts
I have a pair of nos Borg Warner 2328 motor mounts to use on my sons 67 big block. They will not work on the frame pads we have. Can someone post a pic of the correct frame pads used with these mounts? I was told the pads we have are for the big block mounts but the tabs on the mounts prevent the holes from lining up.
Old Aug 20, 2017 | 05:36 AM
zeeke's Avatar
Joe did a sticky on this a while back. This should answer your questions.
https://classicoldsmobile.com/forums...tion-list.html
Old Aug 20, 2017 | 05:53 AM
Once again, let's please stop calling them "big block" and "small block" mounts. For 1967 (and for model years 1965-1968) there was only one motor mount for ALL Olds engines in the A-body - the 2261 style. Don't change the frame pads, just get the correct mounts for your car.
Old Aug 20, 2017 | 08:36 PM
edzolz's Avatar
This car came with a six and I had a set of early frame pads. I guess I will buy some of the early mounts to match up with them or buy the later style frame pads and use my 2328's.
Old Aug 20, 2017 | 08:41 PM
steverw's Avatar
Seems like i paid $3 bucks each for my 2261's at Advance Auto. I think they are Anchor brand. Not sure but they were really cheap as i remember.
Old Aug 21, 2017 | 08:03 AM
...or buy the later style frame pads and use my 2328's.
Why? Unless you are a glutton for punishment, leave the frame pads in place and use the 2261 style mounts like Oldsmobile intended. Again, this is what the factory used on 1967 big block A-body cars.
Yup, something like that. They are regularly $3-something from RockAuto.
Old Aug 21, 2017 | 08:36 AM
edzolz's Avatar
Because my 2328's are old stock made in USA, not Chinee.
Old Aug 21, 2017 | 08:44 AM
So use them on a car that needs them, like a 1969-72 442. Seems like a big waste to futz with the car just to use these here. Your time and money, your call.
Texas442
Mar 1, 2017 06:22 PM
Nasty455
Mar 20, 2012 04:57 PM
ctrain22
May 20, 2009 11:02 PM
Giddy
May 12, 2009 08:21 PM
flatoz
Mar 15, 2009 02:03 PM
