PDA
View Full Version : General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. Spark Plug for Stock '65 330 4-Barrel?
  2. Representing the brand at a local car show
  3. Saw this beauty today...
  4. I still don't get it
  5. Expertise needed 1968 / 442
  6. 442.com?
  7. Austintown, Ohio - Anyone live or travel in that area?
  8. Exhaust hoods
  9. 70s/80s Us Sportcars with the best Handling/Suspension
  10. We should not be insisting on paypal "friends and family"
  11. Rear axle and differential
  12. Pax side mirror
  13. looking for a rim for a 1958 Olds Super 88
  14. 2 door Vista Cruiser??
  15. 62' brake drums
  16. If this insulation fits the Chevelle wgon, shouldn't work for my vista cruiser?...
  17. hood insulation
  18. Please help!
  19. Interested in buying a 1955 or 1956 Olds. Would love some guidance!
  20. 307 conrod installation
  21. Found My Car's Twin: 2 '69 convertibles
  22. Diecast cars
  23. Getting stuff out of crossmember
  24. Product Review - Thormton Guru Colors Trunk Floor Kit
  25. Second broken trans cable in two years.
  26. 71 W30 4 Speed Car
  27. 70 350 block stamp & VIN
  28. 79 Starfires
  29. Parts suppier
  30. 72 CS Color
  31. Internally regulated alternator used with external voltage regulator
  32. Cobra Kai YouTube Red series has 72 Convertible in it
  33. 400 question
  34. Classic Exhaust?
  35. 1970 1100 890 alternator
  36. 1988 Indy Pace Car
  37. A fate worse than death...
  38. Jetfire display engine
  39. Lug nuts bad
  40. A/C Upgrade Kit, anyone using it?
  41. Saffron 67 442 from Florida
  42. Oklahoma Roll Call
  43. trim removal
  44. Inline Tube Car Show
  45. 442.com?
  46. Show Stopper-Call stripe Police!
  47. another aluminum radiator question
  48. Long story about a/c on the Cutlass.
  49. 53 super 88 front bumpers re-chromed going rate.
  50. MINNESOTA dust off show 19May
  51. 1970 442 cowl tag 3 speed car
  52. Racing To The Past
  53. Update on fatal Uber crash
  54. 1969 442 door panels
  55. 67 442 Air Conditioner Lever Hangs
  56. 1968 Cutlass - Right Stuff Disc Brakes
  57. 1970 Supreme. Worth $500?
  58. Fact or Fiction: '40 & '41 Phaetons
  59. dual exhaust for 73 Omega
  60. Overhaulin Chris Jacobs
  61. Trunk Wires Question/ Remote opener??
  62. Look what found
  63. Junk Yard sine 1954 and Never Scrapped Anything
  64. Muscle Car Hoods
  65. crappy elec fuel pumps
  66. New ac dryer explodes ?
  67. Need help---AGAIN
  68. Fender vent template
  69. heater valve
  70. Dallas Guitar Fest
  71. Nola
  72. Rear brake drums
  73. Dana/Perfect Circle Cruise Control parts
  74. Second generation Toronado parts source?
  75. 72 Delta 88/ Will Cragars fit over disk brakes?
  76. Pre WWII battery cable display
  77. Gmc pontiac olds cad buick show
  78. G stamp instead of H
  79. Loss of reference materials
  80. Kingwood Texas
  81. How to tell if car is original a.c. or heat only?
  82. Did Dodge ever run a hood like this back in the day?
  83. radiator 1972 cutlass
  84. 36 ford data plate vin# question
  85. College bound...
  86. 70 442 front grill bottom tabs color
  87. Ordering carpet from Rockauto
  88. Northern Ohio Chapter of OCA May 6th Dustoff
  89. 2018 Olds Dustoff Merrick NY This Sunday 5.06
  90. Courtesy dome light
  91. 68/69 Cutlass/442 rear side marker gaskets
  92. loss of power
  93. Vancouver is certainly a nice place to visit...
  94. Car show
  95. Fan shroud craziness.
  96. Crager SS rims
  97. EVAP & Vacuum. What line to use???
  98. Windshield Wiper Bushings for 1966
  99. Exhaust manifold bolts
  100. I didn’t score any parts at the swap meet, but ...
  101. replacement fuel tank 1972 cutlass
  102. Detroit Autorama 2018
  103. Go ahead and bash your headers to fit
  104. Front end reassembly pictorial and parts??
  105. The apocalypse is nigh
  106. 1970 442 cowl tag
  107. Decal placment
  108. What happened to High Performance Olds?
  109. 1967 442 Oldsmobile
  110. Gasket Under Exterior Stainless Trim?
  111. Rag Joint Splines?
  112. Help with the hood.
  113. coil springs
  114. Interesting film on choke operation
  115. Undocumented W car!!!
  116. My baby became a Bi"t'ch
  117. Help Decoding VIN and Data Plate Please 1968
  118. Still kicking around ideas for our 1970 Cutlass
  119. Dash lights
  120. Speed o dash lights intermiddent
  121. Leather dash maybe??
  122. Adding Temp Gauge to dash
  123. The woes of MAW repair the rear boot day on the 55
  124. 76 Cutlass
  125. 442.com
  126. Tamraz issue?
  127. Reo speed wagon truck
  128. exhaust crossgver plugs
  129. Rear brake parts
  130. 68 CUTLASS/442 Column Info Needed
  131. Drum brakes adjusting
  132. 94,95 Oldsmobile convertible
  133. Weather stripping on a ‘65 Cutlass conv.
  134. 68 Cutlass Convert Part Prices
  135. 66 442 !!!
  136. IBM codes for 1962, Where did they come from?
  137. 68 442 Convertible
  138. engine paint
  139. Needle in a haystack
  140. Anyone have a set of plans to DIY
  141. Treading water
  142. Thinking about relocating to Pinellas County
  143. 1 Of None?
  144. Crushing Classics
  145. Elmer NJ auction 68 W30 some D heads etc
  146. 4 post lift
  147. interesting 67 NOS W30 air cleaner....all of it
  148. Those with rotisserie experience
  149. Help
  150. 1970 442 Overflow position with washer bottle on passenger side
  151. Doors hard to close, thoughts?
  152. Today Was a Good Day
  153. 12 bolt "O" axle posi units
  154. 9 inch or 11 inch booster? does it really matter?
  155. 83 cutlass brougham
  156. Rebuilding your 72 cutlass tail lights
  157. Rear end question
  158. DIN Hack Repair Opinions
  159. NOS Pulley numbers
  160. 1970 olds cutlass supreme Convertible Pace Car
  161. 1965 442 lost
  162. Leaving during the show
  163. Mecum; 70 SX W32 Conv
  164. Took ownership of my father's '65 Cutlass Conv.
  165. please help identify this...
  166. A/C - Heater Vacuum Questions
  167. Decided to take some pic's of the typically important engine, trans rear end numbers
  168. 70 w-30
  169. 1955 Oldsmobile Super 88 sedan
  170. Unwanted Oldsmobile Aurora final 500
  171. 1987 Custom Cruiser for $1500
  172. Another BJ Auction car 70 W30
  173. hahaha 70 442 "good bones"
  174. E4MC Quad TPS question
  175. Muscle cars enjoying a big day at the Barrett Jackson Palm Beach
  176. electric fans?
  177. Sport Steering wheel ?
  178. 400
  179. Firestone tires
  180. 68 Canadian tag decode
  181. OHIO Piston help
  182. 5 speed Cutlass
  183. 71 Cutlass 350 AC brackets
  184. 64 vs 65 cutlass
  185. Baby caps
  186. gauges
  187. 1967 442 Oldsmobile - Body Trim
  188. Onestone
  189. 1980 cutlass supreme
  190. What's a Hood Worth?
  191. Does Anyone Have a Picture of the Anti Rattle Spring Inside the Tailgate of a Vista
  192. Anybody see this? cresent wrench with vise grips
  193. Costom Willys
  194. Best lug nut
  195. Puller vs pusher fans
  196. Octane ratings
  197. Reproduction SS l ??
  198. Schumacher Lithium Jump Starter SL1315
  199. WTF is this ?
  200. Interiors Who has the best quality and prices
  201. 55 f100
  202. build update
  203. chris witt
  204. 1968 Wiring Diagram
  205. Decal's
  206. 62-63 Tachometer Bezel
  207. 324 #8 Heads
  208. Found 442 without VIN !
  209. Shout Out to CO
  210. Mystery Steering Column, 1970's floor shift tilt
  211. Goodbye
  212. 61/63 cutlass / jetfire articles
  213. Cracked up
  214. 2018 Spring Carlisle
  215. Needing help finding a part
  216. Drive Shaft Stripes, Colors and Specs?
  217. Is this console a good candidate for resto?
  218. Phase out of ethanol fuels
  219. Is this the Factory Correct Alternator for a 1972 Vista Cruiser?
  220. Free shipping
  221. Best Vinyl Top Care Product???
  222. Clarification on 4-Core Harrison Radiator
  223. Engine Issues
  224. Dealings with AutoZone
  225. "Custom built by Hurst"...
  226. 1970 Painted rim question
  227. Discrete way to secure hood - 66 442
  228. Olds 403 would this be a good buy
  229. Radiator Codes
  230. Pictures of early Lakewood Bell Housing Wanted
  231. Value of a '65 330
  232. Quarter window roller spring
  233. 1970 Cutlass SX
  234. Upper Radiator Hose
  235. Mom's new 72 Supreme
  236. Radiators
  237. Rear Drum Questions
  238. Time for a new trailer
  239. Paging Gary M
  240. Is 1972 same as 1970 Vista Cruiser or Cutlass Cruiser?
  241. Window Sticker?
  242. 1969 doors
  243. Story board for your car
  244. Gas Monkey Shiner Bock F-100 truck
  245. Rallye 350 Deck Lid
  246. Roger Barr of Chasing Classic Cars
  247. Wanna see a whole lotta cars in one place?
  248. Craigslist SPAM
  249. What 1970 factory colour does this look like?
  250. Anyone near Kalamazoo?
