Getting stuff out of crossmember
Old May 15, 2018 | 04:24 PM
young olds's Avatar
I was swapping frame side motor mounts on my 66 and dropped most of the nuts inside of the crossmember. I stuck my finger up into the hole in the middle but I don’t think it’s big enough to fish around for anything( I think I felt a socket in there though). Wondering if I can get in with a magnet from anywhere or if I should just cut a bigger hole out in the bottom?
Old May 15, 2018 | 04:28 PM
Welding wire and a magnet.
Old May 15, 2018 | 07:38 PM
young olds's Avatar
Where do I go in from? I don’t think the little hole underneath is big enough, at least for the socket that I felt.
Old May 16, 2018 | 07:12 AM
Tedd Thompson's Avatar
With a strong magnet (earth magnet) you should be able to drag anything metallic to the closest hole that they will come out of.A small one has the pull of 45 lbs or more. Found at Home Depot for under 10 bucks..... Tedd
Old May 16, 2018 | 07:35 AM
I dropped a socket in there when I changed out my perches. Had to go in at the Aframe end to get it out. Its a pita...
Old May 16, 2018 | 07:49 AM
Mr Shifty Sidney's Avatar
Turn it upside down and shake it out.
Don W
Old May 16, 2018 | 07:51 PM
oldolds88's Avatar
air hose with blowgun and a piece of brake line fitted to it. it'll bend anywhere you need it to and 100 lbs. air will blow it out of it.
Old May 17, 2018 | 06:56 AM
^^^This. Go through the holes where the lower control arms attach.
Yet another good reason NOT to change the frame mounts when swapping engines. Just use the motor mounts that match the frame mounts.
Old May 17, 2018 | 02:51 PM
young olds's Avatar
I went from a v8 to straight six, it was necessary to change them. I’ll go through the a arm area, thanks guys.
Vader
Jul 11, 2012 10:20 AM
cutlassgal
Mar 25, 2012 08:04 AM
coppercutlass
Sep 11, 2011 06:22 PM
American Lead
Mar 10, 2009 04:37 AM
