PDA
View Full Version : General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. OAI air cleaner Repop vs Original
  2. Aluminum Heads vs. Cast Iron Heads
  3. W-27 rear
  4. U.S vs Canadian built cars
  5. Oldsmobile registry question 🤔
  6. Multiplexer
  7. Who's 69 on the header
  8. What part do I need to cover this ac hole?
  9. In need of gas door and filler neck boot
  10. Help ID this radiator tank
  11. Repop window sticker...final print
  12. Quarter master film
  13. 2 1/2 years later...
  14. 69-72 Cutlass Price Point
  15. Toronado and a Airstream Had a Kid.
  16. May be moving to Virginia...
  17. 1970 442 W30 radio
  18. Newly acquired Oldsmobiles
  19. Looking for step by step how to remove and replace dash for 72
  20. 1983 Buick Lesabre Rain Water
  21. garages
  22. Stolen car video late 60's
  23. Nevada looking at classic car laws
  24. C-C-C-Cold!
  25. M21 lever color
  26. Recommendations for Improving Braking
  27. Bought new 2010 Charger R/T
  28. 1969, 442
  29. Wheel stud stripped
  30. Gear indicator 1970 supreme
  31. 1969, 442
  32. Light problem 1974 ods cutlass supreme
  33. Value of a 215
  34. Wire hookups back of the cigarette lighter
  35. Is old glass worth saving? Especially 1978 Toronado?
  36. Local Car Show
  37. need info: throttle cable hookup 68 442 with L-69
  38. Just curious
  39. Auto city classic power window install problems.
  40. 71' 442 front bumper guards
  41. Need advise for jute and carpet installation ...
  42. Buying 1st Olds tomorrow
  43. Grille badge/radiator?
  44. 72 CS BIG PROBLEM HELP PLEASE Removed one control arm and Axle moved to the rear
  45. A good laugh .
  46. Even Jeff Smith is a hack!
  47. Is there a way to get car history on a 72?
  48. 2021 Homecoming?
  49. A disclaimer?
  50. 350 Disti off 180 degree?
  51. Mecum Auction Purchase
  52. Thornton 404847 HD/ W-30 water pumps
  53. Is this right???
  54. Neighbors
  55. Type P axle from a 67 cutlass 442?
  56. 1947 Olds Woody
  57. Looking for trunk light location
  58. Anybody near ALBUQUERQUE, NM?
  59. Can someone tell me what this is on 72??
  60. Coolant reservoir option code
  61. w25 hood spring pin replacement
  62. 1956 Oldsmobile Remote Control Car
  63. Power Seat Transmission Solenoid
  64. 1966 1967 remote mirror mount drivers side
  65. 73 cowl tag decode and interior advice
  66. '69 442 inside door handle mechanism.
  67. Do you see what I see number matching?
  68. 70-442 hot spot area engine paint touch up
  69. '70 w30 thermostat housing
  70. no electric cars in the future
  71. Fair price for a 65 442?
  72. Engine Oil Supplement
  73. 68 442 OAI air cleaner ID
  74. Edelbrock closing Torrance facility
  75. gm to go all electric in 2035
  76. Dude are you serious ?
  77. Shipping Assistance
  78. Dash
  79. Header alternatives?
  80. engine install
  81. Reproduction circuit board for rally pac gauge?
  82. Help Identify This Part
  83. unrealistic oldsmobile diorama figure
  84. Need advice on best gold spray paint for valve covers on 72 350. Thanks!
  85. Need help with 1966 cutlass/442 molding clips...
  86. Parts Stores, You Must Be Smarter!
  87. Repo Window Sticker
  88. Olds P & A
  89. Vacuum line
  90. 1972 350 Delta 88 Radiator Hold Down
  91. Sport mirror
  92. Pegging the BS meter...
  93. 72 CS Installing a rear sway bar and lower control arms
  94. 1969 Oldsmobile 432
  95. 1970 Cutlass Horn Contact Kit
  96. Wing nuts for tail lights 1987 Delta 88
  97. More Wiper & Washer System Parts
  98. 1970's Oldsmobile into a wall test
  99. Seven Oldsmobile 442s Set for Saturday at Rick Treworgy's Muscle Car City Auction
  100. Steve Magnante Oldsmobile podcasts 2020
  101. Canadian Customs charges
  102. What's the story about fools and the Hurst Olds
  103. Modern OD trans?
  104. New v code hardtop
  105. Need small piece of rocker panel molding
  106. How much HP?
  107. sheet metal
  108. NOS GM AC Delco 15-4208 OW Fan Clutch EBAY
  109. G-Body Forum Question
  110. LED interior lighting
  111. Brackets - gas tank brackets
  112. SSII wheels loose on rotors - Shims?
  113. Window sticker question 🤔
  114. road course tires.
  115. 330 valve train noise
  116. Mecum 1975 H/O W-30
  117. Radio id help
  118. Non-olds question for the smartest guys around
  119. Carroll Shelby's 427 Cobra at Mecum
  120. 1968 Oldsmobile 442 Heater blows cold air
  121. 1969
  122. 4 spoke steering wheel refinishing
  123. Sad Time for Drag Racers and Fans
  124. The most expensive 1976 Ninety-Eight Regency ever?
  125. Looking for who bought a 1968 442 from Venice Florida car dealer
  126. Long time no see ! Needing a Canadian cowl tag deciphered
  127. Lead: 72 Hurst Olds Fixer Upper ebay
  128. Estate Sale - Interesting Olds
  129. Fired up Bad Martha and went for a ride
  130. Radiator swap complete 😀
  131. Core support year
  132. Crank ID
  133. 1970 Parts Book
  134. 68 to 72 bumpers
  135. Time to Clean the Battery Tray
  136. 1964 olds cutlass 330 4v
  137. fan shroud
  138. Music for the times
  139. Here's one returning to mother Earth.
  140. Summit Racing Discount Code?
  141. Changing rear ends
  142. Dash lights - 1974 cutlass supreme
  143. Vapor blast
  144. Gas tank sender repairs ?
  145. water inlet
  146. Saw eastwood opened a new store somewhat near me.
  147. OPG Front Fenders for 70 442
  148. Stud Welder
  149. 1969 442 automatic
  150. 1968 Cutlass firewall tag info. Thanks
  151. Car Show etc pictures. Please post them
  152. GM Performance Parts Book
  153. Rearranging the deck chairs...
  154. 442 4speeds vs. auto's
  155. Can someone break down this tag for me?
  156. Epicvin and car history, and the TCS
  157. 1966 vista cruiser decal wanted
  158. convertible top replacement parts
  159. Custom made maintenance book
  160. First part ever bought?🤔 (How many of you remember?)
  161. Oldsmobaker
  162. Decision on Olds Ciera International
  163. Carburetor Rebuild
  164. Factory tint versus clear glass?
  165. Not mine, 46 Olds, dont see many of these.
  166. 72 supreme windshield wiper motor detail
  167. 64 65 frame interchange
  168. 1966/67 cutlass 2 tone repro roof moldings
  169. Fusick vs. Parts Place quality
  170. Old Car Smell
  171. SPECS Booklet Funnies
  172. Stamping on side of cylinder head?
  173. Oldsmobile pro stock Intake
  174. 1965 Cutlass convertible
  175. RockAuto.com Discount Code - Expires April 5, 2021
  176. Steering Linkage Paint?
  177. Best way to fight Ethanol problems ?
  178. Question about radiator replacement 🤔
  179. 1956 Olds Super 88
  180. Motor Mount Bracket Question
  181. Need help identifying this car...
  182. W30 air filter cross reference
  183. shipping a console
  184. Who makes the most correct Floor Pan Repros?
  185. Cooling fluid missing
  186. GM Part # Lookup
  187. birthdays?
  188. In dash clock
  189. Tcs bolt with stud
  190. 2021 Cheers
  191. Happy New Year
  192. Disappointment and reality
  193. Opinions on this Auction ?
  194. 1966 442 on bring a trailer
  195. Chromer
  196. Gauges
  197. 69' H/O alternator regulator change out
  198. Car title
  199. Part ID. What is this?
  200. Rocket Power!!!
  201. What adhesive should I use?
  202. A restoration/rebuild/project of a different kind (lots of pics)!
  203. 1970 Gold stripe on Galleon Gold paint
  204. Reproduction Rear Wheelhouse
  205. Olds Lady
  206. Correct Radiator Cap
  207. Brake prop valve leak
  208. Specific Production Numbers
  209. President Reagan and his staff share a hearty laugn
  210. An Olds Poem, Merry Xmas
  211. Same Vehicle?
  212. Merry Christmas to all Classic Oldsmobile members.
  213. Merry Christmas
  214. Dick landy pro stock
  215. Holiday Season
  216. 72' Olds Body & Trans plate decode
  217. 68 Cutlass Read Quarter Window Weatherstrip
  218. Steve Ames: A Good Read
  219. Water Pump Gaskets
  220. A/C Compressor Removal?
  221. Nice Read on a lifelong Cutlass Owner !
  222. Pertronix out, Points Distributor in
  223. Rocket Racing Rocket block builds?
  224. How many Oldsmobiles built in 69 had a muncie 4 speed from the factory?
  225. 1972 Cutless Supreme Grille
  226. 69 Olds 442 Tune up
  227. Tach needs adjustment or faulty?
  228. Need a project
  229. Decent rad overflow for $23
  230. auto shift knob diameter
  231. What's the difference between "stock" and "bone stock?"
  232. 1971 Olds 442 fuel and vapor lines
  233. Hard to pass this deal uo
  234. Lets talk about this
  235. Environmentally sealed heat shrink?
  236. Suggested Lubricate for Power Window regulators and motors
  237. speedo cable source
  238. 1940 Ford!
  239. Odds of finding your car may years later??
  240. Winter Projects
  241. 350 block from what!?!?!??!
  242. Bumper ID Please
  243. Striking it RICH on Christmas Morning.....
  244. brake cables???
  245. Restored 66 dash
  246. Battle of the convertible 4 speed 4-4-2s
  247. Identify Valve Covers
  248. EGR doesn't clear air cleaner bottom
  249. Electric-powered, hybrid and performance sleeper assist
  250. Buzzing noise underneath dash, Gen light on/of
