Cooling fluid missing
Old Jan 1, 2021 | 05:44 PM
Fazer's Avatar
I seem to be loosing cooling fluid. I can't find any leaks. No puddles on the floor. The engine and transmiton fluid are the same and not milky. Any idea where it could be going. I'm a bit leery to run it till I figure it out. Any ideas appreciated. Thanks.
Old Jan 2, 2021 | 05:47 AM
Fazer's Avatar
The car is a 69 442 with a 455 in it. It has an overfill tank. I add coolant to the tank, drive the car and it is about 1/4 full. Engine cools, coolant disappears as it should, with cooling. Add some more coolant and same thing happened next time.
Old Jan 2, 2021 | 06:55 AM
VC455's Avatar
Barely Registered
Check if your coolant is leaking to the interior from your heater core. Pull up the passenger side carpet and feel for dampness in the padding.
Old Jan 2, 2021 | 07:10 AM
Funkwagon455's Avatar
Have you done maintenance that opened the cooling system? If so maybe the system did not have all of the air purged from it, and you are working coolant from the reservoir into the voids. If the oil/fluids are not milky, not running hot and there are no external leaks I would certainly not hesitate to drive it. If there is a problem it will show itself.
Old Jan 2, 2021 | 07:16 AM
Tedd Thompson's Avatar
Any excusive white smoke from the exhaust( more than condensation)? Could be a head gasket, does it heat up at all? And my last thought is the radiator cap leaking under pressure do you smell anti freeze at anytime?..... Tedd
kevdog442
Nov 2, 2020 08:20 PM
Lyle_STL
Jun 14, 2020 10:02 AM
Msatlof
Jan 21, 2020 06:45 AM
Zacc
May 5, 2018 08:27 PM
jpc647
Jun 24, 2014 10:11 AM
