View Full Version : General Discussion
- Well that was not fun!
- Preparing for winter
- Kick Panel Carpet on '70 - '72 Cutlass?
- 1970 Cutlass Speedometer Questions
- What kind of "Glue" to use to Hold Upper End of Vent Window frame inside Door Frame?
- Gauge cluster idea, worth the effort?
- th400 duel gate shifter holder
- A real Oldsmobile rocket!
- 1970 cutlass s Ignition lock replacement
- Rochester Q jet casting code
- Fire extinguisher...where do you have yours
- Glove Box Lock - 72 CS
- sport mirror
- pypes X pipes
- 70 Cutlass Supreme - new dash wood grain install question
- Heater control problem 68 Cutlass
- Did a 1972 Vista Cruiser have a hood pad?
- .040 over 10.50:1 forged flat tops for W31
- Mcacn
- Missing Mirror Map light question
- 64-65 manual shift, shifter boot information needed
- Broadcast card info
- Is 1955 Olds faster than the rest ?
- How easy (or dumb) is it to swap a split bench into a Vista Cruiser?
- Pax side mirror
- Engine Dyno Recommendations
- Lights upgrade need help
- Engine/ fuel additives
- Fuel in Oil?
- Need Horn Help
- can anyone take a picture of the tip of their 68-72 Cutlass or Vista Cuiser hood?
- Transporting a Convertible tub ideas
- Door won't open
- Generator light
- date coded side glass for 70
- 1967 Cutlass outside mirror glass
- Christmas Present Suggestion
- Does anyone have access the 1970 Olds Color and Fabric Album or Dealer Trim Books?
- Just wanting to know what you guys think
- OK to drive
- 1972 Cutlass supreme Steering Wheel Mystery
- From the 60’s childhood
- Did Blue Interior 1972 Vista Cruiser come with Blue or Black Seat Belts?
- Chrome emblem restoration
- 1962 slim jim trans
- Be wary of Oldsrocketparts
- Question about 1965-70 full sized speedometer cable
- Finally got my 442 home
- Forgive my gripe, advice needed.
- 67 Toro Front Wheel Bearings
- Help id'ing an olds v6
- Are plastic window roller guides/ bushings pressed onto the stud in 1972?
- Positive for seller RocketDevo
- Holley 4160 rebuild ?
- Observation of floorpan drains, 1970 Delta 88
- Dynomax Super Turbo
- possible last ride??
- Interesting OAI Hood
- 1966 A body Roof Drip Moldings
- 1983 Hurst Olds car chase
- 411961
- 1972 door lock question
- 1971 Cutlass AM/FM radio with amp.
- Best tool for "jacking up" a gas tank
- SS1 Wheel Restoration Question
- Is this for real?
- bitch'n 66 442
- I have play in my Wagon's door hinge pins. Should I replace them?
- Oldsmobiles at the Veteran's Day car show
- Is my car real?
- Non-OAI base with OAI upper assembly
- headlight bezels 1967 442
- 1970 first generation trunk lid
- Reproduction lock set
- 1977 Cutlass H/O Prototype...1 of 1 ??
- 1968 Cutlass Supreme Wheel Question
- 70 442
- Help, gangsta lean
- Might have messed upy hinges...
- Road Trip!
- What kind of repair to get home
- Cutlass emblems
- Value of fun 1977 Olds 442 Project
- A few rare muscle cars. Worth the time
- trim rings
- Question
- Clutch Pedal Squeak
- What's the difference between "stock" and "bone stock"?
- Attaching an electric Dual Fan
- Front springs
- 1970 W-30 fender wells / liners value ?
- Muscle Car and Corvette Nationals IX / MCACN 2017
- Best tires for my 72 cutlass
- Car cover question...
- Evil Knievel's Vista Cruiser
- Lost one of my best friends today
- Question about drilling holes to add a passenger door outside mirror.
- Need info from 1972 dealer's trim or complete information books for trim code 43 blue
- FiTech fuel injection system question.
- Back in an Olds after all these years
- 67 400 engine build
- Interior Trim Codes for 1967 98
- Help with trim tag
- Toro vacuum hose routing
- Olds Dealer
- Running ELECTRIC rad fan??
- Chilton manuals
- 72 Cutlss Supreme
- Disc Brake Dilemma
- 65 442 holiday
- Odd throttle problem
- 1970 W-30 442 Convertible Authentication
- Automobile Driving Museum
- Hickory North Carolina
- Th350 detent cable location, HELP
- 1964 Olds F-85 4 door, barn find
- brackets!!
- Shift rod 6005
- How many Jetfire's do I need?
- water leak
- trim tag
- Am I doing this right? I'm trying to adjust the door gaps on my 72 Vista
- Eye test
- 1970 Emblem positioning
- 68 442 article
- Olds museum opening 2018
- 68 Ramrod Water Pump & Pulleys
- 425 engine/rear end swap/ update on me
- A/C Delete
- Need Help with Genuine 1972 Cutlass Seat Fabrics for my Vista Cruiser
- Nuclear Headlights!
- New to me 1983 Oldsmobile 98 Regency Coupe! 307 V8, 58K miles
- Temperature Warning Light
- Looking For Tach Ideas
- Is it over?
- 1972 Cutlass with cruise Alt bracket
- Another Odd Vista Cruiser question about identical dents on both rear doors
- Re-pop trunk lid
- Oldsmobiles For Sale At Hershey
- Cool Racer - W-30 at MCACN
- New Tubular Headers 400-425-455
- Score of a life time just happens to me
- Help Decoding 70 442 Trim Tag
- Sun distributor machine.
- 12 Bolt Open to Posi?
- gray paint for jack base and hook
- 69 Olds Delta 88 Rear Window Trim Help
- Does anyone know if this molding could belong to my '72 Vista Cruiser?
- 1970 442 brake proportion valve
- 1970 442 Convertible
- Seat belts for 1957 Olds 88 sedan
- Just received my score report Concours d Elegance
- The answer to the question no one asked???
- 4 speed or auto trans?
- Tune-up procedure! Please add your thoughts
- New Thornton B/B headers.
- Can anyone ID this battery tube?
- main & rod bearings
- Bastrop Car Show
- Help needed to indentify Q-jet
- 1969 Cutlass 442 TH400 coolant line question
- Brake Pedal Height
- Plaque for a boat?
- Calif. black plates
- Worst / ugliest Oldsmobile EVER!
- advantages of bigger/smaller Pulleys
- Price for a set of nos 71/72 fenders
- Auto Transport Available WI/IL to CO, or WI/IL to PA
- Been gone for a while
- Smog Due/Adjustable V-belt
- 1967/1968 Steering Wheel
- Cool "Old"s picture
- 1970 442 brake light in dash
- Tubular control arms
- Road Trip
- Anyone remember Erik and his brother w/a Vista Cruiser?
- does a vista cruiser tailgate interchg w a buick sport wagon?
- R.E. Olds museum offered chance to buy its building from Lansing for $2
- 1972 Vista belt line trim and roof wing questions and need front fender trim
- NOS flywheel
- car capsule storage bag
- 350 push rod selection
- Door Hinge rebuild/replacement 70 Cutlass
- 1941 Ignition coil
- Winter Storage
- Local car show
- 66 cutlass motor problems/broken rocker arm
- Rear window trim HELP
- Its always fun to visit other members
- Lion's Club Car Show
- Does anyone rebuild there own Water pumps
- Correct coil mounting bracket for a 69 cutlass and 442?
- Dr Olds Mileage Machine
- 1970, 1971 SS1 P05 wheel production volume? Cutlass
- Aftermarket Fog light issue
- Tilt steering
- 1965 442 4sp. Neutral safety switch
- Trunk lock 1970 coupe 442
- Soon, Very Soon. I can not wait!!!
- Thought this was cool
- cutlass 68 swap 455
- electric fuel pump
- Batavia Bound!
- Anyone have 68 to 72 Wagon or Cutlass Sheet Metal for LEFT Rear Wheel Opening?
- Spiffing up raised white letters (Coopers)
- Insurance Question
- Fuel gauge pegged past F
- Did Linden NJ plant build Cutlass 442?
- 71 cutlass trunk gutters
- Ordered carb from quadrajet power
- Quick Jack
- SX ...help!
- Carlisle
- A/C Evaporator pressor testing
- Convertible Owners!
- Tic-Tac-Clock face replace
- TSC switch
- Hurricane Harvey flood damaged cars Video
- Opgi 48 hr wheel sale 10/3
- 1970 cutlass front Brake drum – wheel bearing size
- aluminum radiator
- Does anyone know if the shifter linkage is off of?
- Gifts
- 72 Cutlass 4-Door What Is It Worth
- Barn Finds 61 F85 wagon
- California Democrat Proposes Bill to Outlaw Gas-Powered Cars After 2040
- 71 cutlass convertible trunk lid
- '70 W-31 Rear Axle Ratio Question
- 1970 sx
- Correct acceleration cable length for the 72 cutlass
- electronic points timing
- 455 hemi olds
- I should have bought stock in ATF and Antifreeze!
- Oldsmobiles at Fall Carlisle on Thursday
- Attention ***firefrost gold***
- Cooler fittings the thread the same between a TH350 and TH 2004R?
- How rare is a 350 W-31 intake
- What is this?
- Side Door Glass
- Alberta Oldsmobile Show 2017
- Rock Auto closeouts
- 68 Hurst Olds what is correct Distributor number
- 71-72 bumpers
- looking for Sal Spina
- Where to start?
- "cutting edge" cutlass
- A/C heater fan ??
- Alternator fan & pulley finishes
- 83 H/O toy cars
