How rare is a 350 W-31 intake
Old Sep 29, 2017 | 04:25 PM
willysman's Avatar
ltownrodder
I have a chance to pick up a 70 350 Olds W-31 aluminum intake for my car. The guy want's a good bit of money ........but everyone tells me that they only made so many for 70. Id like to know about how many of these intakes were produced and what you guys think it is worth.??? Thanks
Old Sep 29, 2017 | 05:11 PM
junior supercar's Avatar
depends on what he and you think "a good bit of money" is.
condition plays a big part since they are aluminum. anything over $600-$650 and it better be perfect
Old Sep 29, 2017 | 05:27 PM
willysman's Avatar
ltownrodder
He said that it has never been messed with (fixed) is very clean and all the holes are right. He said he has to have 700 no less.....
Old Sep 29, 2017 | 06:17 PM
jensenracing77's Avatar
If it is real nice with no welds then $700 is not out of line at all. If it is a 69 or 70 date code helps the price also. That intake was only on the 70 W-31 but was made all the way to 1977 and sold over the counter. The 69 and 70 have a smaller water port on the back corner than the ones made after 70.
Old Sep 29, 2017 | 06:32 PM
willysman's Avatar
ltownrodder
Thanks for getting back to me. He said that its never had any problems as far as repairs or stripped threads. He also said it was date coded to 70. Thanks for the info....I will check out the water port when I get a chance to see it.
Old Sep 29, 2017 | 07:14 PM
zeeke's Avatar
A while back on this site I offered someone $500 for one that needed a real good cleaning, very black and oxidized. He got an offer from someone, I think in BC for $700. He gave me the option to counter since I was the first contact but I passed. If it was clean I would have paid him $700 but the effort to clean it wasn't worth it for me.
I actually picked up a late model one from a CO member a few months back for somewhere around $100 shipped. I didn't do the homework yet but my guess it was off an 80's 442 or H/O. If it works I'll use it on the 70' 350 I took out of the 71' Cutlass when I get to freshening that motor up.
Old Sep 29, 2017 | 07:30 PM
willysman's Avatar
ltownrodder
Zeeke......Thanks for the info. I guess I will check it out next week at Hershey. The guy didn't have it with him at Carlisle but said he would bring it next week. He said it was VERY nice...so I guess we will see. Maybe I will post a photo next week if I get it.
Old Sep 30, 2017 | 10:45 AM
Unless you have a real W-31, don't waste your money. The only difference between a W-31 intake and any other stock intake is the weight. Runners are exactly the same. There is no performance benefit.
Old Sep 30, 2017 | 07:17 PM
anthonyP's Avatar
Very interesting, I never knew there was difference between the production and later cast aluminum W31 intake manifolds.
Besides the Oldsmobile-455 and Olds-455 casting differences, are there any other differences between the 70-72 W30 intake manifolds?
Old Sep 30, 2017 | 07:29 PM
zeeke's Avatar
The intake is for a 350 motor not a 455. The W-30 had a 455 which has a W-455 on the front of the intake. The W-31 is for the 350. It was on the 70' Raley 350's and and I believe the W-31's which has a W-350 on the front of the intake.
Old Sep 30, 2017 | 08:17 PM
70Post's Avatar
Only originally installed on '70 W31s.....not on Rally cars (they got the regular cast iron intakes).
Old Sep 30, 2017 | 09:50 PM
stevengerard's Avatar
that's the most obvious difference and of course the date stamp on the underneath of the manifold. Other than that I'm not sure if there are any differences in ports or other stampings.
Old Oct 3, 2017 | 07:20 PM
willysman's Avatar
ltownrodder
Originally Posted by joesw31
71, 72 W-30 intakes have a large letter "A" by the front runner. They also carried a different part number.
Now for the W31 intake, they carried two different casting numbers. As explained the heater fittings may be different size between the two intakes. I also believe that there is a large letter "A" by the front runner. The change between the castings numbers was made in April 1970.
Thanks for the info. I just talked to the man with the intake and he said it has a date code 1969 on the bottom. Thanks again.
Old Oct 5, 2017 | 05:09 AM
willysman's Avatar
ltownrodder
Old Oct 5, 2017 | 05:12 AM
willysman's Avatar
ltownrodder
Right carb for 70 w-31
Off hand does anyone know the correct Quadrajet carb (number)that is on the 70 W-31 350 engine.
Old Oct 5, 2017 | 05:31 AM
7040255 and if it is not a restamp it is worth between $1000 and $2500 depending on condition and date. If it is a restamp it is near worthless.
Old Oct 5, 2017 | 09:43 AM
willysman's Avatar
ltownrodder
I have a 7040250 on my car right now. How much difference is there from my carb to the w-31 7040255?
Old Oct 5, 2017 | 09:48 AM
A LOT. The most fundamental difference is that the W-31 cam didn't pull enough vacuum to properly operate the power piston in the Qjet. As a result, Olds deleted the power piston and primary metering rods in the '255 and went to smaller fixed primary jets.
Old Oct 5, 2017 | 09:51 AM
If you have a stock cam and not a W-31 then keep the 0250. The 0255 is built for low vacuum. The 0255 has no primary metering rods and the jets are smaller to work without them. If you don't have a W-31 and need original numbers then your 0250 can be built to whatever you need for the engine you have.
Old Oct 5, 2017 | 09:52 AM
You beat me
Old Oct 7, 2017 | 09:07 AM
willysman's Avatar
ltownrodder
Thanks again for the info.....I think I'm
going to have Sparky's redo my carb
GAOldsman
Mar 25, 2012 12:29 PM
rallye350
Sep 9, 2011 04:49 AM
svnt442
Jul 17, 2011 04:43 PM
Aussie67Delta88Custom
Nov 17, 2007 07:36 PM
