How easy (or dumb) is it to swap a split bench into a Vista Cruiser?
I got a good offer on a front split bench seat from John, but it is for a two door. Are there any differences between a two door split bench seat and a 4 door split bench aside from the seat back tilting forward? In particular, I'm not sure if the seat height, depth, width or some other important dimension would be different and then maybe I could have trouble with the cargo floor panels that are supposed to neatly fit together with the folded 2nd row seats to form a flat cargo floor?...
Also, was there a split bench option for a Vista Cruiser and how common was it?....
First, a "split bench" is a bench seat that is physically two parts that can be adjusted individually - basically two wide bucket seats that touch in the middle. These were options on later Oldsmobiles, but not 1960s cars.
What you are talking about is simply a bench seat from a two door. No, these were never installed in four door cars. Dimensionally they are identical to a four door bench and are interchangeable from a mounting and fitment standpoint. Frankly, a two door bench in good condition is probably worth more than one for a four door.
Thanks for explaining the terms Joe. I had heard it so often here, that I made the false assumption that's what they meant.
So, do you see any down-side to installing a 2-door bench seat? The lucky thing for me is that this one it apparently fairly worn and I can afford it and it's making the trip from Oregon to me along with a bunch of other parts, so it's the right time for me to restore it before I would have done my 4 door bench anyway...
So, do you see any down-side to installing a 2-door bench seat? The lucky thing for me is that this one it apparently fairly worn and I can afford it and it's making the trip from Oregon to me along with a bunch of other parts, so it's the right time for me to restore it before I would have done my 4 door inch anyway...
While the bench seat halves won't fold flat, on the 68 Vista I had in college I installed buckets. The passenger bucket would fold flat, which allowed me to easily carry some very long items. You could fold the passenger bucket and the passenger side of the second seat and still carry two people in the back seat.
Wow. I didn't even think about that. You'd be able to carry VERY long pieces. Thanks.
It looks like I made another mistake in describing the seat because it IS the bench seat with the arm rest. The only problem is the arm rest is missing and it's fairly rough. I'm wondering how easy it will be to find the center arm rest and how much more work it will be to fix all the foam on this one?...
"fairly rough" I guess so!! Right after I bought my vista I went to the Olds Homecoming and there was this Bench seat for sale for $10. I bought it and cleaned it up and put it in my Vista. It is a 2 door bench with center arm rest. It fits great and now I have a arm rest. I'll bet you can get a better seat than that one ! Maybe from Scott!
Thanks, Tom
4-ever-olds
Nov 14, 2017 05:56 PM
