67 Toro Front Wheel Bearings
Old Nov 9, 2017 | 05:30 AM
tds's Avatar
tds
Does anyone have experience replacing the front wheel bearings on a 1967 Toronado? On Part # 907770, the bearing is larger that the opening. Is the outside band just to hold the assembly together, and to support the bearing while being pressed in? Thanks for your help!!
Old Nov 10, 2017 | 07:38 PM
cherokeepeople's Avatar
the 66 used a huge double ball bearing,but i believe the 67 went to 2 roller bearings bottom to bottom so the outer band so to speak would be the outer race.
Old Jan 23, 2018 | 10:24 AM
tds's Avatar
tds
Problem solved! Someone changed the spindle/hub on my 1967 Toro with one from a 1970 Toronado. Front wheel bearings are different for the 1967 and 1970.
Old Nov 12, 2021 | 12:08 PM
SL1's Avatar
SL1
I believe the 66-68 used the single large bearing. 69 and up went to the double bearing with the spacer in between.
Old Nov 24, 2021 | 06:45 PM
75royal88's Avatar
i just had to change the spindles on my 1971 toronado.
SL1
Oct 23, 2022 01:30 PM
MANIC2020
Jan 23, 2009 04:10 AM
Cranbrook
Aug 27, 2008 04:27 AM
Cranbrook
Jun 3, 2008 11:21 AM
Andrew240
Dec 22, 2007 01:54 PM
