67 Toro Front Wheel Bearings
Old November 9th, 2017, 05:30 AM
tds
tds's Avatar
Does anyone have experience replacing the front wheel bearings on a 1967 Toronado? On Part # 907770, the bearing is larger that the opening. Is the outside band just to hold the assembly together, and to support the bearing while being pressed in? Thanks for your help!!
tds is offline
Old November 10th, 2017, 07:38 PM
cherokeepeople's Avatar
the 66 used a huge double ball bearing,but i believe the 67 went to 2 roller bearings bottom to bottom so the outer band so to speak would be the outer race.
cherokeepeople is offline
Old January 23rd, 2018, 10:24 AM
tds
tds's Avatar
Problem solved! Someone changed the spindle/hub on my 1967 Toro with one from a 1970 Toronado. Front wheel bearings are different for the 1967 and 1970.
tds is offline
Old November 12th, 2021, 12:08 PM
SL1
SL1's Avatar
I believe the 66-68 used the single large bearing. 69 and up went to the double bearing with the spacer in between.
SL1 is offline
Old November 24th, 2021, 06:45 PM
75royal88's Avatar
i just had to change the spindles on my 1971 toronado.
75royal88 is offline
SL1
October 23rd, 2022 01:30 PM
MANIC2020
January 23rd, 2009 04:10 AM
Cranbrook
August 27th, 2008 04:27 AM
Cranbrook
June 3rd, 2008 11:21 AM
Andrew240
December 22nd, 2007 01:54 PM
Quick Reply: 67 Toro Front Wheel Bearings
