How to remove 1967 Toro front wheel bearings?
How do you remove this bearing without destroying it? Only replacement bearings that I can locate are WJB brand (China)- anybody using these? These are on a 67 Toro with factory disc brakes. Thanks-Steve
Pressing the hub out is the only choice. I put a heavy towel around the bearing just in case it decided to come apart but it didn't.
I have service replacement seals for the knuckle if you need them.
Thanks for the replies.
RE: Hairy Olds: did you replace your bearings with something else or re-use after inspection? The China bearings look a little different especially the built- in seals. Thks Steve
I can't press out the hub without holding back on the bearing. There is nothing on the bearing to hold onto because the end of the bearing is recessed into the bearing retainer, and I don't think the bearing retainer is strong enough to pull the bearing off/ press out the hub. The shop manual shows a GM tool BT-6702 used for this but of course is nowhere to be found. Anybody???
1968 Toronado with same problem
This thread is a bit old but I had the same problem. I bought the tool to pull the bearing from that outfit in California that restores old GM Rvs. It turns out that they are from 72 and later and is too small. To make a long story short, a nine inch grinder with an abrasive disk on it and a dremel tool with cutting disk did the trick. I found the 68 bearings on eBay and they seem to be quality. The foto looks exactly like the 68, but that doesn’t mean it is…Mark
Thanks for the reply Mark. I think 67 & 68 are the same bearing. My bearings weren't bad with 67k on them so I cleaned them up best I could and re-used. I bought the new WJB bearings anyway for the future. Without that special GM tool, it looks like the bearings have to be destroyed for removal, far as I can tell.
I got two of them from a guy here in Az. I posted about this in my thread about the rotors. It might be right below this thread. I thought that I had discovered a cache of them but I bought two of his last three. He still has one. I also posted an outfit that has the Eldorado rotor, but it needs some machine work for the Toronado lug nut pattern. It would need a beveled ring milled for the center hole because it is slightly bigger. Otherwise, I have not been able to find any, when I have looked…Mark
