PDA
View Full Version : General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. OBD2? scanner
  2. Dissecting an Accumulator/ Receiver Drier for G body
  3. Convertible Top
  4. Question about 1969 A-body column shift arm
  5. 70 W-30 4 speed.
  6. Mondello's V.O. Twister II restored (interview)
  7. Does this come off
  8. 97 s10 wont start when hot
  9. 1955 Cadillac A5 compressor seal rebuild
  10. Vin lookup
  11. 330 Olds into a 1982 Cutlass Supreme
  12. Gas Cap
  13. 67 442 video
  14. 69 post coupe rear bumper ?
  15. Small block identification
  16. Wider tires means I need a longer J-hook for the spare - Suggestions?
  17. Alaska bound!
  18. Glove Box Lamp
  19. 1972 A body differences?
  20. Looking for a good body shop and a good upholstery shop around Denver
  21. Rookie restoration question
  22. 1970 cutlass post coupe
  23. R4 Compressor Low Pressure Switch experiences for 1979 Cutlass
  24. Any AC install of new compressor tricks 1979 Cutlass
  25. Any experience with R4 AC Compressor new Scroll type?
  26. Extremely rare parts on non-stock / resto-mods
  27. No low end torque after switching from 2 bbl to 4bbl.
  28. Vending at Oldsmobile Quad States
  29. Aftermarket gauges
  30. Remember to tighten up lug nuts
  31. 1970 Delta 88 Royale
  32. Transmissions first to second generation 88
  33. 1970 Dealer New Car kit
  34. 1st and 2nd generation crankshaft question
  35. Slotted chrome nut frustration
  36. License plate surround.
  37. Under hood "hissing" that sounds like a vacuum leak
  38. 66 442 how to tell for sure
  39. What is the market for 64 Starfire parts?
  40. Oh that rustic look!
  41. Ballpark value of an engine I need to sell
  42. They are listening!
  43. 19th Annual All Oldsmobile Fall Show, Downingtown,PA, Oct 8, 2023
  44. Power Steering Washer ( link to pump) thickness?
  45. kendrick meyers oldsmobile
  46. Auto Seat Upholsterer in the Augusta, Ga area?
  47. engine code decipher
  48. Headlight upgrade for 4 bulb system
  49. UPS Simple Ship
  50. ID another molding
  51. Interior Trim Codes
  52. Jetfire Turbo Engine For Sale
  53. Mystery Hood
  54. 1966 Oldsmobile '88 Steering Wheel Button Chrome Strips
  55. Chassi number
  56. Anyone near Cynthiana, KY?
  57. Delta 88 wheel stud question
  58. Rochester 4MC question
  59. 403 Crankshaft has been modified but rod bearings don't fit
  60. Q-Jet ID
  61. 70 442 W30 convertible at auction
  62. 1970 Custlass Supreme
  63. Cowl screen
  64. Gas tank color
  65. Brake lights sticking
  66. 1967 Oldsmobile 98 steering column play
  67. What happened to this guy?
  68. cup holders 1970 442
  69. W-30 auto carb
  70. Clinton area rod club
  71. Exhaust systems
  72. Timing not staying put
  73. Midlothian Classic Wheels Cruise in, Waxahachie TX
  74. Repair broken diecast trim studs: is there a way?
  75. Documentary - Detroit: The City of Hot Rods and Muscle Cars
  76. Milodon headers
  77. Driving an Oldsmobile is...
  78. End result
  79. My trip to Lansing
  80. How does one attach a radiator tag 🤔?
  81. Big small block starter bolts
  82. QuickJack, anyone?
  83. Cataloguing & inventorying our spare parts
  84. 68 Cutlass build sheet
  85. Steering wheel
  86. Tire Kickers look here!
  87. front fender inside markings questions for 70 W31.
  88. In search of 68' 442 Convertible
  89. sweet 31
  90. 1966 Olds 98 Convertible Fender Skirts
  91. 8 track player
  92. ***UPDATE***8/13/23 - I Found my SX!!!
  93. Denver members Fairmount Car Show
  94. Sweet 70 SX I had the pleasure of taking care of recently
  95. Anyone know this car?
  96. Multispeed delay wiper upgrade
  97. Ginny's Frozen Custard Car Cruise, Barnhart. MO
  98. Just sharing a pic or two
  99. Olds 215 Engine Oil Pan Bolt Torque Spec
  100. 1969 432? Who knew…
  101. Craig5859
  102. OCA National Pics
  103. Which letter exhaust manifold?
  104. Tool to remove oil pan drain plug 1961-65
  105. Stock 14x6 wheel
  106. lacquer paint
  107. Best way to attach a radiator tag?
  108. 1967 trac pac 400 small block ?
  109. Keys cut at Nationals
  110. Front window adjustment
  111. 1969 442 Pictured on the Classic Oldsmobile Site Page
  112. 1980 Quadrajet
  113. 1970 cutlass parking light wire clip
  114. Transmission
  115. Anyone else fighting?
  116. Rearend Cover for a 1969 Cutlass
  117. Which heads to use on 455
  118. 69 cutlass convertible boot install
  119. 442 trunk battery
  120. 72 Olds Cutlass Firewall
  121. Rally Steering Wheel Question
  122. W25 air cleaner
  123. 71 ‘vert 442, 16k miles not mine. Sold new at General Sales West Chester PA
  124. 66 cutlass forum?
  125. 1970 Fender extension retainers
  126. posi rear
  127. Olds on Apple Music
  128. Oldsmobile Speedometer Thermometer
  129. 350 Rocket Question
  130. Header ID?
  131. 1968 442 or HO questions
  132. Hood pins
  133. Not important, just kind of humorous
  134. F-88 Concept at Auction - August 17-18
  135. 61 Dynamic 88 bubble top no post
  136. Flattened cam lobe or collapsed lifter
  137. 1967 Cutlass Deluxe Top of Door/quarter Trim
  138. 1972 Cutlass Supreme trunk lock
  139. Do I have a Rare Cutlass?
  140. Does anyone know when Oldsmobile stopping doing the little dealer promo model cars?
  141. 1971 Cutlass Supreme Door Glass Replacement
  142. high speed engine halting
  143. 1930s OLDSMOBILE Accessory Dash Clock
  144. 1970 fender to door alignment question
  145. 1962 Starfire steering wheel
  146. Interesting doo dad. Key fob?
  147. Correct head gaskets G block
  148. 1966 Olds Dynamic 88 Battery Housing
  149. Steve Mags Does the 1964 Jetstar 88
  150. Car show luau
  151. I Do Cars on YouTube
  152. Head ID 7A
  153. Water pump I.D.
  154. Here we go again, electrical problem?
  155. Non-A/C '70 CS Under Dash Ductwork Woes
  156. Broke a rocker arm bridge
  157. No oil at rockers
  158. Dayton C.O. meeting
  159. 1953 Super 88 power antenna
  160. Warranty on batteries?
  161. Carb tit
  162. AeroTech Go-Kart on Bring a Trailer
  163. Found a neat dealer plate at a local auction.
  164. Trying to I.D. blocking cast #...
  165. Atco Dragway Closed for good :(
  166. aftermarket ss1 rims
  167. Anyone know a reasonable LTL shipping alternative
  168. Behind the Scenes - '71 Oldsmobile 442 W30 Convertible
  169. Cutlass S or Supreme? Which way to go?
  170. Top 10 Most Overrepresented and Overrated Classic Cars at Car Shows.
  171. US Marshals scam is a real threat to elderly
  172. 72 Cutlass Supreme Interior Paint/Dye Color
  173. Why I have become tainted with shows
  174. Cruise Night Oldsmobiles
  175. Need to make some AC Brackets. Any Suggestions?
  176. Big Car Radio Bracket?
  177. Syracuse Nationals 2023
  178. A Muscle Car With Three Names - 1964 Oldsmobile F-85 Cutlass 442
  179. 3" exhaust for 1971 olds 442
  180. Road trip and a car show all in one😀
  181. How about an Olds powered tank/gun carrier
  182. Manual found for my olds ?
  183. 1972 Olds 98 - Body Service Manual
  184. “OLDSMOBILE” AM radio plate
  185. Looking for Windshield trim Compatibility for ‘78 Delta 88
  186. How much does a small block Olds engine weigh?
  187. Oldsmobile Service Lighted Sign
  188. Loose Gas Pedal - 69 Olds 442 - How to stop it sliding off?
  189. Quadrajet with strange stamping
  190. GM A Body interchangeable parts ?
  191. Pulley sizes
  192. Does Number Matching Matter for Vista Cruisers?
  193. frame restoration
  194. Need Eight Track Player repair recomendation
  195. Nylon teeth timing gear
  196. Rearview mirror identification
  197. Rust on roof/ceiling -interior
  198. 1969 vs 1970 442 Coupe Rear Seat Frame-Bottom
  199. Intake manifold oil leak
  200. Need help with mystery Olds. 1973-1974?
  201. 1936 Oldsmobile pickup? Factory or homemade?
  202. Don’t Drive on Old Tires
  203. In search of
  204. Tripower filter question?
  205. HEI vs CD vs Points ignition
  206. A nice day in Northern Oklahoma
  207. 2001 Bravada lift gate question
  208. Dash face plate replacement
  209. 44 yr old Omega with less than 500 original miles.
  210. Oldsmobile V5 Diesel
  211. 71 Vista windshield
  212. Speedometer
  213. Learned the hard way today...
  214. 69-70 hood stripe kit question
  215. 1970 Oldsmobile what ? What is this ?
  216. Engine tuneup
  217. Re-Webbing Seatbelts
  218. Headers that didn't quite fit...
  219. Got my new personalized tag today!
  220. 1970 Cutlass speaker fader knob - questions / help needed
  221. "Clunk" when downshifting
  222. Fox Lake Mopars at the Park
  223. 1970 Oldsmobile Olds 442 Pace Car Convertible 455 CI Engine & Ride - My Car Story wit
  224. Not One Oldsmobile
  225. 72 442 w30 convertible
  226. Is this true?
  227. Calling all Qjet Geeks: Measuring Power Piston Spring Lengths & Strengths
  228. Ignition cylinder ID
  229. 68 Cutlass Convertible HVAC wiring
  230. Identify dual snorkel air cleaner
  231. 1968 Juneau Gray 442
  232. Fuel choices
  233. No "COLD" light on startup - some possibilities & the fix
  234. Fender Vents and Hood Vents / pictures / ideas
  235. Middletown cruise night
  236. 1961 lincoln continental Pickup?
  237. McHenry Cruise the Moose Olds Night
  238. 70-72 OAI fender braces
  239. What color did Oldsmobile paint there irrigation and marine engines?
  240. 70 cutlass hood latch area
  241. 40s 50s GM Parts Book ID
  242. 251 carburetor restoration
  243. lost some antifreeze
  244. Dual gate and kick down switch
  245. Brake Drum - 2037R
  246. 1974 omega worth it?
  247. Flywheel teeth worn to nubs
  248. Car Show, Evansville, Pine & Co. 6-18-23
  249. 1969 cutlass s convertible
  250. Another dip stick question
