GM A Body interchangeable parts ?
Hollanders is unfortunately not a comprehensive document. For example, Hollanders shows that only Cutlass disc brake spindles can be used on a Cutlass. Keep in mind that the Hollander interchange database was developed by reports from wrecking yard operators, so it's about as accurate as the Olds FAQ. Fortunately, Hollanders is conservative if anything - it usually won't give you wrong info but it won't necessarily give you ALL the interchanges possible.
I had a Hollanders but experience and other sources augment that. For example, we know that all 1964-72 front spindles interchange, though early ones have smaller bolts that hold the steering arm in place. Hollanders does not point this out.
There is one available for free download here;
1966 Olds Parts & Acc Price Schedule (Reference Interchangeability) - ClassicOldsmobile.com
You can get GM part numbers from these two free downloads;
Thru 1975 - Oldsmobile Illustration Catalog - ClassicOldsmobile.com
Thru 1975 - Oldsmobile Chassis and Body Parts Catalog - ClassicOldsmobile.com
Yes, the Oldsmobile Parts and Accessories Parts Schedule.
Spoiler
