Flattened cam lobe or collapsed lifter
Old Jul 31, 2023 | 08:05 PM
Donaldbabineau's Avatar
I was driving my 71 c20 up a steep grade at low speeds and noticed a clattering from the engine. I pulled the valve covers and noticed the #6 exhaust valve was only lifting about a third as much as the rest. I tried tightening the rocker an eighth of a turn and the motor wanted to stall so I backed it off to where it was. Other than the noise and a little bogging going up the hill, the truck runs really well with good power at highway speeds and on flat terrain at lower speeds. I drained the oil and ran it through a coffee filter, shined a flashlight on the oil, and checked the drain plug and bottom of the drain pan for metal. There was nothing but oil. I didn't pull the filter and cut it open. So my question is wouldn't there be metal in the oil if it was a flattened cam lobe? Could the problem be a collapsed lifter? What else could cause the lack of lift?
Old Jul 31, 2023 | 08:11 PM
66SportCoupe's Avatar
Check the lifter or possibly a flat cam lobe.
Old Jul 31, 2023 | 08:22 PM
This^^^^^^ Is it a SB or BB
Old Jul 31, 2023 | 08:30 PM
It's a original stock 350. Is there a way to see the Cam lobes without pulling it? I know you can see some of them on a 455 through the valley.
Old Jul 31, 2023 | 08:32 PM
If you pop the intake and run the cam and pull the lifters you'll find it. What oil have you been running in it?
Old Jul 31, 2023 | 08:39 PM
15-40 diesel, but I haven't had the truck long. It only had only been driven about 1,000 miles since 2005 based on the receipts that came with it.
Old Jul 31, 2023 | 08:41 PM
Difficult to tell then. Engine may need to come apart to diagnose.
Old Jul 31, 2023 | 08:47 PM
Yeah I expect at least the intake will need to come off and the lifter pulled to inspect. I know what to look for if the bottom is worn. I don't have experience with a collapsed lifter. Is it easy to tell if it's collapsed?
Old Jul 31, 2023 | 08:52 PM
If it's collapsed it will not have the plunger near the top of the lifter.
Old Aug 1, 2023 | 05:59 AM
Sugar Bear's Avatar
Is the bottom of the rocker torn at the pivot ball? Is the pushrod bent? If both are ok it is most likely a bad cam lobe.
Jautuori
Apr 12, 2022 04:39 PM
Smitty275
Jul 20, 2014 03:23 PM
VI Cutty
May 16, 2014 07:19 PM
Sampson
Feb 2, 2014 03:45 PM
jvock6
Aug 4, 2012 06:16 PM
