PDA
View Full Version : General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. Father’s Day
  2. 1971 442 W-30 ‘vert sold, wow...
  3. I noticed that Innline Tube sells a repop metal dash to dash padbracket
  4. 68 to 72 notched valve covers ???
  5. Wheels
  6. YOM License Plate
  7. Bringing My Baby Back to Life
  8. 70 Cutlass U-Joint replacement tools
  9. 72 Battery tray
  10. Frame Type
  11. 69 DR Oldsmobile Ads ??
  12. Question about N94 wheel covers
  13. Olds Article in Hemmings
  14. Street Demon Carburetor
  15. Shout out to members in Boulder CO area ..
  16. 72 Headlights - High Beam
  17. 1970 Olds dash vinyl
  18. Carlisle ?
  19. Turn a 350 over by hand
  20. Door panels
  21. Type o 3.42 ring and pinion
  22. Help... 70' 455 engine color
  23. Help with power bench seat removal
  24. Master cylinder push rod
  25. Posi or ltd slip
  26. very loud exhaust leak on my '69 442... need advice...
  27. 65 cutlass 442 shark fins
  28. Cleaning Vinyl Seats
  29. Timing and carb 350 olds
  30. Body Mounts
  31. My sister’s daily walk, central New Jersey
  32. Save on Fuel Injectors, Sensors, Spark Plugs & More at RockAuto!
  33. Who's Olive (?) Green '68 442 'vert w/ Red W36 Stripe Did I see 6/11?
  34. 1965 cutlass 330 4GC carb float heighth...
  35. UMI Performance Sales Schedule
  36. Cool Poncho Wagon
  37. You guys get this?
  38. 1969 15 X 7 steel rims for A body
  39. Power top switch
  40. Harmonic balancer
  41. 1969, 442 Alternator
  42. Are really all cars after 1971 slow?
  43. 1967 442
  44. When did this become a thing?
  45. bumper jack 71 cutlass
  46. 200R4 TV cable hook up
  47. Drivability and Safety
  48. 1974 442 ?
  49. Wheel well trim covert vrs hardtop
  50. Uh oh! Idiots at Sam's Club.
  51. Soo many questions
  52. What model should I title a 72 H/O to?
  53. 1964 oldsmobile super 88 best oil to use and what fuel is best for this year.
  54. Private car ownership is back!
  55. Convertible top cost
  56. 455 block work
  57. 71 hoopdee
  58. Mystery part!
  59. Seat belt restore
  60. Headlight bezel/bucket resto
  61. Where to purchase new glass?
  62. Adding Cruise Control
  63. Can't find an intake manifold bolt kit
  64. 70 Cutlass Center Link replacement - Pullers
  65. Looking to confirm numbers heads and motor 1972 350 cutlass supreme
  66. '71 442 Build Sheet
  67. Cowl And Vin Tag Question
  68. virtual car shows?
  69. Better vinyl paint
  70. OPGI Gauges
  71. Nooooooo!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  72. Demon carb help please
  73. Newbie to help out older neighbor
  74. shipping
  75. 2 years and counting...
  76. 70 car for sale thoughts
  77. Gas Tank Sending Unit
  78. Delco Pliacell Shocks
  79. fender skirts
  80. 1964 Olds Cutlass holiday coupe resto
  81. I'm looking for that smooth idle
  82. Oldsmobile sure was a crazy hodge-podge of cars
  83. Junkyard Gem: 1996 Oldsmobile Cutlass Supreme, Phoenix Open Edition
  84. 1969 Cutlass convertible top hoses
  85. Fresh Air Intake Hose For 307
  86. Pertronix help
  87. 1979 Hurst Olds options
  88. Reproduction Hood Hinges, Good or Bad?
  89. 1961 88 - Would YOU buy?
  90. Part number look up
  91. PROTECT-O-PLATE Question
  92. A/C Question
  93. Cable length
  94. 1965 330 vacuum and rpm questions
  95. 1970 442 w30 inspection / appraisal
  96. 61-62 Disk Brake Conversions
  97. Hot Rod magazine May 1966 - Hairy Olds
  98. Shoulderbelts for 1972 Convertible
  99. Vista Cruiser Assembly Manual?
  100. Truck for sale needs minor frame work
  101. protect-o- plate 344879e115724 ...69 442
  102. Fastenal 3PL suspended?
  103. Starter?
  104. Close call last night
  105. Jetfire number 7
  106. Sealant on top of cowl?
  107. Parts finish question
  108. I bought an Olds diesel
  109. 70-72 Cutlass Supreme hardtop option
  110. Original starter?
  111. Howdy all.... been a bit....
  112. Ambitious seller on eBay 🤔
  113. New PayPal scam using old tracking numbers
  114. Cranking
  115. Misc pats value questions
  116. Big Block Motor Mounts
  117. Proper Posting Etiquette & Procedures
  118. Rear End
  119. Transmission cooling lines 72 Cutlass
  120. veterans day
  121. Shift Linkage Hanging
  122. Aftermarket wheel id help
  123. Hummm, wire is wire, right?
  124. 1969 Cutlass no start condition
  125. What does this fit??
  126. 1977 442 Starter mounting to block
  127. 425 cutaway drawing
  128. 1969 Cutlass data plate color code? Made in Canada car
  129. Installing hood hinge springs with threaded rod
  130. help with column back drive setup
  131. Name that part
  132. Fun and functional late spring projects
  133. 1964. 98 olds suspension bushes
  134. Power steering pump question
  135. College days
  136. Floor shift stuck in park
  137. 1969 442 driver door
  138. Turbo 400 tag code
  139. How does one tell the difference between a re pop bumper and a original ??
  140. What's The Chances or Odds?
  141. 455 oil pan
  142. In search of Quinn Sullican
  143. A nice 430 mile drive in a '75
  144. 1971 Cutlass Heater control valve
  145. fuel sending unit
  146. Poor man's valve job?
  147. Fun road time in the red flat top wagon
  148. Hifonics TPS-BT1 - Sounds
  149. S10 Newer Console into '80 El Camino
  150. Chev vs olds quadrajet
  151. 62 Starfire Wipers
  152. Power Steering Pulley help!
  153. Original speed in the 60’s
  154. What a waste
  155. Ideas 1966 442 B90-B85 option window felts
  156. Jack stand recall
  157. 65 bumper baffle question
  158. Last year of the O4B4 Intake manifold??
  159. Proper 1966 442 window felt kit
  160. Manual B body alert!
  161. How many miles does your Olds have?
  162. 1972 Cutlass PS Pump Removal
  163. 1973 98 2 door hardtop blower motor
  164. Book, cars of oldsmobile
  165. 1970 OAI N9 hole
  166. Is there really a market for this?
  167. selling cars on today's E Bay
  168. Think tank time ....
  169. AM Radio to FM Converter?
  170. What is the correct choke hot air tube
  171. Parts Vendors
  172. Wireless gauges and sensors?
  173. 70 442 Pace Car Convertible (Not Mine)
  174. 461 or 462?
  175. 1969 Cutlass correct floor shifter
  176. Axle Ratio '71 442 Factory Air, 4 Speed
  177. 394 t350
  178. What's New Today??
  179. Do blower fans get old?
  180. Hurst Dual Gate question..
  181. Stainless steel headers
  182. Garage Break-ins & Stolen Olds'
  183. Vote for me! (part one)
  184. Is this a 1955 Olds 98 radiator shroud? New question, the 1955 AC condensor?
  185. Check this 71 Cutlass S out
  186. Throw away society mentality???
  187. Advice on Garage Floor Epoxy
  188. 1 of 1, 70 Vista 442 (2 Door) Concept (?)
  189. '76 Cutlass Supreme Body & Paint, Worth it?
  190. Tank vents
  191. Antenna is Loose
  192. Who is rtolds ?
  193. Freeze out plugs
  194. Double stick tape to attach tach?
  195. Undercoating advice
  196. Olds legend Ron Garey has crossed the finish line
  197. trying to start
  198. Looking for GM Part # for RH mirror 1976 Olds Custom Cruiser
  199. 66 442 buffed out pretty nice
  200. Body shops in California
  201. 71-72 factory blue floor mats
  202. 65 442 exhaust questions
  203. 1964 Olds Cutlass holiday coupe resto
  204. 73 cowl tag decoding
  205. 1964 olds 98 394
  206. Help! Qjet mystery part
  207. What was the code option for 70-442 stainless seat belts?
  208. Wire Wheel Covers
  209. 73-77 A Body Interior
  210. What are the metal punchouts attached to my 1983 oldsmobile warranty information book
  211. 1970 Cutlass convertible price range
  212. Tic toc gauge.
  213. Does anyone make repro arm rest pads for 4-door 67 CS's?
  214. fashion statement
  215. Trying to find a servo for Cruise control
  216. radiator size 68 B body versus 69 Abody
  217. Windshield washer hoses
  218. Center armrest on 72 convertible
  219. Question about grilles
  220. enough cold air ?
  221. Original or repops?
  222. Vista Cruiser fuel tank??
  223. edit thread
  224. Save on KYB Shocks & Struts at RockAuto
  225. 69 442 Grille flat or semi black?
  226. 1965 Olds 98 what series ?
  227. How to remove 66 cutlass 442 side mirror
  228. LONG term project car
  229. Condenser mounted to coil 70 Cutlass
  230. 45 Years? Hard to Believe
  231. Question about Interchange between 1954 and 1955 Tredle Vac
  232. ISO OEM Style Muffler for 70 CS 350 2BL
  233. Kick panel for speakers
  234. Seeking Belt Trim Moulding (Clips)
  235. Just checking in. Excited
  236. “The cars of Oldsmobile” book
  237. 1967 Cutlass fuel tank strap mounting points
  238. rear coil springs
  239. Need help- 66 pulley set info non air
  240. 1973 Olds trunk light
  241. Front air dam deflector 69 cutlass
  242. 455 rebuild, initial start up/break in
  243. Need help, 66 power steering questions
  244. Body mount bolts '65 Cutlass
  245. 1955 Oldsmobile
  246. Cigarette lighter question
  247. Classic Parts
  248. Toronado temp gauge
  249. Anti-Squeak tape for 1962 body panels
  250. 1966 Cutlass/442 front bumper value.
