Power steering pump question
I have a 72 Cutlass, 350 CID, and I replaced the power steering pump. What I thought was a straightforward task turned into a chore. I ended up getting the OPGI pump since the aftermarket pump that was supposed to fit was incorrect. My issue now if that when I tighten the belt the pump actually sits a little crooked - enough to make the belt track incorrectly. Is there something I am missing? I have the lower mounting bolt tight
Check out this thread and let us know if it resolved your problem for you.
https://classicoldsmobile.com/forums...spacers-63037/
power steering
I've got the same problem on my 69 98.are these spacers available over the counter at my local parts house?or do i have to track down some used one's.and do you happen to have any.
Waldo
Waldo
you can also stack regular hardware metal washers to space your pump correctly as a quick if not temporary fix. - not a factory look but has been effective for me in the past when the factory pieces weren't handy.
cluelesscutlass
Jan 3, 2012 06:18 AM
