1965 Olds 98 what series ?
Old May 6, 2020 | 09:53 AM
GCH's Avatar
GCH
Hi , is there any number or letter code to see if the rear axle is
antispin or conventional differential ?
1965 Olds 98.
Old May 6, 2020 | 11:07 AM
Yes. There should be a two letter code on the right axle tube on the forward side, about in the middle. Probably Q something. QK, for example.
Also, please make new thread for new question.
Old May 6, 2020 | 12:32 PM
11971four4two's Avatar
MOTORHEAD
1965 Olds 98.
IF you have the car with back tires off the ground safely , on jack stands , in neutral (not running)
Spin a tire , if the opposite side tire spins in the same direction usually indicates posi / anti spin
Otherwise pull the cover and see if there is a clutch type carrier. If so add posi lubricant additive
If axle has had work done .. welded up or posi added axle stamp codes NO Longer have any relevance to how it is now
Old May 6, 2020 | 07:03 PM
bccan's Avatar
Did you put limited slip additive in along with the oil? If not then you wouldn’t have potentially helped the problem. The limited slip differential needs the additive to allow the clutches to “slip” smoothly. IF the additive has been added or once it is added it will take some driving (especially turning) before the chatter/clunking MIGHT subside.
Old May 8, 2020 | 05:26 AM
monzaz's Avatar
From the factory...IF YOUR CAR IS REALLY original ...you would have had a LIMITED SLIP DIFFERENTIAL FLUID TAG ON THE REAR COVER...OR CHEVY WOULD HAVE HAD ON IN THE FILL PLUG AREA. oops caps key again sorry. Jim
Old May 9, 2020 | 08:13 AM
Lonnies Performance's Avatar
Based on the pictures.... it is a limited slip.
Now if the wrong oil was used, it may still chatter for a while after changing the fluid until the new fluid has a chance to penetrate.
Try doing some figure 8's in a parking lot to help work the new fluid in the clutches.
Also you can get a limited slip additive, which is a small bottle (about 6-7 ounces) & add to the fluid. This helps with the irregrular feel (& possible noise) when turning at low speeds.
The GM additive is very good, but may be hard to find in your area.
Old May 10, 2020 | 02:48 AM
GCH's Avatar
GCH
Sorry for that ,should think about this next time
Jacked up the car and spin a wheel , and the other wheel turned the opposite direction .
Thank,s should change the oil and check level.
Old May 15, 2020 | 01:05 PM
GCH's Avatar
GCH
Not sure what series my 1965 98 are ? Series 38 ?
Was thinking change differenttial oil.
Old May 15, 2020 | 01:30 PM
If you jack it up and both wheels turn in the same direction when spinning the tire by hand, you need a 90wt with a posi lubricant included in the oil. If one wheel turns or they turn in opposite directions, plain old 90wt gear oil will suffice.
Old May 15, 2020 | 01:39 PM
jaunty75's Avatar
No. The "3" just means Oldsmobile division. The series number is the second two digits. You have a '98 convertible. That falls into the row labeled 38400. The series is thus 84. The 00 is determined by the body style. By long convention, Oldsmobile convertibles are style 67, so yours is 38467 as shown in the third column.
All '65 98s except the Luxury Sedan are series 84. The Luxury Sedan is series 86.
Old May 16, 2020 | 06:26 AM
GCH's Avatar
GCH
Thanks for info. Have jacked up the car and when spinning one wheel the oppsite goes
the other direction so plain transmission oil will be great.
Thanks for info about the Oldsmobile series codes , have wonder about this for a while.
So my 65 Dynamic 88 should be series 56 with body style no 69 then.
And since my 98 have series code 84 the diffential should have about 4 - 3/4 pts oil.
Old May 16, 2020 | 08:29 AM
Not transmission fluid, you want 90wt gear oil. I fill the differential until I can put 1 knuckle or tip of my index finger in the fill hole bent down and feel the fluid. I don't fill until it runs out.
Old May 16, 2020 | 08:47 AM
GCH's Avatar
GCH
Sorry language problem 80/90 w approved with MIL-L-2105 B as manual says
Old May 16, 2020 | 09:38 AM
That will work.
Old May 16, 2020 | 10:13 AM
jaunty75's Avatar
Yes, if it's a four-door with center pillars. For many years, Olds called that style "celebrity" sedan and used it the name across the range of models (A, B, and C body cars). If it's a four-door without a center pillar (a hardtop), then it would be a "Holiday" sedan, and the car would be 35639. Olds used "Holiday" to refer to hardtops (two or four-door) for many years as well.
Old May 17, 2020 | 11:01 AM
GCH's Avatar
GCH
Yes it´s a four door with centerpillars.
Old May 17, 2020 | 11:04 AM
jaunty75's Avatar
Very nice. Photos are everything on this site. Without them, the cars people claim to own don't really exist!
Old May 18, 2020 | 10:56 AM
GCH's Avatar
GCH
Removed the differential cover today and there was real black
oil in it. But "of course" i got wrong gasket ? .12 holes instead of
10 as i have.( Felpro RDS 55029 ? Took a picture of the differential:
Old May 18, 2020 | 02:58 PM
I moved your posts from the other thread to this one. No need to ask the same question in multiple places. Yes, that is an open rear end so all you need is 80/90wt with no posi additive.
Old May 20, 2020 | 10:43 PM
GCH's Avatar
GCH
Yes, love to se pictures of cars and parts
Thanks , i agree thats better. Was stupid of me posting in a another thread in the first place.
Johno65
Jul 8, 2018 03:22 PM
Fizz
Aug 31, 2016 06:47 AM
StarGeneral
Jan 30, 2016 10:54 PM
76 vette
Aug 6, 2009 05:46 AM
