PDA
View Full Version : General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. Suggestions for Breather circuit??
  2. Interesting barn find...
  3. 1970 Oldsmobile 442 Trim Tag
  4. '70 Cutlass Supreme Convertible W-31?????
  5. New daily driver!
  6. Would anyone in the Flint MI area consider going to look at a car for me?
  7. What is a reasonable price for a 3rd member or complete rear end
  8. At wit's end. Help.
  9. 1970 Cutlass Manuals...Which ones do I need
  10. Anyone familiar with this?
  11. More Modern Size/style of the 69 Hurst Olds Wheels?
  12. Thoughts on freely giving authenticating knowledge for the cars
  13. watch your step
  14. 442 Accident (?)
  15. General Tire Commerical - 1978
  16. 1984 olds Delta 88 worth?
  17. Motor serial numbers
  18. Antique Briar Cutlass
  19. '70 cutlass convertible - color combo
  20. Distributor wiring help please
  21. Cowl tag info
  22. Can you modify chevy small/big blocks or mopar engines to run on german autobahn?
  23. Protecto Plate assistance '70 Cutlass Supreme
  24. 69 442 Alternator
  25. Breakerless-se electronic ignition conversion
  26. 82 Cutlass Supreme exhaust question
  27. Baby's in storage...
  28. 1966 442 - new carpet intall question
  29. Cam 101?
  30. build sheet help
  31. Decoding Help
  32. Cool Youtube video
  33. 1966 442 Console Installation
  34. Wide oval red lines
  35. Name-that-Olds!
  36. 70 Radio
  37. SSIII wheels pricing
  38. quality of metal of non-original manufacturers
  39. Refurbishing Heads
  40. Inspection of 442 in St. Louis, MO
  41. New to Classic Olds 72 Cowl Tag Help Please
  42. Original Driven gear
  43. I cant find rear wheel bearings
  44. 65 442 Cannibal Edition?
  45. 1970 Olds 442 Early Fall in the SE
  46. Convertible top pump
  47. What's my Cutlass weigh?
  48. Does anyone know what year this is for?
  49. Micrometers and measurements!
  50. Reconditioned a dash bezel for my '95 CS convertible
  51. Bumper jack date code question...
  52. Dampener pulley bolt
  53. Sport mirror identification
  54. Saw this on Facebook...
  55. Texas Craigslist
  56. 71 Cutlass Power Windows Swap
  57. fitting pertronix to 55 olds
  58. Question on Stabilizer Bar and also Control Arm Torque
  59. Head Bolts for Early vs the rest of the 350 builds
  60. Need good source for reman carb
  61. Something You Want To See
  62. "Trans Am" reality carbuilding show
  63. Found a nice Sears timing light while in Hershey
  64. Need help please
  65. How do you replace rear wheel bearings>>
  66. paintwork expense...WOW
  67. L69 carb rebuilder recommend who???
  68. 72 Cutlass Supreme Power steering belt/pulley squeal
  69. Exhaust Manifold Gasket
  70. Chrome Bolts for Holes in Bumper
  71. New Layout?
  72. Parts Vendor
  73. Header change?
  74. special tranny
  75. Genuine GM fan belts
  76. Parts book thread
  77. What driven gear needed
  78. A Heads cores ??
  79. A couple of other exhaust questions?
  80. Anyone ever seen the Hooker Titanium coating in person?
  81. New pics...
  82. 4200 mile road trip in my Vista, came home on a trailer
  83. 69 442 speedometer ratio adapter
  84. Painting 442 Grille
  85. Recycling a 350 Olds
  86. Display engine opinions
  87. Source for 7/8 20 drain plug?
  88. Oldsmobile couch!
  89. emergency cable removal
  90. Replacing Heater Core 72 Sports Coupe
  91. 68 wood steering wheel in a 1969 ??
  92. Installation of rail weatherstrip
  93. Speed o and front em brake cable
  94. 1972 Cutlass Exhaust Build
  95. Good times...
  96. Original G block where are you?
  97. What is missing and why?
  98. scrapping carb bodies
  99. Southern California Olds Club Show - 10/6/18
  100. Changing from Edelbrock back to Quadrajet. Need advice and parts.
  101. Installing Aftermarket Gauges 1969 Cutlass
  102. How to contact Stephen Minore?
  103. Fusick at Hershey?
  104. pinch weld molding 66 442 convert
  105. '69 4-4-2 W-30 At Auction?
  106. 66-67 A-Body Rear Window Channel Question
  107. Realoldspower?
  108. Heater Core replacement for a 1972 Cutlass
  109. Looking for Reputable Machine shop in NC
  110. W-25 Ram Air Hood - Functional or just aesthetic?
  111. need a hand with center caps
  112. Why so many different A-Body Export KPH speedometers?
  113. Quadrajet Power carb rebuild
  114. Yellowed Washer Bottle
  115. Reputable Vintage Air Installer Wanted for 1970 442 Convertible
  116. Hurst dual gate shifter cable
  117. looking for wheels
  118. Cutlass Frame
  119. It's raining here in NOR California.
  120. Leather Upholstery Interior
  121. 1972 Oldsmobile Cutlass S. Wont spark
  122. info to share
  123. 350 hemi
  124. Front disc to fit 14" drum rims on 64-72 Cutlass, 442
  125. "Air Hog" air filter
  126. Happy Day for me
  127. 1970 Rallye 350 Questions
  128. Blew the motor up! Part out questions :83 Delta Royale Brougham
  129. 67 Touched by King Midas
  130. Two things
  131. 67 442 4spd console
  132. 1971-72 taillight housings
  133. Fremont Assembly Plant
  134. 70 442 cowl tag
  135. NOS Valve covers
  136. Hidden gem 1970 4 speed W-31
  137. How-To Install Flasher (Location?)
  138. Musclecar review
  139. hood pins
  140. Ocean City Endless Summer Cruise 2018
  141. Great Story from Hot Rod...
  142. Question?!?!
  143. Reason for Restoring Confirmed
  144. Hollander interchange book
  145. G Body T-Top
  146. Holley Sniper EFI installed on my 72 455!
  147. W-30 W-31 On craigslist
  148. cowl tag decoding site
  149. Information card found
  150. Is this for real !!!
  151. 1956 Olds S52-50 Paint Code?
  152. Fair labor costs?
  153. Traveling to Cleveland Ohio?
  154. 1971 w30?
  155. 394
  156. Looking at a 1969 Delta Royale, need help from big car guys Updated with Photos
  157. Wire wheel tool
  158. A4 intake plugs - One There, One Not
  159. Fuel line
  160. 65 Olds '98 at LKQ Self-Serve Greer, SC
  161. 62 starfire
  162. S.O.S. carb gasket
  163. Window Felt
  164. Newbie needs exhaust help... did I make an expensive mistake?
  165. What Does This Engine Say To You?
  166. Where to buy
  167. tit top talk like pirate
  168. 69 outside door mirror loose
  169. pedal extenders
  170. Box of stuff, previous owner
  171. Would anyone like to see my 54 Olds get built soon?
  172. Interesting find above Cutlass fuel tank
  173. 70-72 Cutlass Convertibles - Stress Cracks
  174. No respect at all I tell ya
  175. Distributor Advice
  176. #2 & #3 cyl problem
  177. Sport steering wheel part # 9749836
  178. Cam lobe seperation
  179. Working on the dash
  180. Engine Runs If "GAUGES TRANS" Fuse is Installed
  181. The price of gas in 1972 and 1976
  182. Old iron
  183. Oldsmobile race cars
  184. Steering Gear Rack Piston Plug
  185. Convertible top pump
  186. 1957 pivot arm bushings
  187. 72 cutlass supreme dash assembly
  188. Second thoughts?
  189. Ironic realization...
  190. Olds at car show
  191. a good day for olds at the local car show
  192. Need advice on lifting assembled 455 short block
  193. 64 Cutlass Passenger Side Mirror
  194. Des Moines Iowa swap
  195. Vulcan bumper Jack
  196. Rochestor 4BRL Carburetor primary throttle plate differences – With and w/o a hole
  197. Need some expertise
  198. I know, i know
  199. HELP Please: Brake Booster Rod Length?
  200. Is my Vista a base or custom??
  201. Latest Issue of MCR
  202. Can any tell me what this is please
  203. Saw my first clouds today in 4 months.
  204. 72 olds cutlass supreme.
  205. Thornton 350 headers
  206. Pulling my hair out. Better start or I sell it.
  207. 66 Gauge cluster
  208. Today is 911
  209. Deal or No Deal
  210. New to me oldsmobile
  211. Identification of '50s Oldsmobile
  212. electrical problem, please HELP!
  213. It seems I have a leak...
  214. Contemplating a tire and wheel swap
  215. 1972 Cutlass rear window trim
  216. 72 power windows
  217. 1956 88 Car Cover
  218. 1964 dynamic 88 convertible
  219. 69 Cutlass S drop top heater core?
  220. Looking for help for my cousin 1936 Mercedes
  221. Part I.D.
  222. Selling Prices Deleted
  223. 1964 Cutlass remote mirror
  224. 1966 442 hood
  225. Wasn't meant to be
  226. Aerotech go cart worth
  227. Reputable restoration shop
  228. Firewall fuse block connector grease
  229. Rattling PCV
  230. 403 flexplates
  231. Another Epay Beauty!!!
  232. Vista Cruiser Help
  233. AutoFair Sept 2018 Charlotte Motor Speedway
  234. 72 Cutlass Supreme Repop Rally Packs
  235. 71 442 Green stripe color code needed
  236. OL’ MARAIS RIVER RUN - SEPTEMBER 15th & 16th , 2018 ~ 1972 or Older Vehicles Only
  237. Tow from Waco to Fort Worth
  238. Considering buying a '59.
  239. Amazon gift card options?! Why?!!!
  240. Weight reports?
  241. Historically speaking...
  242. Frankenmuth, (Mi.)Autofest Sept.7-9
  243. Option codes
  244. 68 Cutlass Instrument Lights don't work
  245. Need help on buy a rebuilt kit for a 425 olds
  246. Cable Selection???
  247. Sure glad I am not a Chevy guy and on Chevy forums
  248. Happy labor day
  249. Thinking about buying another car (craigslist)
  250. 1981 cutlass cruiser diesel
