Refurbishing Heads
Old Oct 24, 2018 | 02:11 AM
Raffi's Avatar
Refurbishing Heads
Hi,
On average how long does it take to rebuild heads including valves and everything else (so they're ready to bolt on as it were)?
I apologise for the simplicity of the question but I am currently getting some heads rebuilt (August) and am still awaiting their completion.
Any information would be great.
Thank you
Old Oct 24, 2018 | 04:22 AM
deadeyejedi's Avatar
this is entirely depending on the shop and thier workload .ive had two sets done at my local napa machine shop (which is a fairly busy place )and got each set back within 3 or 4 weeks ,and i told them no rush .you should always discuss a time frame with the shop and hold them to it .
Old Oct 24, 2018 | 05:05 AM
X2. Took about the same for the last set of BBO heads that I had done. Mag, hot tank, machine for insets and big valves, surface, machine for Teflon seals, and assemble.
Old Oct 24, 2018 | 05:22 AM
IMHO, 3-4 weeks is too long. I suppose if you're on good terms with the machinist and you're truly in no rush then that's ok. However; I had my local machinist rebuild a set of Ford 5.4l heads and it took him less than 2 weeks. It didn't need valve guides but they are OHC heads so they were that much more complex than old school Oldsmobile heads.
I suggest going to the machinist to retrieve your heads immediately. They aren't interested in completing the work. A competent machinist wouldn't need more than a day or two to do the actual work. Even if the heads needed everything.
Old Oct 24, 2018 | 06:21 AM
My last set of heads were 3-4 days.
Old Oct 24, 2018 | 06:26 AM
oddball's Avatar
It's less than a day's worth of work to do a basic refresh of two classic V8 heads. So it's all up to the shop's scheduling. And whether or not they lost anything (it happens....)
OldSoldier
Jul 28, 2025 01:50 PM
73aussie455
Dec 7, 2017 02:56 AM
72cuttys
Sep 5, 2012 11:47 AM
442b
Feb 18, 2012 06:32 PM
Stevec
Apr 28, 2011 09:01 PM
