#2 & #3 cyl problem
Old Sep 18, 2018 | 03:20 AM
joe68h/o's Avatar
#2 & #3 cyl problem
Cyl #2 & #3 don't fire. All others cyl fire. All cyl have 145 to 150 compression. Have spark on both dead cyl. Have switched cap, wires, & plugs with same results. Thought vacuum leak or cracked intake so I plugged all vacuum ports with no improvement. Replaced intake with different one and used composite intake gaskets for better seal same results. Heads had valve job done before problem. Even put adjustable rocker arms on thinking some of the stem heights were not to spec. Valve springs all look ok. Any suggestions what problem could be before I pull heads to have checked again.
Old Sep 18, 2018 | 05:10 AM
Long shot, but maybe intake valves aren't opening? You got compression and spark, only thing left are fuel and air. Or maybe big vacuum leak on runner to 2 and 3??
Old Sep 18, 2018 | 07:11 AM
cherokeepeople's Avatar
what are you working on ??
Old Sep 18, 2018 | 07:58 AM
Oldsmaniac's Avatar
What is your distributer? If stock points maybe bad lobes on distributer... just because you have spark outside possibly under compression its not sparking... could be marginally weak spark, just a thought.
Old Sep 18, 2018 | 08:30 AM
assuning you have a v8 350-455 you have compression,you have spark and it does run so you have gas,2&3 are on same runner in the intake so that would point me to a vacuum leak.get it running and spray some wd-40 around the base of the carb and along intake to see if they start firing.
boese1978
Tech Editor's Desk
16
Apr 25, 2017 03:29 PM
Cincinnati Rick
Aug 20, 2015 04:40 PM
rg442w30
Oct 15, 2014 05:13 PM
killer501872000
Non-Olds Engines
22
May 26, 2013 04:22 PM
Odmark
Feb 6, 2013 07:10 AM
