Fuel line
Old Sep 21, 2018 | 06:36 PM
truckman5000's Avatar
W30
Fuel line
Feed and return metal line.
runs in factory frame location.
I had a small leak 50 miles ago, I fixed...well not good enough as fuel line blew off.
where the lines are, seems problematic from factory
I'm wanting to run an. Lines front to tank?. As I'm concerned of fuel/ fire
Old Sep 22, 2018 | 05:52 AM
If by "AN lines" you mean braided stainless, well, the factory steel (or better, stainless) lines are a much better choice. Braided stainless lines are just rubber hose inside a stainless braid. I've had the rubber go bad and leak, just like any other rubber hose. Solid steel is safer.
Old Sep 22, 2018 | 11:50 AM
70W-32's Avatar
If you buy Braided hose with teflon liner the gas wont attack it, but it is more expensive than regular braided. I got oversized( 1/2" ) stainless fuel line, prebent, from Right Stuff Detailing.
jimvbills
Sep 17, 2019 09:05 AM
tgilligan
Feb 25, 2015 04:39 PM
71cutty
Jan 13, 2014 02:18 PM
bonnevillegreg
May 10, 2011 12:45 AM
dantana
Aug 21, 2009 10:58 AM
