Pulling my hair out. Better start or I sell it.
Old Sep 11, 2018 | 06:42 PM
Dadsbadass442's Avatar
Just had my 1967 442 Olds shipped from Colorado to Hunstville, AL. Met the shipper in the parking lot. He started it, backed it off the truck and shut it off so we could do the once around. No delivery issues with the car. Shipper left and I started the car right up. Drove it half mile to the house. Back it's pretty *** into the driveway so the entire neighborhood could see. Dam car won't start now. No power what so ever, none, no radio, lights, crank, dead silence when I turn the key. Took battery to Autozone, two of them for second test, opinion. Battery readout was brand new, as it is brand new. Pos and neg on battery are new and tight. both red and black cables are new and heavy duty. What in the world should I trouble shoot first? I'm guessing it could be a hundred things, please throw something at me.
Old Sep 11, 2018 | 06:45 PM
cherokeepeople's Avatar
do these use the wire to the horn relay like the later ones??
Old Sep 11, 2018 | 06:46 PM
truckman5000's Avatar
W30
Someone add a fusible link? Fues between battery and relay..
Old Sep 11, 2018 | 06:54 PM
Check the connections at the post on the horn relay.
Old Sep 11, 2018 | 07:33 PM
tru-blue 442's Avatar
Old School Olds
Check the starter wires as well.
Old Sep 11, 2018 | 07:48 PM
svnt442's Avatar
If there is no power at all when you turn the key, make sure all of the under hood connections are in good shape. If those pass muster, then turn your attention to the ignition switch.
Old Sep 11, 2018 | 08:50 PM
redoldsman's Avatar
Proud Viet Nam Veteran
If none of the above work, check the negative battery cable where it connects to the engine.
Old Sep 11, 2018 | 10:06 PM
What Red said.
Old Sep 12, 2018 | 12:50 AM
svnt442's Avatar
I thought for sure that covered the ground wire as well as the hot stuff.
Old Sep 12, 2018 | 01:58 AM
66luvr's Avatar
I have had a bad, or loose, connection where the wiring harness under the hood plugs into the inside wiring on the firewall. Probably caused by human error, someone messed with it and didn't get it plugged in tightly. It caused the symptom you are having, nothing happens when you turn the key.
Good luck,
TheGoldsmobile
Jun 13, 2019 06:46 PM
ralbers
Oct 10, 2018 04:08 AM
CrazedCountryRebel
Dec 14, 2012 08:20 AM
Jamesbo
Feb 6, 2011 12:08 PM
tim72
Jul 2, 2009 08:23 AM
