View Full Version : General Discussion
- 68 Cutlass Muncie Pilot Bearing Questions
- Nice 1970 W30 GM Heritage Center
- Look what I found. GM spare air
- Car Cover Sale 50% off plus an extra 15% this weekend
- Things kept getting in the way, you see...
- Rare intake
- I'm confused (12 bolt type O Posi)
- A Couple Of Unusual NOS Parts Recently Found
- Speedhut is having a 15% off sale on all guages this weekend
- '64 coupe front fender trim clips ID?
- Fire at Advanced Plating in TN
- Autobody specialties
- Motor oil question
- 68 Cutlass Console Wires - What For?
- voltage drop
- The Guvnah's Oldsmobiles
- Newbie with a few questions
- Air conditioning too cold?
- Found something interesting
- Advice for the Engine Swap Project
- Phoenix Transmission in Weatherford
- Adirondack nationals car show
- F body Oldsmobile?
- SMS headliner 15% discount till Aug 31st
- Last time you shifted on the column manually
- Muncie 4 Speed Reverse Light Switch - specific to car or trans?
- Remanufactured Engines
- how to tell a true 1971 olds 442 w30
- Engine building nightmare
- 1970 Cutlass SX
- Autozone parts bad...or good?
- Coolant Reservoir Installed...
- Jetfire video boosting
- Fixer Upper Rallye 350-Cheap-Not Mine
- Local Olds Car Show
- Turn signal problems
- I screwed up bad
- Missing part
- oil gas hub caps etc.
- Another Jetfire 4 speed car, 1963
- What's it worth, GM EOS?
- Jack color ??
- No other word for it -- sacrilege
- programing key fob
- rip mr king
- body clips
- VW content and Hail Cannons
- 35TH Annual All Olds Show August 26th 9-3PM
- OAI. Air cleaner bucket
- Help With Decoding VIN #
- Rock Auto code placement at check out.
- Pep Boy at Rock Auto prices !
- Better Call Saul
- Engine Paint
- Are 65-70 B/C bodies undervalued?
- 67 Automatic shifter cable
- Found someone’s build sheet
- now that the woodward cruise in
- Foam to OAI Flapper Adhesive
- Cutlass Fiberglass 442 Hood Question !
- Lost another Olds car guy and arts vendor
- I bought a car today
- CAN'T FIND Vacuum Adv. Help Please
- When to fire it up?
- 76 cutlass damage
- Gas gauge 1/4 tank off
- NOS resortations
- $200,000- $500,000
- Electric choke BS
- MSD Throttle Body
- Olds concept cars
- Must be a trend starting
- I'm at a loss for words!!!
- Worth of B 425 heads
- Vintage tee shirt
- attntion old(s) farts: *2* 1983 D88s auction
- Critter feast
- Relocating to North Carolina
- OCA Nationals Gettysburg
- Tri City rechrome
- Vehicle Valuation Site
- J head replacements
- Frozen 71
- Sherwin-Williams Hurst Gold
- 1969 Cutlass
- A shout out to the SE VA members...
- Interesting hot rod article
- Super Charger
- 425 fuel pump
- HISTORY OF THE ROCKET ENGINE by F. Gibson Butler
- Electric Choke Conversion Kit
- Seat Belt base question
- Hot Rod Jetfire article
- Hope there is no limit on questions
- Northstar Tech
- Door Hinge Wrench 1/2" -
- Has the 2019 OCA Nationals site/date been released?
- 64 Cutlass with a non functional door lock. Guidance required.
- selling my project ?
- Guess what is in the barn
- Advice needed
- CLR to clean nasty bolts
- Free beer
- Carburetor
- Oldsmobiles at car show
- Moog Front spring info
- This is the way to tow
- Saw this and just thought WOW!
- 65 Cutlass
- Friday Nite Lights
- Best radaitor
- 1968 442 remote mirror
- On Craigslist, I thought it was overpriced
- 350 kick down bracket
- Ditching Iggy Points
- Trunk pan install?
- Helping my bro out with his 65
- Olds-themed man cave
- wiper transmission 66 cutlass
- Mufflers suggestions
- '57 Fiesta article
- Do I need a high output alternator?
- 1977 Cutlass' Body Styles
- Night Moves...
- Tariffs coming on old car parts?
- LED lights for our cars, a little help please
- 1969 Toronado 455
- 10 millionth Ford Mustang produced today
- Any North Carolina dealer help?
- '55 Super 88 Rochester 4 bbl carb - help please
- Is this normal ???
- Getting confused about compression ratio
- 2020 Nationals
- Lonely Olds
- Ok guys what the heck is this?
- Vista Crusier T-Shirt on Blipshift
- Coolant Fitting...
- And the #1 reason to delete that vinyl top is...
- 1969 olds 442 bumper
- Need the apolstered weatherstrips for around the doors
- Help w/ "Mini" Deluxe Seat Belt Retractors
- Centerlink dust covers
- Column Shift
- 442.com
- This is nuts?
- Ignition help needed desperately!!!!!
- Timing light
- Pre Heater Hose
- Speedo cable
- HELP: reset combination valve???
- A/F numbers
- 69 or 71
- Happy day...found build sheet
- 1999 Cutlass
- OAI hood decals
- Aftermarket OAI Air Cleaner Bases
- Hydraulic top down manually?
- Bracket modification for Tall Valve covers.
- front window channel inner molding 65 Cutlass
- Want to change 72 Cutlass S hood to ram air.
- Quadrajet linkage
- tire age
- Missing piece of my decoding
- Anyone Know Larry Thrall?
- 4 post lift ramps
- Anyone know these clocks?
- 1967 Delmont 88 & Delta 88 front Brake Drum Help
- Wind lace
- What is this wire?
- Replacing rain gutter CS1972
- 1970 w-30 hot rod article
- Huh? 72 W30 stripe cancelled?
- 4 post lift ramps
- Wiper motor
- Generator light, buzz
- Information on title.
- Question for the masses...
- 72 grille emblem trouble
- 1970 98
- 1966 Tricarb
- Can I remove this?
- Looking For Someone To Inspect 442 Near San Diego
- Wot
- Carb Spacer
- Hood tooth rubber bumpers
- Looking for a 442
- my car got stolen
- 1958 Oldsmobile
- Single Post Car lift!!!
- Dash Color
- New posting window
- 76 Olds Cutlass S
- Rear Seatbelt Needed
- Bolts that I screw up
- Headers
- An Olds engine bible
- Racing Stripes
- Gauge Senders
- 67 Olds 442 power antenna
- Racing fuel
- Pics of my a/c install..
- How does it run?
- Whats it worth?
- Factory Clock Adjustment
- Dealer info.
- 1972 cutlass \ 442 convertible top switch keeps burning out
- Backwards Fuel Gauge!
- Where Has 442.com Gone ???
- Special order paint 442's & Rallye 350's
- 1969 442 hood hinges
- Weird Science
- factory 8 track
- Door Buzzer
- 1970 Cutlass W-31 Carb Adjustment
- Aftermarket alternator bracket???
- billet altenator brkts
- Olds/Buick/Pontiac Car Show September 16, Easton PA
- Hood rear trim install help needed
- Just had to share this one
- Paint code original Rocket V8
- Muncie fill plug cross-threaded
- brake shoe wheel cylinder alignment
- Stronger stance
- RPM at highway speeds
- 16th Annual All Oldsmobile Fall Show, Oct 14, Downingtown, PA
- 1970 turbo 400 speedo housing
- Current value
- Oldsmobile assembly plant tour 1963
- Starter, Alternator and Air Conditioning Compressor
- Oldsmobile 442 Coin
- Burglar Alarm
- Craigslist find of the year for me
- hurst olds vin
- 1970 442 turn signals
- Shifter Issues
- Plastic grilles - 72 CS
- 2018 Classic Olds meeting
- The parts place rear marker light bezel?
- Gettysburg 2018 Nationals
- air breather
- 1967 Delta 88 Custom Cowl Tag?Vin Decode
- 1972 cutlass wiring
- 1970 Body (Cowl) Tag
- 72 Cutlass Supreme Rear Trunk Letters Should I ??
- installing an olds 350 into a chevelle wagon
- 67 Cutlass AM/FM RADIO
- Vacuum door locks??
- Q-jet bowl plug leaking
- Clutch Shudder
- Battery cable mount location
