1970 98
Old Jul 29, 2018 | 07:06 PM
cutlassjim's Avatar
1970 98
I just got this beast from a friend of mine who lost his storage for it. Did they ever make a passenger side mirror for these?
Old Jul 29, 2018 | 07:29 PM
cherokeepeople's Avatar
i don't recall mine having one,but thats been about 30 yrs ago.i see you have the wiper button on the shift lever!does it work?also power pass seat does it have a map pouch on the inside of the drivers seat?
Old Jul 29, 2018 | 07:47 PM
cutlassjim's Avatar
I think the wiper button is on the dash, it does work. There are pouches on the back of the front seat. Power seats work great. Also has telescoping steering column. 455 with dual exhaust and positraction.
Old Jul 29, 2018 | 11:04 PM
eric66's Avatar
Nice car thanks for saving it from the crusher or someone taking its heart from her.Enjoy the ride with Friends and family and welcome to the club of boat captains.
Old Jul 30, 2018 | 05:15 AM
it sure looks like it has the button on the end of the shift lever.if you press it in part way it will wipe the wipers once,if you push all the way it will run thru a full wash cycle.also the little pouch is on the drivers seat between the 2 front seats,down the crack ,it's kinda hidden unless you know it's there.
Old Jul 30, 2018 | 05:16 AM
also looks like it has a rim blow horn,inner side of steering wheel is a rubber insert all the way around,press it and see!
Old Jul 30, 2018 | 06:11 AM
Very cool car!
Old Jul 30, 2018 | 02:27 PM
To answer the OP's question, a passenger side outside mirror was not available as a factory-installed option, but you could get one as a dealer-installed item. It is the same P/N as the RH mirror used on the 1968-69 Cutlii. Fusick sells a reproduction for $65 under P/N SM6865R.
Old Jul 30, 2018 | 05:57 PM
cutlassjim's Avatar
There is a button in the end of the column shifter ***. I also found the map holder between the seats. Thanks Joe for the mirror link. You guys are awesome.
Old Jul 30, 2018 | 06:20 PM
That old thing does green on green very well. I see tilt/telescopic, cruise, pulse wiper, horn blow, am/fm, AC, posi, duals, trunk mat.....power split strato bench?!?!?!
What else does it have?
Old Jul 30, 2018 | 06:57 PM
i see cornering lights too.man thats loaded with options.more pics man i'm just drooling over this,i miss my blue on blue 70 98 so bad.
Old Jul 30, 2018 | 07:28 PM
cutlassjim's Avatar
It also has a 8 track player. My friend Max"s uncle bought it new in Sept, 1969. It has the proteco plate. Max got it 18 year ago when his uncle was in failing health. Max is a ASC cert. mechanic and has always kept it mechanically sound. It has 107,000 actual miles. Max quit driving it about 8 years ago and it has just been taking up room in his garage. He called me last week and made me an offer I couldn't pass up. The car has always been garaged. It is running, but I want to do a basic tune up on it. More pics tomorrow. Thanks for all of the great comments. It is a true unmolested piece of history.
Old Jul 30, 2018 | 07:46 PM
Junkman's Avatar
I know that Cadillac for 1969 had a rim blow steering wheel, and it was a 1 year only part. They dropped it in 1970, because it was so problematic. I would think that Oldsmobile would have also dropped it in favor of a standard horn blowing mechanism that has withstood the test of time.
Old Jul 30, 2018 | 07:57 PM
cutlassjim's Avatar
It does have the rim blow horn and it does work. It just seams like it could take some getting used to.
Old Jul 31, 2018 | 02:58 PM
btw's Avatar
btw
Smokin' BBQ Member
That dual line whitewall is likely a Firestone bias ply.
Old Aug 1, 2018 | 04:21 AM
cutlassjim's Avatar
here are a couple interior pics.
Old Aug 1, 2018 | 04:25 AM
cutlassjim's Avatar
Got her inside just before the rain.
Old Aug 1, 2018 | 05:09 AM
man hood lock and rear defog,looks like they ordered every option on the sheet.take good care of it,there are probably only a handful left in that nice of shape.oh and it looks like you need a bigger shop.
Old Aug 1, 2018 | 03:39 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Wow...thats a nice sled!
Old Aug 2, 2018 | 09:45 AM
Destructor's Avatar
Nice, go through it and make sure it is dependable and do some road trips. Brings back memories of my 71 Coupe DeVille. They are both built on the same platform. I like the 98's instrument panel more.
Old Aug 2, 2018 | 07:37 PM
cutlassjim's Avatar
Well here is the beautiful, but not very pretty part, lol. I dont think the engine compartment has ever been detailed. Are E heads any good. My shop is pretty good sized, i just have to much junk.
Old Aug 2, 2018 | 07:46 PM
E heads are just fine. I'd say your valve cover gaskets leak a little. That is a hi compression, probably low end torque, nice mannered cam 455. It is perfect as is for that car with maybe some detailing.
Although most of the rowdiness was left to the A body Cutlass brothers, the 88 B body could have some performance, but the C body 98 was about dignity, quiet exhaust, and a smooth idle. This is as close as Olds came to asking for Grey Poupon out the rear window.
Old Aug 3, 2018 | 08:01 AM
blakes7's Avatar
Neat 8-Track player, does that work?
Old Aug 3, 2018 | 03:57 PM
cutlassjim's Avatar
Yes, the 8 track works great. The stereo sounds kind of rough. I haven't been able to get the front speakers working yet.
neatolds
Aug 22, 2015 10:59 AM
oldspackrat
Mar 12, 2015 06:34 PM
radioburningchrome
Dec 14, 2012 03:12 PM
jlkoldsman
Aug 5, 2012 03:23 PM
jensenracing77
Apr 5, 2011 08:44 PM
