Turn signal problems
Old Aug 25, 2018 | 04:54 PM
jeclin's Avatar
Post Turn signal problems
My 1970 Culass turning signals are out of sorts. I first noticed them beginning to blink very slowly. I bought a new flasher, but now the left signal doesn't work at all. I've checked all the bulbs, and noticed the one on the rear left is loose in the socket. I put in new bulb & bulb grease. The right signal is working ok, but left just doesn't want to work. Does anyone have ideas of how to fix?
Old Aug 25, 2018 | 06:33 PM
Do the 4 ways work?
Old Aug 26, 2018 | 01:46 AM
Did you replace the hazard flasher that is plugged into the fuse box or did you replace the turn signal flasher that is plugged into a socket on top of the steering column?
Old Aug 26, 2018 | 05:58 AM
If the right signal is working its not the flasher.
Old Aug 26, 2018 | 10:44 AM
Just pointing out that there are two flashers for the different functions.
Have a look at this thread for info on loose bulb connections:
Right brake lights not working
https://classicoldsmobile.com/forums...ml#post1120137
1BOSS83
Jun 30, 2014 11:40 AM
gabe442
Jun 9, 2012 10:07 AM
Olds92
Dec 1, 2011 02:59 AM
72442
Nov 17, 2009 08:04 AM
pinky
Sep 30, 2007 06:30 PM
