1992 cutlass convt. flasher location!??
Hello,
I have a 92 oldsmobile cutlass supreme convertable. I cannot figure out where the turn signal flasher is located. If anybody could help me out that would be greatly appreciated!!
I'm assuming it's my flasher that needs to be changed. When I put my turn signal on (either left or right) the turn signal blinks VERY quickly. I don't think I have a lamp out because when I turn my hazards on they blink normally.
Thanks guys!
Thanks guys!
I think the hazzard and turn signals use 2 different flashers. Turn signal flasher is usually clipped to a panel near the steering column. Fast flashing usually means a bad bulb, are you sure yours are good? Can you hear the flasher ticking?
Sorry, brain fart - bad bulb means no flash. that's what I get for trying to type fast between phone calls at work.
When I turn the turn signals on I can hear an initial click once and then it goes away and my blinkers are blinking really quickly. I took off the cover piece below my steering column and cant seem to find it!
No.
The turn signal flasher is designed to flash differently if a bulb is out, but the 4-way flasher is designs to flash the same speed across a variety of numbers of bulbs.
You can swap the two flashers, and the lights will flash about the same, provided none are burned out.
Why not just turn on the 4-ways and walk around the car once and look at the bulbs? It's quicker than asking a question on the internet.
Hello,
Thanks guys!
Thanks guys!
You are right, there are 2 flashers. One for the hazards and one for the turns signals. The one you are looking for should be in the same place as the 1995 Regency I owned. It's under the AC shroud on the drivers side, which means you'll have to undo it and drop it so you can get access. It will either be taped or clipped to the subframe close to the column. The hazard lights are on a completely different circuit, that's why the lights operate normally when you used it.
