1968 turn signal flasher location
Welcome. I've moved your post to it's own thread. The turn signal flasher is on a wiring pigtail under the dash. The flasher clips into a clip screwed to the backside of the lower metal dash lip on to the left of the steering column. This is unfortunately not clearly spelled out in the Chassis Service manual.
If you don't know what you're looking for (which would allow you to "let your fingers do the walking" behind the dash), you may need to find it the first time lying on your back with a flashlight in your teeth.
It will look something like this (but will be to the LEFT of the steering column, up under the dash, by the headlight switch):
The search finction is your friend (although I will admit I cheated because I knew I posted this picture last year)
https://classicoldsmobile.com/forums...sh-wiring.html
