1968 turn signal flasher location
Old Apr 27, 2015 | 06:13 PM
ezheimers's Avatar
1968 442 - Where is the turn light flasher located? Thank You...
Old Apr 27, 2015 | 08:55 PM
Please start your own thread with your question, rather than hijacking a dead three year old thread.
Welcome to ClassicOlds.
Old Apr 28, 2015 | 06:21 AM
Welcome. I've moved your post to it's own thread. The turn signal flasher is on a wiring pigtail under the dash. The flasher clips into a clip screwed to the backside of the lower metal dash lip on to the left of the steering column. This is unfortunately not clearly spelled out in the Chassis Service manual.
Old Apr 28, 2015 | 07:21 AM
If you don't know what you're looking for (which would allow you to "let your fingers do the walking" behind the dash), you may need to find it the first time lying on your back with a flashlight in your teeth.
It will look something like this (but will be to the LEFT of the steering column, up under the dash, by the headlight switch):
Old Apr 28, 2015 | 12:13 PM
allyolds68's Avatar
The search finction is your friend (although I will admit I cheated because I knew I posted this picture last year)
https://classicoldsmobile.com/forums...sh-wiring.html
Old Apr 28, 2015 | 12:22 PM
Better if the car isn't upside down.
Old Apr 29, 2015 | 03:15 AM
Yellowstatue's Avatar
But you didn't show the secret location of the clip.
costpenn
Jun 24, 2015 10:38 PM
cargo442
Sep 11, 2010 06:55 AM
DarrylJ
Apr 12, 2009 04:37 AM
Flye
Apr 7, 2009 02:34 AM
JPDPG
Jul 30, 2007 03:28 PM
